Author Topic: Cali 1400 Electrical Issues  (Read 15398 times)
Offline rrojaswahl
« on: August 31, 2025, 07:42:06 PM »
Friends - after ~ 100 K miles now the electrical issues are starting to get worse on my 2014 California 1400 Touring:
Red triangle comes on, big SERVICE letters appear, and while the bike still runs for ~ 60 miles or so, eventually the ABS and traction control lights come on and then I allegedly drive 247 miles per hour, hence the whole display goes nuts, and then the bike dies.
It's not mechanical - it's electrical. When I diagnose the errors stored the ECU I get the following codes & descriptions (translated from German):
P0610 - brake light relais too low
P0700 - A-PRC function error: no signal - what does this mean, what is the PRC function?
both have appeared on two occasions by now.
then also recently the following two codes appeared alongside those above:
P0560 - Battery voltage : too low (even though I had just recharged the battery btw...)
P0701 - no signal - again: what does this mean?
Is this an alternator issues, hence the battery not charging? Or are there other underlying issues that I don't know about?
Is a new alternator the only remedy here, or has anybody had a similar issue and fixed it differently?
Many thanks & cheers,
Roy
Offline Moparnut72
Re: Cali 1400 Electrical Issues
« Reply #1 on: September 01, 2025, 08:40:47 AM »
I haven't had my 1400 for about 4 years. First thing check the voltage first thing while it is running, This can be done using a function on the dash as you probably know. I would replace the battery, they are cheap, at least in the US. If you don't have one I would get the Service Station manual. There is a complete list of error codes in it. There is a guy who sells them on eBay. He goes by "meandmylittleman201 5. I have purchased several manuals from him. You can also get a digital version online from Cadre Cycle. Good luck.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #2 on: September 02, 2025, 06:00:22 AM »
Check your PMs
Offline rrojaswahl
« Reply #3 on: September 02, 2025, 07:49:45 AM »
Sorry - what are PM's? What do you mean by that?
Txs
Offline kballowe
  • - Kevin the Great -
« Reply #4 on: September 02, 2025, 08:01:03 AM »
Txs
PM=Personal Message
« Reply #5 on: September 02, 2025, 12:32:36 PM »
I sent you Pete Roper's email address by personal message. He knows what is wrong and will walk you through it. Just click on "my messages" above, copy and paste the address in your email browser, and send the message to Pete.
Online TN Mark
« Reply #6 on: September 02, 2025, 02:29:44 PM »
Oh man, doesn’t Pete post here any longer?
The man’s an absolute legend, in the very good way for the Moto Guzzi community. Years ago I bought one of his sump devices to help prevent the oil pump from starving for oil.
Plus he’s as funny as the day is long.
« Reply #7 on: September 02, 2025, 05:49:09 PM »
Many have left Mark, Beetle's gone too. I won't get into who insults who. None of my business.
Pete is easy enough to find, Griso Ghetto
« Last Edit: September 02, 2025, 06:15:55 PM by guzzisteve »
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #8 on: September 03, 2025, 03:48:08 PM »
First look at voltage with running engine, clean battery terminals.
Aprc is Aprillia traction control, or the Guzzi variant,
But the combination of errors points to missing voltage. Or connections or the generator or is regulation device buit in the generator as a replacable unit.
Paul
Daytona 1225, Stelvio 1151
« Reply #9 on: September 03, 2025, 04:54:08 PM »
+1 Paul, there was an update to cut a wire to Alt that will fry it if key is left on. AND the wire was still coming hooked up even in 16. The wire was to go to a GEN light but bike doesn't have one.  Do a search and you'll find it.
« Reply #10 on: September 07, 2025, 11:28:33 PM »
https://www.thisoldtractor.com/guzzi007/schematics/2014_California.gif
The Voltage regulator is internal to the Alternator, I have no idea if its a replaceable item, All I can suggest is to read the battery Voltage, should be 13+ at upper revs.
Im pretty certain the green wire to the Alternator should be alive with the motor running (Power thru Fuse 1) Do the horns work? they share the same fuse
« Last Edit: September 07, 2025, 11:35:12 PM by Kiwi_Roy »
« Reply #11 on: September 08, 2025, 09:21:02 AM »
The alt can be rebuilt & the regulator can be replaced, friend in IL just had this done for $100 bearings and all.
Offline rrojaswahl
« Reply #12 on: September 08, 2025, 06:17:53 PM »
Friends - txs for all the help and comments and ideas!
To answer the questions posed below:
1) When the defect happens and fuse 1 bursts, both horn and front-light go out. Daylight running- & rear-lights stay on. New (!) battery reads ~ 11.4 V after a ~ 50 mile ride with warning light on, so not close to 14 V and hence not charging during the ride. When I rev the engine, voltage of battery does not increase - again evidence it's not charging. But why not?
btw : Alternator rebuilt and regulator replaced for 100 dollars? Where?? Or do you mean 1000 dollars?
Many thanks again,
Roy
« Reply #13 on: September 08, 2025, 06:32:02 PM »
You can get a used one on ebay or take it to a rebuild shop. My buddy took his to a shop in Geneva, IL that's been around forever, they put in new bearings also. I would check everything on that fuse circuit for a pinched wire or bad connector.
Offline Vagrant
« Reply #14 on: September 09, 2025, 12:34:19 AM »
Clean all the ground wires too.
« Reply #15 on: September 10, 2025, 06:20:10 PM »
Sorry, which circuit are you referring to?
Update
Never mind I see it in the OP's last post. Fuse 1 feeding the headlight amongst other things
Does the headlight come On in daylight on this model?
The alternator doesn't seem to be putting out the correct Voltage, you could pull it off for testing by an auto electrician with a rig for testing alternators?
Have you checked the belt tension?
« Last Edit: September 10, 2025, 06:47:50 PM by Kiwi_Roy »
« Reply #16 on: September 10, 2025, 06:58:36 PM »
Roy, might be broken belt in 100Kmi, if it has not been checked.
« Reply #17 on: September 11, 2025, 10:04:41 PM »
There[s another post here talking about the alternator.
A couple of monkeys wrenching on a 1400
painfull to watch.
https://wildguzzi.com/forum/index.php?topic=123946.0
Online TN Mark
« Reply #18 on: September 12, 2025, 02:46:50 PM »
rrojaswahi,
     Did you get in touch with Pete Roper regarding your bike not properly charging? If so, what were his suggestions? So far, we've seen suggestions of needing a new battery, to cut the upper wire going into the back of the alternator and to ensure the battery along with other connections are clean and tight, also to ensure the belt is intact and working. Have you had a chance to perform these checks yet?
     If you already removed the alternator,  I'd certainly bring it to a local auto electric/alternator repair shop to be tested.
Sadly, there are three YouTube videos from link provided. The guy is in Canada and looks to have a fun home shop. But, he dismantled a lot of the bike to remove and replace the alternator and it didn't fix anything.
     Anyway, what's the status of your bike's charging system now?
Offline moto-uno
« Reply #19 on: September 16, 2025, 12:52:33 AM »
   Before you even dream of replacing the alternator ( a daunting task the first time ) . They are a Chinese unit and have on the back of them
a removable regulator . The part number will probably still be on it , it is easily ordered from China. I'd be surprised if the belt had failed . Good Luck  :thumb:
Online TN Mark
« Reply #20 on: September 16, 2025, 07:48:24 AM »
Moto Guzzi: hand built in Italy by those with an aversion to grease with low bid parts from China.
Also, remove and check the 30a and the 40a fuse on or near the battery + terminal. Apparently Guzzi used more low bid fuses with a pension for corroding. If the fuse terminals tarnish enough, the fuses can melt. There’s a lot of this type of information online.
Offline rrojaswahl
« Reply #21 on: September 18, 2025, 07:32:57 AM »
Dear All:
Many thanks again, and here an update:
I did not yet remove the alternator or check the belt - I know the latter an obvious thing to do, but that's a daunting task (service manual and a German online video (from "moto schrauber") basically say: remove tank, exhaust pipes (!) and engine itself from the frame (!!!), etc. etc. etc...). To me this is a multiple-day job done best during cold wintertime inside a warm garage, not for during the best time of the riding season with the last few warm sunny days left here the Northeast (albeit I am now limited to battery power and therefore range, but for now I have to live with that...). Even the dealer says he would only do this as a last resort...
Btw: The fuses and fuse boxes are fine and not visibly corroded or molten; battery connections are good and tight (I now recharge battery after each trip, and a carry second one in reserve always with me just in case); I had the brake relay replaced (to no avail); one cable to the rear light was frayed and I removed it (also to no avail). Upon revving engine, multimeter does not show increasing voltage at the battery - hence it's still not charging...
My current plan is to a) contact Pete Roper (will share his recommendations with his permission here in due course), and b) get an endoscopic camera to try to look "inside" for better visual diagnosis around the alternator before I engage on a bold mission to take half the bike apart...
Many thanks again & keep you posted,
Roy
Offline rrojaswahl
« Reply #22 on: March 27, 2026, 07:53:51 PM »
Dear All:
Here update of the work that was done recently over the winter months:
1) alternator belt replaced - no effect. red light still on, battery not charging, voltage remains at ~11V, even when the engine is rev'd up..
2) alternator (and converter) replaced - holding at about 13V at idle, and once I am above 3000 rpm it continues to hold. voltage doesn't go up further (should go to ~14V), but it also doesn't go down anymore.
So clearly the alternator itself was bad or old and needed replacing - but there is still a wiring problem or maybe a failing switch somewhere... Somewhere there is a shortcut. Relays and fuses were checked, and the electrical harness was also checked, but nothing obvious there...
frankly - I am just fishing for ideas, but because am out of ideas myself...
Many thanks in advance,
Roy
Online TN Mark
« Reply #23 on: March 28, 2026, 08:35:33 AM »
Was the alternator and its attached regulator bench tested prior to installing them? It most certainly needs to read 13.9VDC to about 14.2VDC.
I’ve not replaced the belt or an alternator on a 1400 but have watched those same German videos. I’ve watched every one of his 1400 videos and always learn from them.
At this point, you’ve replaced the three main components: alternator, regulator and the belt. You’ve also examined the fuses, associated wiring and the fuses.
Does the dash voltage match what you read with a separate voltage DC meter?
I wish I had a ‘check this or that’ suggestion for you. Sadly, I do not. Have you also check over at GuzziTech for a suggestion or a recommendation? The 1400 8V section they have is the best I’ve seen anywhere.
Offline vintagehoarder
  • Cycle Hoarders
  • Ride to Eat, Eat To Ride
    • Facebook Page
« Reply #24 on: March 28, 2026, 08:58:17 AM »
Might Investigate of this was done?
Cyclehoarders Garage
2021 Honda CT125 Trail Cub
2018 Triumph Tiger 800
2014 Moto Guzzi V7 Speical
2009 Vepsa GTS 250 ie
1986 Yanaha FZX700 Fazer
1981 Honda CX500 Deluxe
1973 Moto Guzzi Eldorado 850
1969 Yamaha YAS1C
LaGrange, KY
Offline rrojaswahl
« Reply #25 on: June 18, 2026, 02:35:49 PM »
Dear All:
Just wanted bring this to a closure: The culprit appeared to be a broken fuse holder where #1 fuse is sitting - it was very hidden and therefore not at all obvious to see. Only with a gyroscopic camera was I able to see it. Temporary solution: I cut off a blade from a spare fuse, put it into that spot where the holder was broken, and then added the normal fuse on top of that. Contact was made, and everything works fine so far. No error messages, and battery is charging. Did ~ 120 miles and fingers x-ssed it will stay that way.
A $ 2.25 cents fix, after having replaced so many other parts (alternator, belt & converter following that tech bulletin below - thanks!) also the brake relais and the front brake microswitch...)  !!!
Thanks to all who have helped and pass on the learnings! Cheers. Roy
