Author Topic: Backfiring persists after 1 year sitting  (Read 7369 times)
Offline baloo
« on: September 15, 2025, 10:27:28 AM »
1989 Mille GT 1000cc bought in 2021 and still all stock with about 36,000 miles.
Bike ran fine until I again let it sit for over a year.
So, to re-start, I fogged the cylinders, drained the carb bowls, dumped the old gas and put in new 93 octane gas, changed the battery, and fired it up -- no probs after a few cranks.
BUT, I get bad backfiring above 3000rpm.
I checked the plugs (which look ok) and made sure they were getting spark.
​Any suggestions regarding backfiring?
1) Anything ignition related due to sitting?
2) anything specifically carb-related due to sitting?
3) What could have gone wrong, mechanically, after sitting for a year to cause backfiring at higher rpm?
Thanks.
Re: Backfiring persists after 1 year sitting
« Reply #1 on: September 15, 2025, 10:54:56 AM »
Could be a number of things. Check to make sure your intake and exhaust bolts are tight. Might pull your carb bowls again and double check for any crud. Change the spark plugs to new or known good ones.
Now for  a weird one. Check you air filter box for rodent nests. as well as the mufflers.
« Reply #2 on: September 15, 2025, 11:44:49 AM »
Your points also may have some crud on them. Clean all ports in carbs, mix screws, pilot & main jets, needle & atomizer, and drillings in carbs.
Also the screw in center of distributor w/pad on it. Mahe sure drop oil on pad & loosen screw & just snug it. If it's tight the advance won't work.
Check wires & caps on plugs.
And what Tom said, varments get in airbox
« Last Edit: September 15, 2025, 11:46:54 AM by guzzisteve »
Offline baloo
« Reply #3 on: September 15, 2025, 01:27:23 PM »
Hah!  Rodents!  A possibility, in that it has been sitting under the carport, but covered (cover probably gives the rodents a sense of security, right?)_.
I did look in one of the carb bowls and got out some tiny crud.  Should I just bite the bullet and pull the carbs and clean out all the passageways?
Good thinking about the advance! I'll oil the pad and check the screw.
Likewise, I will check intake and exh bolts -- I assume you're saying that a leak would change the air/fuel ratio enough to backfire....
All good ideas, and thanks.
Online Moparnut72
« Reply #4 on: September 15, 2025, 10:14:17 PM »
I have a brush chipper that gets used once or twice a year. It has on start up run rough, I have added Seafoam and after a bit will start running normally. This year I put a fuel shut off valve on it so that should solve the issues.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline baloo
« Reply #5 on: September 16, 2025, 10:05:55 AM »
kk
Seafoam to the gas, I assume?
I do use the shutoff valves from the tank whenever it's not running, and I add gas stabilizer to the tank. I
But, I did empty the tank of the old gas and added fresh fuel before this most recent adventure.
Offline Dukedesmo
« Reply #6 on: September 16, 2025, 10:20:44 AM »
My LM2 backfires a little on the over-run, I can't find anything wrong with it and it runs well otherwise so I just assumed it's 'normal'?
But a couple of years back the crossover pipe between the 2 exhausts cracked where it joins the down pipe, it wasn't a big crack and was barely visible but it created a huge backfire issue. So checking the exhaust for leaks sounds like a plan.
Le Mans II
Ducati 916
Ducati M900
Offline redrider90
« Reply #7 on: September 16, 2025, 01:15:00 PM »
Thanks.
What kind of ignition do you have. Some 89s came with Moto Plat like my 90 mille. They are terribly unreliable. I'd check plugs first and then coils. Condensers can look ok at low RPM and fail at speed. Stock coils always good bad over the years.   Checking the timing is drop dead easy. Pop off the access cover on the flywheel and check the timing with a timing light. Advanced  is set at 5K RPMs so get out your ear plugs and a fan on the motor. I forgot for the moment what the timing is set at. I have to go out to my shop which I am not near to get the specs.  You can go to https://www.thisoldtractor.com/mg_manuals/owners_manual_california-iii_1989-01_en.pdf The 89 Calli with points is the samehttps://www.thisoldtractor.com/mg_manuals/owners_manual_california-iii_1989-01_en.pdf
« Last Edit: September 16, 2025, 01:16:58 PM by redrider90 »
Red 90 Mille GT
« Reply #8 on: September 16, 2025, 03:37:47 PM »
Backfiring…
Is it blowing back out the carb or firing unburnt mixture in the pipe ?
I’ll betting on points or distributor related cause, have you ascertained which side is failing ?
Offline chuck peterson
« Reply #9 on: September 16, 2025, 07:29:54 PM »
Did you clean the jets while the carb bowls were off? Im not familiar with the round slide carb but jets clog pretty easily when left alone without seafoam and or stabil
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline baloo
« Reply #10 on: September 20, 2025, 03:51:22 PM »
What kind of ignition do you have. Some 89s came with Moto Plat like my 90 mille. ....
I just get 10 minutes a day to work on the Guzzer, so please bear with me and my ignorance and erratic learning curve...
PLUS, lately, I have been taking The Stupid Pill (not a prescription item, and not available over the counter -- and definitely age-related) such that I completely unlearn decades of experience working on cars/bikes!!
I have spent an unnecessarily inordinate amount of time going thru digital workshop manuals on other Guzzi models that I downloaded, searching for just basic pics of the engine with component labels -- of which there are NONE.  Yes, I have probably hours spent in this endeavor.
1.  I was hunting for the distributer, and, DON'T TELL ME THIS IS IT, (see attached pic) buried under the gas tank and tucked inside and under the frame, and out of easy reach and easy adjustment!!??  Whaaa?  I see no exiting plug wires, but are they hidden on the other side?
If that's really the dizzy, I have lost all respect for the Guzzi engineers -- they're like the 60s-80s American car designers who NEVER worked on the actual cars that they designed, resulting in impossible access to high maintenance items such as plugs, starters, etc!
2.  Also, what is this a finned piece behind the right side cover?  It looks like a rectifier.
3.  Lastly, in my notes from 5 years ago and previous notes from the previous owner from back in 2007, there is a hand written annotation that a "Dyne" was installed (spelled like that).  IF THIS IS referring to a Dyna ignition, WHERE would I find this box?
4.  No, another "lastly":  how in the world do I remove the air filter element without removing the gas tank?
Thanks.
Offline redrider90
« Reply #11 on: September 22, 2025, 12:41:54 AM »
OK that is the Dizzy. If it you a Dyna III electronic ignition in it then you have a points Dizzy that has the points removed from it and replaced it the Dyna pick up unit. The Moto Plat Dizzys could not used to accept the Dyna. There should be a single CDI unit tucked in behind the rectifier sitting in front of the battery. At least that is where I put mine. Dyna has 3 ohm (green) and 5 ohm (black coils). I managed to fit mine in the stock coils placement. I found 2 types of experiences with Dnya. those who never had any trouble out of them and then those like me who have had trouble with failures. I have had one module failure and 2 coil failures. If you do have a failure you can return them to Dyna for testing and even if out of warranty they will charge a lower cost for replacement.
As replacement of air filter ( I run high flow K&N the fits in the stock box) you have to remover the battery to get at the rear of the box that has 2 long screws holding the back plate on the box and replace it from there.
Red 90 Mille GT
Offline paulbricey
« Reply #12 on: September 22, 2025, 04:13:22 AM »
"I have spent an unnecessarily inordinate amount of time going thru digital workshop manuals on other Guzzi models that I downloaded, searching for just basic pics of the engine with component labels -- of which there are NONE"
TBH the Parts Lists are a lot more useful when looking for components & assembly sequences/locations.
Riding to live
Offline John Croucher
« Reply #13 on: September 22, 2025, 08:33:09 AM »
Pull the mixture screws and spray carb cleaner in a couple of shots.  A lean mixture can cause backfire when off throttle.  Slightly dirty can lean out mixture.
Offline wirespokes
« Reply #14 on: September 22, 2025, 05:48:28 PM »
Sounds like you have a Dyna. They're known to act up if there's the slightest amount of corrosion on the boards.
The distributor may look like it's in an awful place, but where else can it go? The engine was actually designed many years before the V7 in 1967, in which it was first debuted, for a military vehicle, and possibly a fiat. it's actually not that hard to deal with. First, remove the tank. The two slotted cover screws allow access, and the cover can be removed turning it a certain way. You'll need to remove the dyna board to access the reverse side that grounds to the distributor body. A pencil eraser works to clean it up. Nothing abrasive!
That could handle the problem.
Since the low speed jets aren't gunked up (evidence, runs fine low end)I wouldn't expect it of the midrange. If working on the Dyna doesn't get it, then ensuring all electrical leads to the coils and ignition are bright and shiny would be my next step.
But my best guess is the Dyna.
