Author Topic: Installed Hagon Nitros V7 850  (Read 274 times)
Online MikeP996
« on: September 12, 2025, 03:26:05 PM »
Today I installed a pair of Hagon Nitros on my recently acquired '21 V7 850 Special.  The bike had Maxton front fork cartridges, Mistral mufflers, and a KN filter installed by a previous owner.  I had found the rear rather stiff so decided to add a pair of better shocks, adjusted to my weight
I had ordered a centerstand but it is hung up in customs and the shocks arrived so I decided to install them though it would have been easier with the centerstand.  But I figured one side at a time wouldn't be a problem.  BUT the Hagons are a couple of mm longer than the OEMs and even by pulling up on the frame to ensure the off side OEM shock was fully extended I couldn't fit a new shock onto the mounts.  Bummer!
But then I realized that since the Nitro's spring preload is fully threaded, I could take all the tension off the spring plus another few MMs, and compress the shock a bit so it would easily slide into place.  Before unwinding the adjuster I had marked its location so once the shocks were mounted I wound the adjusters back to the original position that Hagon had set them based on my weight.  So it ended up being quite easy.
It was raining so I didn't go out to see what difference, if any the new shocks made.  Should have gone anyway, it's not the first time me and the bike were soaked - when I picked it up two weeks ago it rained the entire 94 miles riding back home!  ;)
2021 Moto Guzzi V7 850 Special
1976 Honda CB400F
'73 Norton Commando
2017 BMW R1200RS
2015 BMW R9T
Offline bigbikerrick
Re: Installed Hagon Nitros V7 850
« Reply #1 on: September 13, 2025, 11:51:06 AM »
Thats a fantastic  bike you have, Mike.  Looking forward to the report on the first ride with the nitros!
Rick.
Online JJ
« Reply #2 on: September 13, 2025, 04:19:10 PM »
Rick.
Yes...and I would like to know if you can really notice the difference in riding with the *new* Nitros - - ??? :wink: :thumb: :bow: :cool: :boozing:
« Reply #3 on: September 14, 2025, 08:02:25 AM »
I've installed Nitros that were properly sprung and valved for my weight.  Big improvement every time.  4 different bikes.
