Author Topic: Acid Based Aluminum Cleaners  (Read 11886 times)
Online PeteS
« on: July 11, 2025, 04:30:35 PM »
Just discovered that Eagle One Etching Mag Wheel Cleaner is NLA. I found it the best way to clean cast aluminum cases, cylinders, and heads. I tried some Napa Aluminum Brightener but its nowhere near as effective. Anyone found something that works as well as the Eagle One?
OB Guzzi content, I found the alternator cover on the new V85 stained from road debris or water? Lots of elbow grease with Mothers Mag Polish and its still not like new. Not sure why they didn’t treat it or clear coat it.
« Last Edit: July 11, 2025, 04:32:34 PM by PeteS »
Re: Acid Based Aluminum Cleaners
« Reply #1 on: July 11, 2025, 04:38:58 PM »
Mark @ Moto Guzzi Classics uses Zep Alume-E. I've tried to buy it from my local Zep dealers and distributors without success.
Online PeteS
« Reply #2 on: July 11, 2025, 04:57:16 PM »
AlumE doesn’t even show up on the Zep website other than a description. I wonder if an ingredient used in these acid cleaners are now banned, like methylene chloride paint strippers are now banned?
Offline aklawok
« Reply #3 on: July 11, 2025, 05:08:51 PM »
I got interested in this product and this is all I could find:
https://images.zep.com/zepcorporate/tds/psr_1062.pdf
In the notes it says:
Note: Zep’s Product Care Program requires Zep Sales Representative and their Customers be certified in proper handling and use of this product as it contains HF.
Probably why it's not a direct sale item, there is a call# on the spec sheet though.
2007 california vintage
Offline John Croucher
« Reply #4 on: July 11, 2025, 05:20:48 PM »
Pinsol cleaner.  Has acid and alcohol base, smells good.
Online AJ Huff
« Reply #5 on: July 11, 2025, 05:26:31 PM »
Looks like Eagle One Etching Mag Wheel cleaner is basically phosphoric acid with a splash of sulfuric. Milk stone remover is phosphoric acid so you might have similar results with it. And probably a lot cheaper.
-AJ
'71 Ambassador
'01 California Special
'05 Road King
MGNOC# L-753
Online PeteS
« Reply #6 on: July 11, 2025, 05:34:35 PM »
Colas have phosphoric acid as well. I know some have used it as a rust remover. Eagle One would work in about 30 seconds. Spray on, wash off with lots of water.
Offline RinkRat II
  • Lake Powell AZ
« Reply #7 on: July 11, 2025, 07:00:28 PM »
    Zepalume........... .... Section 3. Composition/Information on Ingredients
 SULFURIC ACID; oil of vitriol
 HYDROFLUORIC ACID ; hydrogen fluoride; hydrofluoride
 PHOSPHORIC ACID
 ETHYLENE GLYCOL MONOBUTYL ETHER;   2-butoxyethanol; butyl cellosolve
      Nasty but probably works great :evil:
      Some very dilute lye and water mix may be worth a try
       My $.02
      Paul B  :boozing:
« Reply #9 on: July 12, 2025, 04:28:57 PM »
That's because that stuff is extremely toxic and they will not sell it like most of their consumer based retail products. I assume that Mark gets it because he is running a business that justifies the use but after a friend talked to a Zep salesman about the product I'm no longer interested in taking that risk and either is my friend.
Online PeteS
« Reply #10 on: July 12, 2025, 05:41:31 PM »
Looks like there are many phosphoric acid cleaners on Amazon. I may try one of them.
Offline FrankenGuzzi
« Reply #11 on: July 14, 2025, 02:56:03 PM »
Power Team Acid Rinse contains phosphoric and sulfuric: https://www.tractorsupply.com/tsc/product/dairyland-power-team-acid-rinse-1201150
Offline boatdetective
« Reply #12 on: July 18, 2025, 12:47:58 PM »
Yup- Zep Alum is primarily Hydroflouric and YES, it is ridiculously dangerous. However, it does work like a bastard. They pulled it a number of years back.
Here's a hint- find an operation that commercially cleans tractor trailers. They will have 55 gallon drums of the stuff.
People as a rule tend to be generic about their acids, but don't realize that acids attack (or don't affect) metals differently. In fact, you can buy a suite of acid reagents to positively identify most metals. I recall having my V50 engine on the bench and had a hell of a time finding which acid really worked to brighten the case (I was unsuccessful).
Jonathan K
Marblehead, MA
1981 V50III "Gina"
2007 1200 Sport "Ginger"
Online PeteS
« Reply #13 on: July 18, 2025, 06:38:37 PM »
I did an MSDS on this stuff. They claim it has Sulfuric but MSDS makes no mention of it so maybe just a trace amount for advertising purposes.
Offline Pescatore
« Reply #14 on: July 19, 2025, 07:20:29 AM »
I used Muc-Off and did a good job brightening the engine
and cast aluminum wheels.
A toothbrush worked magic into tight spots.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
