Author Topic: The NoMar did it again  (Read 11847 times)
Online Perazzimx14
Re: The NoMar did it again
« Reply #30 on: July 08, 2025, 07:25:22 AM »
Using plants as soft material to prevent rim damage is brilliant!!
Also need to furrow out a area for the disc so it doesn't have to be removed each tire change  :thumb:
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline guzziart
« Reply #31 on: July 08, 2025, 09:07:18 AM »
I don't understand the "crawling around on the ground" comments in reference to the Coats 200. One lays the wheel down onto a pad to break the bead (requires bending over - oh my!  :grin:), then operates the lever at waist level to break the bead. <shrug> One must then bend over again to flip the wheel, repeat, bend over to pick the wheel up and put it on the changer. Oh the horrors.  :grin: :grin:
Well, the crawling around on the floor reference was meant for the rabid & max units, not the Coats or the bead breaker any of these manual changers. The Coats was my preference at the time I was looking for a manual changer but they were out of production and I wasn't able to locate anything used at that time.  And, bending over is an issue for me since I no longer have a "young" back (boo hoo, woe is me).  Yeah, I can bend at the waist but straightening back up is difficult for me, as is stooping down to pickup everything I drop on the floor :laugh:
Age has nothing to do with it, I just don't like working on the floor. Heck, I put the bike on lift to check the tire pressure  :thumb:
Me either but haven't been motivated enough to put the bike on the lift to check TP.
I don’t find the Coats 200 I have here at my home shop to be a “crawling on ground” inconvenience in any way, either.  I like it very much
Me either although I don't have a Coats
guzziart: "Although I'm not a fan of crawling around on the ground to do a tire like with the Max & Rabid." No reference to the coats in his comment??
I don't understand the desire to work at ground level, so I guess we agree to disagree. Personally, my days of working on the floor are over. I don't care if everyone else works in a hole in the ground in my world the work comes to me and my back is better for it. YMMV
Yeah, I didn't mean to come off as enjoying to work at "ground level" I don't.
« Last Edit: July 08, 2025, 09:42:08 AM by guzziart »
Offline Dukedesmo
« Reply #32 on: July 08, 2025, 09:49:07 AM »
Quote from: Wayne Orwig on July 05, 2025, 01:41:52 PM
Then there is the fact that it turns a one hour job into a one day job.
___________________ ______________
That's why I do my own, doing it when I want to rather than relying on someone else.
Plus saves me some money, what's not to like.
Le Mans II
Ducati 916
Ducati M900
« Reply #33 on: July 08, 2025, 02:21:40 PM »
Us shorter guys are built lower to the ground.....so not a problem.   :grin:   :shocked:
Offline guzziart
« Reply #34 on: July 08, 2025, 08:12:37 PM »
I resemble that remark! :laugh:
« Reply #35 on: July 08, 2025, 08:19:55 PM »
Me too.  Way less effort to stand up than youse beeg guys.   :evil:  Kind of like working on tight spaces on cars/motorcycles.  I don't know how some of you beeg guys can your sausage fingers into teeny tiny spaces.   :evil: :shocked:
Online Moparnut72
« Reply #36 on: July 08, 2025, 09:42:02 PM »
When I worked in the radial engine overhaul shop we had an expression that "the second world war was a myth." No way the industry could have built that many engines in that period of time. You think our machines are tight to work on you haven't seen anything. I think that all the Rosie The Riveters with their tiny hands had an easier job of it.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #37 on: July 09, 2025, 08:55:50 AM »
My last trip to a dealer ended with the chain at max tightness zero slack, and the tires inflated to the max tire pressure from the sidewall. The tech was in his first week of work and it was a $400 bill just for the install of two tires
  :popcorn:
Well, there ya go. (shrug)
