Author Topic: EldoVert now making a whining noise in high gear -SOLVED-  (Read 1253 times)
Offline lazlokovacs
« on: June 16, 2025, 03:43:09 AM »
Just to prove that it never rains but it pours, the EldoVert after 4 years of 100percent trouble free riding has decided to present me with 2 problems.
The ignition stuff is in another thread.
After coming off the highway yesterday, I noticed a loud whine whenever I decelerated and at low revs in high gear. It's never done this before. Hard to tell if it's still whining at speed due to the other noises generated.
I vaguely remember reading something about this on the site, but can't find it through searching.
Anyone know what this might be?
Thanks as usual.
« Last Edit: September 04, 2025, 11:12:36 AM by lazlokovacs »
Offline Don G
Re: EldoVert now making a whining noise in high gear
« Reply #1 on: June 16, 2025, 12:16:29 PM »
Oil level in trans ok? Try shifting it between ranges maybe the shift fork is loaded?  DonG
Offline lazlokovacs
« Reply #2 on: September 04, 2025, 11:12:16 AM »
-SOLVED-
Changed the ATF fluid and the noise went away,
you live and learn!
Offline bigbikerrick
Re: EldoVert now making a whining noise in high gear -SOLVED-
« Reply #3 on: September 04, 2025, 12:38:34 PM »
My convert always whines at certain rpms.  A California II automatic I had did the same thing. I always thought that was the nature of the beast.  Its interesting what you report, with the atf. was the level low?
Rick
Offline lazlokovacs
« Reply #4 on: September 05, 2025, 04:30:43 PM »
No, not low, but had been in there a while, looked a bit dirty as it came out....
I'd be lying if I said I could explain it but the whine has gone!!
