Author Topic: setting up delrin manifolds & PHF on t3  (Read 7060 times)
Offline yackee
« on: June 14, 2025, 08:08:35 PM »
I ran into some issues with installing new PHF30 carbs on my t3. Initially things seemed fine, but after a 60 mile ride the bike started acting strangely, revs wouldn't come down with the clutch pulled. At home I found all the manifold bolts had loosened. I tightened them back up but the bike still won't run reliably, revs still stay high before dropping and then stalling.
I was wondering:
1. how tight do I tighten down the delrin manifolds? I am worried about cracking the plastic.
2. Does anyone use RTV, or should the o-ring be enough? And do I change the o-ring every time I take the manifolds off the cylinder?
3. Does anyone use lock washers under the manifold bolts?
Anything else I should consider? Thanks for any tips.
Online SIR REAL ED
  • uh.... it's personal....
Re: setting up delrin manifolds & PHF on t3
« Reply #1 on: June 15, 2025, 07:26:48 AM »
I would install the biggest flat washer you can next to the manifold to get some bearing area.  Then a lock washer and only tighten enough to compress the lock washer.
If it still leaks or loosens up, then I would use some sealant on the o-ring and thread locker on the threads.
2019 Beta EVO 250
Online Frenchfrog
« Reply #2 on: June 15, 2025, 07:31:14 AM »
I've had issues with those manifolds and took them off and went with alloy ones.
The main problem I had was the manifold screw threads for fitting vacuum gauges leaked and stripped so I fitted helicoils with an o ring to seal the screws and have a decent thread.
Personally I don't rate the delrins after that.
Offline Turin
« Reply #3 on: June 15, 2025, 12:58:29 PM »
did you use step studs and lock nuts? That's what i did and have never had an issue.
1985 Sidlow Guzzi
Online Frenchfrog
« Reply #4 on: June 15, 2025, 02:23:57 PM »
yeah but the issue was with the bleed screws on the sides Turin.They leaked .
« Reply #5 on: June 15, 2025, 02:55:47 PM »
They have metal thread inserts in the vacuum ports now.
Offline Turin
« Reply #6 on: June 15, 2025, 03:26:29 PM »
Wouldn't be the first time I read something wrong... so the bleed screws to the port on the sides of the manifolds are coming loose and causing a vacuum leak? I'd use a dab of Silicone on the threads or just glue them and be done with it. That's just me though.
1985 Sidlow Guzzi
Online SIR REAL ED
« Reply #7 on: June 15, 2025, 04:41:57 PM »
some would say they... bled...
2019 Beta EVO 250
Offline yackee
« Reply #8 on: June 15, 2025, 06:29:14 PM »
I used thread-reducing inserts but hadn't thought about reducing studs. That might be the solution.
Offline yackee
« Reply #9 on: June 15, 2025, 06:30:07 PM »
Frenchfrog, which alloy versions did you use? I didn't know anything non-plastic was available to mount them to a T3. I still have the stock manifolds.
Offline Turin
« Reply #10 on: June 15, 2025, 06:39:23 PM »
I got my step studs at ace hardware. I use a little copper RTV on both sides of the gasket.
1985 Sidlow Guzzi
Online Frenchfrog
« Reply #11 on: June 16, 2025, 03:32:24 AM »
I helicoiled mine...still have to say ,much to my surprise, the bike runs better with alloy manifolds !!!!
Online Frenchfrog
« Reply #12 on: June 16, 2025, 03:36:37 AM »
You can use any of the alloy manifolds as long as they match the carb and cylinder intakes.They do need a small bit of porting to match to the heads as a rule but this is not really essential.
The ones I used for T3 heads and then LE Mans heads were from later square head bikes
« Reply #13 on: June 16, 2025, 08:38:12 AM »
I was never a fan of the Delrin manifolds - I try to avoid plastic anywhere critical on older Guzzis. The clincher for me was when I ordered a pair for a customer and one arrived cracked, brand new in the wrapper. Nope...
Online Frenchfrog
« Reply #14 on: June 16, 2025, 06:47:22 PM »
I fell prey to the shtick Antietam  and at that point didn't come across any ally ones
Offline wirespokes
« Reply #15 on: June 16, 2025, 10:45:15 PM »
I've thought of trying the FI manifolds. Perhaps the 40mm Dellortos could mate up to them? Anyone do that?
Thanks for the word on the Delrin manifolds. I've never been too excited about plastic in that application.
I've wanted to cast aluminum and it doesn't seem too difficult. One of the first projects would be intake manifolds for 36 Dells.
Offline Turin
« Reply #16 on: June 16, 2025, 11:36:42 PM »
fyi, Stein Dinse and others sell alloy reducer manifolds that taper down to fit a bigger than stock carb. I bought a set for my lemans III.
1985 Sidlow Guzzi
Offline wirespokes
« Reply #17 on: June 17, 2025, 10:29:18 AM »
I'd think the stock 36s on a LM3 would be sufficient. Is there much to be gained going larger?
« Reply #18 on: June 17, 2025, 12:05:30 PM »
I had a pair of G&G Delrin manifolds on the 1000S but when I had the heads flowed by Mike Rich he told me to ditch them because they leaked. But I’ve had a pair on the CX for years with no issues and that bike has always run well with those manifolds. And when I purchased the manifolds the stepped screws weren’t available, so I just used the original screws from the OEM manifolds and they’ve never been removed.
Offline guzziart
« Reply #19 on: June 17, 2025, 04:05:39 PM »
FWIW, I've been running delrin manifolds on my '87 LMIVSE for almost 12 years now.  Initially, the metal thread insert for the vac ports came out with the screws.  I complained to the vendor about the threads coming out, he said send them back for a refund, he'll use them on his bike!  I declined his offer.  Instead, I cut some threads on a small piece of metal brake line, put a little JB Weld on them threads and screwed them into their respective manifolds, I then installed rubber vacuum caps on the pipe ends, problem solved.  Anyway, since the basic manifold installation, I've not had any other issues with the manifold bolts loosening up or vac leaks at vac ports, carb to manifold joint or manifold to head.  IMO, the delrin manifolds do a good job supporting the carb if the original air box plumbing has been removed to facilitate pod filters.
« Last Edit: June 29, 2025, 11:33:45 AM by guzziart »
Offline Turin
« Reply #20 on: June 17, 2025, 06:39:06 PM »
I'm also doing minor headwork, installing a P3 cam, ergal flywheel, and a Rennsport 2-1-2 exhaust. Otherwise, the 36s would be plenty.
1985 Sidlow Guzzi
Offline yackee
« Reply #21 on: June 28, 2025, 09:00:13 AM »
Thanks to all who helped out with this. I got the T3 sealed up and running properly with the delrin manifolds and the PHFs.  The manifold holes for the bolts/studs are 8mm, and they have brass inserts (I think they are called shelf washers??) that bring the diameter down to 6mm. The inserts pop out easily. So I could have used the manifolds with my original 8mm manifold bolts by popping out the inserts and using a washer. But before I figured that out I went ahead and installed 8mm-to-6mm reducing studs as suggested, with nylock nuts.
Just to close this out, this is what seemed to be causing the original air leak problem: the brass inserts were noticeably longer than the thickness of the base of the manifold, and because they "stuck out" the base of the manifold wouldn't sit flush with the machined surface on the cylinder.
Problem solved by grinding down the inserts until they fit flush with the base of the manifold. And then I RTVd it just to be safe.
Offline guzzista
« Reply #22 on: June 28, 2025, 11:55:09 AM »
For those interested , the Malossi aluminum manifolds are still available, and like everything else  of the sort, supplies have also been drying up . I was getting them States side from a scooter  supply house that has vanished since -.  Here is a set on EBAY UK( no association on my part, just sharing the link).  Admin please delete if not appropriate
https://www.ebay.co.uk/itm/386840632910
