Author Topic: Norge likely suspects for batt drain?  (Read 15637 times)
Offline brider
Re: Norge likely suspects for batt drain?
« Reply #30 on: September 15, 2025, 08:12:46 AM »
     The alternator is absolutely on the battery circuit with the Diode Bridge separating the battery circuit from a ground through the windings. Not just a crack pot Theory but real trouble shooting. My 1200S had this same problem last year.
??? Re-posting the wiring diag here, with Alternator identified. Note the 40A fuse feeding the Alt right next to the 30A fuse I indicated as the offending circuit....if I pull the 40A fuse to the alternator, the .29A current drain still exists. I cannot see how the Alt in this case is still a likely suspect, although I WOULD like to know more about your similar problem and how you solved it:
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
