Author Topic: Aux/fog lights on tonti  (Read 1628 times)
Offline yackee
« on: August 29, 2025, 05:45:50 PM »
Moto, on this board, very kindly gave me a pair of nice LED auxiliary/fog lights for my T3. He has similar lights mounted on his T3, under the headlight with a clever homemade bracket.
I was hoping that others on the board might be able to share their strategies for mounting aux lights on their Tonti-frame bikes so that I can think through the possibilities. I have the "civilian" crash bars, but they don't seem adequate, either because of angle/height that the lights would be mounted at, or because they would be close to the exhaust port, which I don't want to obstruct. And I have the "tall" police-style windscreen on, as sold my mgcycle. my turn signals are mounted on a bar, also sold by mgcycle, on the bottom fork cross-brace.
Thoughts appreciated. And a shout out to Moto for his generosity and deep experience with these old bikes.
Online StuCorpe
Re: Aux/fog lights on tonti
« Reply #1 on: August 29, 2025, 06:50:19 PM »
I used a pair of clamps from Harpers that they use to mound their fairing.  A long threaded rod filled up with stainless steel nuts to make it larger diameter (probably not necessary).  It looks like this.
« Reply #2 on: August 29, 2025, 07:49:49 PM »
On the bottom triple tree in front is where the brake fitting for front brake is, this is perfect place to mount bracket w/brake piece on top.
« Reply #3 on: August 30, 2025, 08:18:04 AM »
I'd be concerned that lights mounted too close to the turn indicators.  Could wash out the signal to approaching drivers.
Online StuCorpe
« Reply #4 on: August 30, 2025, 10:25:44 AM »
King of Fleece- Doesn't seem to.  I have them connected like the aux driving lights on autos are supposed to be.  They are only on while driving on high beam headlight, whenever I go to low beam they go off.  That way no one coming toward me is not blinded like so many of todays super bright LED headlights do.
« Reply #5 on: August 30, 2025, 10:56:21 PM »
I like that look but I would have used a different spacer rather than the nuts.
When I put spots on my V7III Special I found that the factory had drilled and tapped holes under the bottom triple tree so I simply carved out a 3mm Aluminium plate for the two spots and a pair of fiaam freeway blaster horns.
I wired the spots thru a pair of 2 Amp reed switches inside the headlight bucket a small magnet on the outside of the plastic bucket closes the reeds. If I don't want the lights on I just move the magnet further away.
I used a pair of diodes one from High beam one from Low beam so the spots are on Low or High.
High beam ----->|----/------Spots
Low beam  ----->|---/
Online StuCorpe
« Reply #6 on: August 31, 2025, 09:46:10 AM »
Kiwi Roy - I like the idea of something larger than the nuts.  But I used what was available and free.  I happen to have a lot of stainless steel (mostly 3/8" and 1/4") hardware from working with television transmission line so what was on hand and free is what got used.  I used One relay energized off the High beam light to turn on the aux lights.  Here again used a relay that I had on hand and was free.
