Author Topic: What is this on the front forks?  (Read 1412 times)
Offline NCAmother
« on: June 13, 2025, 03:53:46 PM »
Here’s a picture of the lbottom of the forks on an old Tonti guzzi.   In the picture what is the socket head bolt for?  The bolt is facing the front of the forks
Howdy
Offline jrt
Re: What is this on the front forks?
« Reply #1 on: June 13, 2025, 04:00:04 PM »
Drain plug.
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Offline NCAmother
« Reply #2 on: June 13, 2025, 04:09:13 PM »
Thanks!
One other Question:  what size are the axle pinch bolts?
« Last Edit: June 13, 2025, 04:10:48 PM by NCAmother »
Howdy
Offline turboguzzi
« Reply #3 on: June 13, 2025, 04:22:48 PM »
but just as important is the empty hexagonal cavity under it.... its for the nut of the axle clamping bolt! by the dust in it, someone has been riding without it for a looong time. not safe, not good.
« Reply #4 on: June 13, 2025, 04:30:33 PM »
Thanks!
M10 x 40.
Offline Stevex
« Reply #5 on: June 14, 2025, 03:58:47 AM »
That pinch bolt is a Allen bolt, with a domed nut in the the pictured recess.
« Reply #6 on: June 14, 2025, 11:58:42 AM »
Do not over tighten the axel pinch bolts or it will crack the fork leg. It’s a place a torque wrench will get you in trouble. Especially true on the side with the larger diameter of the axel. Don’t ask how I learned that..
Snug is all it needs. At that time a new lower fork leg was only a hundred bucks.
« Last Edit: June 17, 2025, 10:27:41 AM by John A »
