Author Topic: Aluminum welding  (Read 3989 times)
Offline sdcr
Aluminum welding
« on: August 25, 2025, 11:04:43 AM »
I am looking at a vintage motorcycle from th 90’s. It currently has a crack in the aluminum swingarm. The crack is along the pivot area, where the SA attaches to the rear of the engine.
I plan to remove the swingarm arm, and have it welded. Can anyone recommend a good alloy welder?
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Offline sdcr
Re: Aluminum welding
« Reply #1 on: August 25, 2025, 12:28:53 PM »
Ducati 900 SS/SP?
Any weld shop worth it salt can help.
Actually, it’s a 1993 750SS. Here is a picture of the crack. It in a critical area, which is stressed by the pinch bolt.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Offline sdcr
« Reply #2 on: August 25, 2025, 01:54:40 PM »
No, just started the looking process, and saw the crack. I like the bike, so may go with the purchase.the less expensive CR Ducati 900, had a metal swingarm arm. I may go with that one.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Offline nc43bsa
« Reply #3 on: August 25, 2025, 02:06:47 PM »
I would be leery of welding an aluminum swingarm at that particular location.  A metallurgist once told me that aluminum alloys "have a memory", in that accumulated stresses add up until the part fails.  Failure of this part in a high-speed sweeping curve would be hairy, to say the least.
As mentioned, I would go with a good used part rather than trying to repair that one.
1990 MilleGT
Offline nc43bsa
« Reply #4 on: August 25, 2025, 02:09:23 PM »
Also, when I tried to view the photo, the hosting site (imgbb) wanted a subscription.
Has it come to this, that a subscription is required to view photos in addition to posting them?
« Last Edit: August 25, 2025, 02:09:52 PM by nc43bsa »
1990 MilleGT
Offline sdcr
« Reply #5 on: August 25, 2025, 04:40:17 PM »
I saved the photo from an auction site, so I get the same prompt.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Online cliffrod
« Reply #6 on: August 25, 2025, 05:29:55 PM »
I also got the prompt on this specific photo, but didn’t get it on imgbb image from another thread.
Online Dukedesmo
« Reply #7 on: August 26, 2025, 08:54:15 AM »
Quote from: sdcr on August 25, 2025, 06:28:53 PM
___________________ _______________
I had the same thing happen on my Ducati Monster, although the swingarm was an 851/888 racing item with the bracing. Apparently they were renowned for cracking until they modified them for later models using a different grade of alloy and making them a little thicker in that area.
I was originally going to weld mine but I actually had a later (non-braced) improved model so I used that instead, I left the cracked one with a welder friend to repair but, for one reason or another it never got done.
The advice I got was to stick with the newer model as it likely won't crack, the older stuff was not really good enough but I don't know if that also applies to SS models of the era?
I didn't know mine had cracked until, when riding along the rear end felt 'loose' almost like a puncture. When I looked down at the swingarm pivot this is what I saw;
The spindle was completely out of the swingarm on the chain side so the whole rear end was flexing under power. Initially I thought the pinch bolts had loosened as the cracks weren't visible until I got a really good look at home as they were underneath
Here's the break on one side;
And the other;
I think it would be best to get a new swingarm if at all possible.
Le Mans II
Ducati 916
Ducati M900
Offline sdcr
« Reply #8 on: August 26, 2025, 12:42:57 PM »
Thanks for all the tips on this Ducati swing arm arm. I am now in agreement, that replacing the swing arm is the best path.
Anyone here know what year Ducati upgraded the part? There are many advertised on eBay, but it’s challenging to tell what one are the upgrade.
 Also, Since the bike will not be tracked, but just a rider, I may go with the steel, CR swingarm.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Offline sdcr
« Reply #9 on: August 27, 2025, 07:27:38 PM »
I missed out on the Ducati 750SS. Went for more than I wanted to pay, with transport costs and needing a new swingarm arm, +.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
