Author Topic: Mounting Voltmeter - 2003 EV  (Read 7952 times)
Offline SemperVee
  • USMC Retired
« on: September 17, 2025, 05:41:14 PM »
If you were to install a round digital volt meter & cell charging port up off the HB risers as fashioned  - where would you recommend tapping into access switched power and ground? Inquiring minds need to know?  Thanks. . .  Thinking off the blinker connection or heated grips maybe?
« Last Edit: September 17, 2025, 06:14:23 PM by SemperVee »
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
Re: Mounting EV voltmeter
« Reply #1 on: September 17, 2025, 06:12:07 PM »
I'm guessing a 98 EV, actually it doesn't make much difference
https://www.thisoldtractor.com/guzzi007/schematics/2004_EV_Catalytic.gif
Electrically you want the connection as close to the battery as possible to avoid any Voltage drop.
i would even consider adding a small 12 Volt relay to feed the meter direct from battery
the relay coil can be from anywhere on the ignition circuit as the coil can handle some loss in Voltage.
On later models like my 2017 V7III I connect the Voltmeter across the small running light in the headlight bucket, that circuit only has a small load on it
As for mounting the meter bracket, look at the Bar clamp you might find the two halves are separated by a small gap.
I use a bracket from 18 Gauge Aluminium sheet, it fits nicely in the gap, loosen the clamp insert the bracket then tighten the two front bolts to clamp the bracket the two rear bolts are tightened last to clamp the bars.
you might want to put the bracket behind the bars if you have more room to clear the tank.
Use a step drill to make the hole in the bracket.
« Last Edit: September 17, 2025, 06:43:08 PM by Kiwi_Roy »
Offline SemperVee
  • USMC Retired
« Reply #2 on: September 17, 2025, 06:13:25 PM »
Hi Roy,  My mistake; 2003 EV
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
Offline 73 sport
Re: Mounting Voltmeter - 2003 EV
« Reply #3 on: September 17, 2025, 06:55:47 PM »
      Wiring on Italian bikes is usually under capacity. I would run a 14ga , preferably 12ga, to the battery with a fuse in the line.
Offline nc43bsa
« Reply #4 on: September 17, 2025, 07:28:40 PM »
I think that's a little overboard for a USB port.
1990 MilleGT
Offline SemperVee
  • USMC Retired
« Reply #5 on: September 18, 2025, 12:29:58 AM »
I like your idea Roy of using the headlight bucket and tapping the small switched wire to running headlight and either adding a relay or perhaps a small inline fuse but the draw fom the digital meter is very light and only 5 watts for the cell phone if needed.  You can see I already have a bracket mated to the volt meter. Thanks!
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
« Reply #6 on: September 18, 2025, 07:50:03 AM »
I wired mine on my 2004 EV into the 'city bulb' in the headlight bucket. Easy to do and switched with the key.
The advantage, or disadvantage, is that there IS a voltage drop due to all of the loads on that line. It reads a few tenths of a volt low. Not a problem. One day it started reading a good bit low. It turns out there was a problem with the relay in that circuit, and the voltage drop pointed it out.
Sometimes it is good to test the entire system and not directly connect to the battery where you may not see problems cropping up.
Offline SemperVee
  • USMC Retired
« Reply #7 on: September 18, 2025, 09:48:48 AM »
Wayne,  might you have a picture to show your handiwork with the connections?  Thanks.
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
Offline John Croucher
« Reply #8 on: September 18, 2025, 10:56:51 AM »
I have the same type, but with on/off switch.  Wired directly to battery.
« Reply #9 on: September 19, 2025, 08:36:32 AM »
No. It is just the little bulb below the main headlight bulb. Pull the headlight shell and it is obvious.
« Reply #10 on: September 19, 2025, 03:49:15 PM »
As Wayne says, this is how I wired my V7iii Special
I see 12.5 after the bike has been sitting for a week and up to 14.1 at speed.
Offline SemperVee
  • USMC Retired
« Reply #11 on: September 20, 2025, 01:40:13 PM »
While the volt meter is better right off the battery I don't get too concerned with that and usually tap the wiring anywhere convenient that is on keyed power. Honestly I don't care about the exact voltage I want to see how the voltage is reacting. Constant, falling or rising. I mainly use the volt meter to monitor the batteries state of charge when running heated gear on bikes that do not have a lot of additional electrical capacity.
Most bikes will keep up with the additional electrical load at speed but fall short at low speed and/or idling. I can watch the volt meter and if it starts dropping below what is normally displayed I toggle off the heated gear and watch the charging system replenish the battery.
That makes a lot of sense.  Don't try and confuse us with logic now.... :laugh:
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
Offline SemperVee
  • USMC Retired
« Reply #12 on: September 21, 2025, 04:50:55 PM »
 Clean install. Thanks for the input.
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
