Author Topic: Are the newer style petcocks as good as oem?  (Read 238 times)
Offline NCAmother
« on: August 28, 2025, 10:24:10 PM »
I’ve got an 850T tank that needs petcocks. The newer style are much cheaper, are they any good for non stock 850T?  As good as the more expensive petcocks?  Thank you
This is from MGcycle site
Howdy
Offline Guzler
  • 1977 850 T3
Re: Are the newer style petcocks as good as oem?
« Reply #1 on: August 28, 2025, 10:50:23 PM »
These are bullet proof:
https://www.treatland.tv/vintage-OMG-petcock-16mm-p/omg-16mm-01z3254011z.htm
Offline frozengoose
  • To eaches his onus...
    • smiles from nowhere
« Last Edit: August 29, 2025, 12:05:26 PM by frozengoose »
Big Jon
Jerry Zee
« Reply #3 on: August 29, 2025, 08:59:52 AM »
I've installed at least a dozen pairs of them, never had a problem.
Offline bigbikerrick
« Reply #4 on: August 29, 2025, 11:00:10 AM »
I put a pair of those in my 76 Convert, its been over 3 years now with no problems. They were a bit" stiff" at first, I took them apart,and lubricated the area under the handle ,with some silicone grease,,and they work very smoothly.
Rick.
Online Turin
« Reply #5 on: August 29, 2025, 11:53:57 AM »
Stay away from the re-pop sugar cube petcocks. Every set I've bought started leaking pretty quickly. The new BAP style work.
1986 Sidlow Guzzi
1996 Triumph Daytona 900
