Author Topic: Different vibrations after fueling  (Read 11514 times)
Offline faffi
« on: September 06, 2025, 01:11:25 PM »
Near the end of my previous ride, and after filling the tank, my V9 got a new kind of vibrations that were primarily noticeable around 3000 rpm (60 mph indicated). Very fine buzzes, the kind you usually noticed with inline fours. You know, the really annoying buzz. I can feel them in the handlebars, seat and see it on the speedo needle that buzz into a fine blur. It gets worse with load.
It was the same today, and did not change after I filled the tank with petrol on a different station. Both stations are reputable brands with plenty of traffic going through, so fuel should be fresh.
I cannot hear anything ringing or any other noises that have not been there before, and engine power seems identical to before.
I understand this is not much to go by, and it could of course be a coincident that it happened after filling the fuel tank with new petrol/gas. But has anybody else experience similar vibrations appearing suddenly - AND found the culprit?
Current bikes:
2002 BT1100
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Offline lazlokovacs
Re: Different vibrations after fueling
« Reply #1 on: September 08, 2025, 03:30:31 PM »
I am by no means saying that this is the case for your engine but I had a similar sensation on a Calvin many years ago. People thought I was nuts but I was certain a new vibration had just appeared out of nowhere.
A year later the crank locked up as the oil pump sprocket had worked its way loose enough to stop circulating oil  :shocked: :shocked: :shocked:
Offline faffi
« Reply #2 on: September 08, 2025, 03:50:15 PM »
Ouch :shocked: I am going to check the bike over externally first, checking for any fastener or part that may have come lose. An oil pump sprocket coming off, though - what are the chances :undecided: Thanks for sharing the information!
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline SIR REAL ED
  • uh.... it's personal....
« Reply #3 on: September 08, 2025, 05:32:06 PM »
Erik,
Maybe your bike has been listening to this video?
https://www.youtube.com/watch?v=nGy9uomagO4
2002 MZ Skorpion
1994 DR Skorpion
Offline Tkelly
« Reply #4 on: September 08, 2025, 07:44:00 PM »
Maybe you should drop down a gear ,60 mph at 3000 rpm doesn’t seem right.
Offline chuck peterson
« Reply #5 on: September 09, 2025, 04:03:05 AM »
Drop two gears and call me in the morning…
4-6k w a steady throttle reaps rewards only found on a Guzzi
There’s a sweet spot at 4250…
And 4850
And 5250
5750
Even, gasp! 6000…
Let that motor sing.
But i always say that. Yes, things buzz at 3k that smooth out above that. At 21k mine still seems to be getting smoother.
In car parlance, turn the radio up…
Loose nuts bolts fixtures can be found w the motor off and tapping w a rubber mallet, maybe you’ve got something loose there. Pound on the tires with a massive whack to see if something buzzes elsewhere on the bike
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline faffi
« Reply #6 on: September 09, 2025, 07:14:28 AM »
Erik,
That could be  :laugh:
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline faffi
« Reply #7 on: September 09, 2025, 07:32:06 AM »
Indicated, so actual 57? IIRC the engine theoretically turn 3480 @ 62 mph, giving 3100 @ 57. In fifth, the period is around 50 mph actual, giving the same rpm. So the buzz happens around 3100 rpm, give or take a little, and increase with load. There is no buzz below or above the narrow range. The buzz is new, trembling vibrations have always been there, also increasing with load.
Dropping to 4th at 50-70 mph is not smooth, either, and generally less comfortable than using taller gears due to higher frequency shakes, but I do drop down for hills or strong headwinds.
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline Moparnut72
« Reply #8 on: September 09, 2025, 09:14:56 AM »
Wind 'er up. I haven't ridden an 850 but my V7 is almost never ridden at that rpm unless in town in lower gears. My V7 basically lives at 4,000+. Small blocks love to rev, big Blocks too.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline SIR REAL ED
« Reply #9 on: September 09, 2025, 09:30:54 AM »
Your bike may be confused about it's gender and might self-identify as an in-line four.
Removing pistons is simple surgery, adding pistons, not so easy.....
Is the buzz there at the same rpm's in all gears, or only at that rpm at some speeds?
Same rpm at all speeds would indicate something is a bit loose or worn.
Road speed variations could be a lot of things.  Key fob, helmet visor, new eye glasses.......
Try changing tire pressure to see if it changes the noise.
« Last Edit: September 09, 2025, 03:39:40 PM by SIR REAL ED »
2002 MZ Skorpion
1994 DR Skorpion
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #10 on: September 09, 2025, 09:35:26 AM »
kk
Keep in mind that the hemi head small blocks appear to run optimally at lower RPM than the older Herons. And the V9 maxes at 6800 RPM, the V7 III at 7200 RPM.
(this may not have any worth with faffi’s issue; just pointing out that Heron heads and hemi head small blocks are not be so apples-to-apples)
« Last Edit: September 09, 2025, 11:32:17 AM by Dirk_S »
Offline normzone
« Reply #11 on: September 09, 2025, 02:38:58 PM »
"Loose nuts bolts fixtures can be found w the motor off and tapping w a rubber mallet, maybe you’ve got something loose there. Pound on the tires with a massive whack to see if something buzzes elsewhere on the bike "
With my Bassa, I have found loose crash bars, motor mount bolts, shifter linkage, and more delivering what sounded like an RPM related pings.
Offline faffi
« Reply #12 on: September 09, 2025, 03:44:36 PM »
 :thumb: Max torque at 3000 rpm according to Guzzi, so that is not lugging.
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline faffi
« Reply #13 on: September 09, 2025, 03:47:59 PM »
Y
RPM is the common nominator, and more load at that RPM increase the buzz. Worn would be strange, especially since it happened between me stopping for gas and starting up again a minute later. But something loose it can be. My first suspect was the fuel, but it did not change when I filled up next time at a different gas station.
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline faffi
« Reply #14 on: September 09, 2025, 03:50:10 PM »
Good tips. As I think I've mentioned already, I will look/knock in search of something loose.
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline Bulldog9
« Reply #15 on: September 09, 2025, 03:58:27 PM »
3K is not technically lugging it, but every one of my seven Moto Guzzi's much prefer to be over 3,500 to 4,000 RPM.
Take it out and bang it off the rev limiter (okay okay, just below) for half a day. Your bike might just be tired of being ridden by an old lady. (LOL.... I kid I kid, but I am making a point)
MGNOC#23231
Offline faffi
« Reply #16 on: September 10, 2025, 12:31:35 AM »
I often rev it to or close to the limiter, but I see no reason to criuse at high rpm. More vibrations, more noise, more fuel.
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline SIR REAL ED
« Reply #17 on: September 10, 2025, 05:52:48 AM »
When you stop to refuel, are you chugging an energy drink?
Lots of kinds of buzz (American slang!) out there!   :wink:
Does it seem to be related to the amount of gas in the tank?
Worn gas tank mounting rubbers perhaps?
2002 MZ Skorpion
1994 DR Skorpion
Offline faffi
« Reply #18 on: September 10, 2025, 08:31:31 AM »
No and no, but it would have been a simple fix.
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline Bulldog9
« Reply #19 on: September 10, 2025, 10:51:00 AM »
When I took my Stornello on my 3k mile trip to Arkansas and back, I stayed in the 4-6K rev range and averaged over 45 mpg. Run your motor at higher rpm. Keep it above 4k. It will be happier.
You're gonna get weird vibes cruising at 3k or less. Or keep ignoring everyone's advice.
MGNOC#23231
Offline PJPR01
« Reply #20 on: September 10, 2025, 11:12:39 AM »
I still think it could be fuel related...you could add a fuel additive to the tank to get rid of any water that may be in the bad gas, and ensure that it eliminates that completely, or drain the tank as best as possible.  I've had a bad case of gas a couple of times that caused the bike to run very poorly, not just minor vibrations as you are mentioning.  Other than that, some screws have come loose, but it's too much of a coincidence that it happened immediately upon filling up.
« Last Edit: September 10, 2025, 06:58:46 PM by PJPR01 »
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Offline SIR REAL ED
« Reply #21 on: September 10, 2025, 05:55:17 PM »
Time to get out the stethoscope.
I like the idea of draining the tank and trying some additives and different kinds of gas.
I'd even add some two stroke oil to the tank, just to see if that makes the fuel pump sound different.
I've had water in the gas (especially in winter) make vehicles run poorly, but that is usually so huge a change that I never noticed any vibration difference.
2002 MZ Skorpion
1994 DR Skorpion
Offline faffi
« Reply #22 on: September 11, 2025, 02:54:26 AM »
I will believe this when someone can be bothered to run any Guzzi engine on the "rolling highway" dyno at 4-6K and an identical engine at 2.5-4K rpm under the same conditions, and prove less wear in the engine run at the higher rpm. My engine definitely vibrates more at 4K than at 2.5K.
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline SIR REAL ED
« Reply #23 on: September 11, 2025, 06:16:01 AM »
From previous posts, I have been interpreting the symptom as a change in vibration frequency, not a change in vibration magnitude.
Different frequencies will affect  cause resonance that was not there previously.  Which usually is a sign of something being loose.
I've always found a stethoscope or the poor man's equivalent of a long handled screwdriver held to the ear to be helpful in locating noises.
Lots of ideas have been thrown out there.  Enjoy the experimentation.  Please keep us informed of what you learn.
"Lugging" an engine, especially a twin or single, produces a whole different type of "vibration" than what you seem to be describing.
2002 MZ Skorpion
1994 DR Skorpion
Offline Dirk_S
« Reply #24 on: September 11, 2025, 06:28:48 AM »
I’m coming to faffi’s defense one more time on the revs topic.
I’ve owned a V7 II, and I now own a V7 III and a V9. While I can’t confess to be an extremely astute observer in all things technical regarding my riding experiences, I can indeed make an observation that the Heron likes to hang out a bit higher in the revs over the V7 III—like, 1,000 RPM higher—and the V7 III likes to rev just a little higher than the V9. Give them all a spin, and I bet you may feel the same way.
« Last Edit: September 11, 2025, 09:14:12 AM by Dirk_S »
Offline Clifton
« Reply #25 on: September 11, 2025, 08:34:11 AM »
I'm not saying faffi is lugging his bike but Bulldog's light hearted suggestion brings back a conversation I had some years back with Joe Katz who once owned BMW of Daytona and was a great mechanic on airheads and early K bikes.
 The customer complained that his airhead just seemed to be running a little rough so Joe changed plugs, balanced the carbs, checked timing, adjusted the valves, etc.
 Joe happened to notice as the customer left he short shifted up into higher gears, 20 minutes later he returned saying "it still just seems not to be as smooth as it used to be". Joe said he rode it and the customer was kinda right, it seemed to be just a little buzzier than a good running airhead should be.
 Joe told the customer (who lived almost an hour away) "ride this bike home but only in 1st and 2nd gear, once home take it back out and ride it normally then call me."
 The customer said "but, but, I'll be on 50 mph roads."
 Joe said "then go 50 mph but remember only 2nd gear!"
Joe said an hour later the customer called back thanking me saying the bike's running better than it ever has now.
I asked Joe "so what exactly did running the bike up close to red line for an hour do to fix it"?
Joe said "I don't know but it generally works."
25 R1300GS
21 V85TT
20 XT250
14 CB1100
08 1200R Sportster
93 R100R
Offline PJPR01
« Reply #26 on: September 11, 2025, 09:00:02 AM »
Surely a mechanic of this caliber would know exactly why this works...having torn down many engines I'm sure, he'd have seen the build up and crud that accumulates.
 :thumb: :thumb:
Paul R
2008 Silver Norge
2002 V11 Scura
Offline SIR REAL ED
« Reply #27 on: September 11, 2025, 09:12:13 AM »
 :thumb: :thumb:
Shirley, one would think so.....
More than one way to interpret the mechanic's response.  I took your response to be the second one.
The rider riding the bike differently, resulted in the rider riding a different bike was my initial interpretation.
2002 MZ Skorpion
1994 DR Skorpion
Offline Moparnut72
« Reply #28 on: September 11, 2025, 09:00:30 PM »
I am leaving on a camping trip tomorrow. I was going to take my Mandello but I have been apprehensive about riding it with all my camping gear. So I put it all on my V7lll and went for a spin. I usually only ride the V7 around town. As I was test riding it out on the highway I was thinking about this thread so I paid more attention to the rpm levels. I found that 4k+ rpm was the smoothest at highway speeds roughly 60 mph. Fifth worked at that speed but the mirrors were a bit fuzzy indicating a little bit of vibration. I doubt that sixth would be worth using until 70+ mph is achieved. I haven't ridden it on the slab since I bought it but after 6K miles it has gotten substantially smoother and loves to rev.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline faffi
« Reply #29 on: September 12, 2025, 10:35:40 AM »
That Beemer, likely having plenty of miles, carbs and less powerful ignition system could have suffered from choking and the high revs could have blown out the cobwebs. Not unlike a diesel being run only t low rpm that will benefit from a blast.
Regardless, I am inclined to go withthe theories of somethinghaving comw loose, since it happened suddenly,  not somethingdeveloped over time.
Either that, or crap entered the tank via the fuel..
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
