Author Topic: New To Me 2016 Eldorado 1400  (Read 226902 times)
Online TN Mark
Re: New To Me 2016 Eldorado 1400
« Reply #180 on: September 20, 2026, 07:12:34 AM »
I can understand that position but it’s also reality on some bikes. I’ve been a Yuasa AGM battery fan for decades. For this 2016 Eldorado, I’m now quickly turning into a lithium battery affectionado for obvious reasons. Initially, lithium batteries had ‘issues’. The cheap ones for the most part still do. Lithium still mostly comes from China. The differences seem to be the Battery Maintenance System (BMS) and the new lithium configuration called LifeP04.
Voltage drop while cranking below 11 is a real thing.
Also, the earlier 1400’s were prone to a faulty demand sensor. It’s a well documented issue. It’s greatly exasperated by battery voltage drops. Preventing voltage drops may not cover up for a dodgy demand sensor. But a voltage drop under 11 during cranking is likely to magnify the issues of a dodgy demand sensor.
By 2017, Piaggio went to a more robust ride by wire system. Which eliminated the earlier service fault warnings. So, Piaggio fixed their initial 1400 demand sensor issue. They even upgraded the demand sensor for the early 1400’s and gave it a new item number. Also in 2017 Piaggio added a SAS (air induction) system to the 1400 line which brought its own complications. Most owners by now understand the need to remove the SAS system and plug the holes it needed.
I’ve not heard these same issues with the newer bikes like the V85.
« Last Edit: September 21, 2026, 06:31:37 AM by TN Mark »
Online TN Mark
« Reply #181 on: September 21, 2026, 08:11:56 AM »
12 for 12 start ups without a fault message (URGENT SERVICE or SERVICE) since replacing the Yuasa YTX-20 battery with the Antigravity ATX-20-HD and resetting the fault codes.
That’s a record!
Offline jacksonracingcomau
« Reply #182 on: September 21, 2026, 11:15:23 PM »
That’s a record!
Unfknbelieveable !
Imagine that in 1921 with maggy , points and primitive carby
Yep, they worked 12 out of 12 too
It’s the 13th start that can catch you out !
Online TN Mark
« Reply #183 on: September 22, 2026, 08:55:27 AM »
Starts 13, 14 and even 15 went off without a hitch. Yea, I know, the 16th time will be 'the one'.
Did Piaggio install a batch of dodgy Demand Sensors in their 2013 to 2016 1400 series bikes? Yes
Did some Demand Sensors get replaced due to the voltage drop of the original Lead Acid/AGM battery? Very likely.
Will my Demand Sensor someday 'go bad'? Quite possibly. I'm glad to have a new one on the shelf to use as needed.
At least an URGENT SERVICE or a SERVICE message, if they return, don't render the bike unuseable.
Offline DoubleGuzzi
« Reply #184 on: September 22, 2026, 09:08:23 AM »
TN Mark: a realist.
 :clock:
Nearly natural progression..
Offline 2Nr
« Reply #185 on: September 28, 2026, 11:43:07 AM »
It's experiences like yours and a couple others that make me scared to get rid of my california and pick up a V85 or newer california.  There is no reason for the electronics to be this sensitive.
Electronics are always this sensitive, everything is reliant upon a good stable voltage, unfortunately battery construction has been a bit dodgy lately and  plates tend to short out as they are made much thinner than decades previous, this causes weak cranking and unreliable electronics, as a technician, I have seen many intermittant fault codes created by bad batteries or even battery connections. Time will prove out the theory, here's hoping that it works!
2016 Eldorado
2007 Breva 750
2012 CanAm Spyder Rs
Online michaell32
« Reply #186 on: September 28, 2026, 04:43:10 PM »
I'd have to disagree that they are always this sensitive. On my dr650 the regulator came unplugged and the battery voltage dropped so low the bike wouldn't run. I plugged it back in and push started it. It ran fine the whole way home and that battery is still in the bike today. On my California the Odyssey battery was on its way out after 7 or 8 years. The bike barely started 200 miles away from home but it got me home with no issues. Even in my GSXR days I never had a weak battery cause a check engine light while it was running nor any car I have owned.
2003 California EV
2018 Suzuki DR650
78 Honda GL1000
Offline 2Nr
« Reply #187 on: September 30, 2026, 03:42:14 PM »
 Oh yeah, a DR650 doesn't use fuel injection or cop spark, both use voltage to change where a good old carb uses none of that! GSXR, same kind of situation, the Cali 1400 when fuel injected makes voltage demands even when sitting. When I say electrical, I meant electrically controlled, any fuel infected, overly computer controlled ignition type engine and the Cali 1400 is a prime example. As a mechanic I have seen many cars, trucks and motorcycles with cel lights that were only due to low voltage.
Stephen
2016 Eldorado
2007 Breva 750
Online michaell32
« Reply #188 on: September 30, 2026, 05:10:38 PM »
Stephen
All of my GSXRs were fuel injected. I was an auto mechanic as well before I went to work on conveyor belts.
2003 California EV
2018 Suzuki DR650
78 Honda GL1000
Online TN Mark
« Reply #189 on: October 01, 2026, 08:19:49 PM »
The world's most enhanced 2016 Moto Guzzi Eldorado reached another milestone yesterday. I located and bought a used all leather tank bag mount, item: 2S000524. These have been NLA for years so I was thrilled to get the used one. Thank you TonyBlaze. Now her (Bella) leather ensemble is complete. Matching Eldorado leather saddlebags, trunk, tank bag and tank bag mount. My wife wiped the mount, the tank bag (new) and the trunk (new) down with Bick 4 Leather Conditioner today. The 'used' tank bag mount looks absolutely brand new.
The tank bag mount even came with the two clear vinyl pieces that go under it to help keep the tank from getting scuffed. Since the two clear pieces are designed as 'single use' items, I'll bring them and the tank bag mount to a local car wrap shop to have a new one piece protective film cut. I'll be sure to get the 'good stuff', 8mils thick and glossy etc. I may even have the shop install the protective film for a 'professional grade' installation.
Pretty exciting stuff for me really. Of course, once I get everything mounted, pictures will be taken and posted.
« Last Edit: October 01, 2026, 11:17:16 PM by TN Mark »
Online Bill W
« Reply #190 on: October 02, 2026, 04:50:56 AM »
Mark
Have you gotten my last two PM's that I sent you? They are not showing up on "My Messages"
Online TN Mark
« Reply #191 on: October 02, 2026, 06:19:35 AM »
Yes sir, I’ve received them.
Thank you, and, I certainly will.
« Last Edit: October 02, 2026, 06:20:49 AM by TN Mark »
Online Moparnut72
« Reply #192 on: October 02, 2026, 09:32:55 AM »
Helicopter tape is made for that type of use. From what I have read it works well and is easily removed.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online TN Mark
« Reply #193 on: October 02, 2026, 09:01:42 PM »
Well, key turn 16 & 17 brought back the dreaded URGENT SERVICE message. So sad. 😞
The Demand Sensor will hopefully get replaced this coming week. I’ll call my local dealer (HBR Powersports) tomorrow to get it scheduled.
Online TN Mark
« Reply #194 on: October 06, 2026, 09:55:51 PM »
I followed another GTM suggestion regarding the stainless high hat and flanged acorn nuts. I replaced my OEM ugly exhaust nuts with these new ones.
When removing the OEM exhaust nuts, three of the four studs easily came out. I wiped a bit of nickel anti seize on them and snugged them down into each threaded hole. The double nut scenario made it easy.
The left side exhaust didn’t even have an exhaust gasket! No wonder the left side started making noise. Now both sides have a new OEM exhaust gasket and I also added some nickel anti seize to the acorn nut side. Everything was torqued down to 5, 10 and then 14 foot pounds. Yes, I know the spec is higher but these threads were wet with high temp nickel anti seize. I’ll retorque them again after the next couple of heating and cooling cycles.
The exhaust nuts went from embarrassing to attractive. I love this stuff.
The bike goes in tomorrow to get the Demand Sensor replaced.
The stainless high hat and flanged acorn nuts are under Moto Guzzi item number: 2B007821.
« Last Edit: October 06, 2026, 10:06:14 PM by TN Mark »
Online TN Mark
« Reply #195 on: October 08, 2026, 12:57:35 PM »
The world’s most enhanced 2016 Moto Guzzi Eldorado Faith-O-Meter resets today. It runs exactly as it should with its new Demand Sensor. Hopefully the urgent service fault codes and warnings are now behind me.
Like I said, we’re back to square one.
At some point I’ll buy a Windows laptop so I can send GTM the existing fuel map for their modification consideration. The GTM fuel package was sent with a map that includes the full GTM exhaust system. When I have a Windows computer I’ll also open up the airbox lid as per the GTM instructions. Their new fuel map will also take that into consideration.
Realistically, I’ve reached the end of 1400 engine performance mods. And, yes, I’m fine with that.
A shout out to HBR Powersports in Cleveland, TN. They have a new Technician who has never laid eyes on a Moto Guzzi 1400 before replacing my Demand Sensor. He was very meticulous and complete. He did run into an issue when he was done the bike was idling at the 'limp mode' of around 2000 rpm. He immediately got with the Piaggio Technical department and they worked it all out in short order. I am thankful and grateful that HBR Powersports works on my 10 year old Moto Guzzi. I'm thrilled they have a technician who stuck with it to ensure everything was worked out as it should be. All for a 2 hour labor charge.
The dealer Service Manager was beyond impressed with how well the Eldo runs as well. On his test ride he never got out of 2nd gear but his impressions were how powerful and perfectly balanced the bike is. The dealer is only a few years into Moto Guzzi so my 1400 is their only frame of reference.
« Last Edit: October 08, 2026, 04:20:33 PM by TN Mark »
Online TN Mark
« Reply #196 on: October 12, 2026, 01:05:11 PM »
The latest in a line of continuous Eldorado upgrades is the oem meep meep horn set. I'm installing a set of Hella Strong Tone S92 horns.
At 4", they fit nicely in the same place as the oem small meep meep horn set. I had to drill another hole in the brackets that came with the Hella set to make the mounts the same length (shorter) as the oem horn set. If I installed them as is with the Hella mounts, they would have been too high up and interfere with the front/side bodywork neck surround.
I'm using a separate horn relay and using one set of oem horn wires to control the relay coil with 18 gauge red and black wire. The oem blue wire going to the horn is the 12VDC positive signal and the white is ground. Then, a 12 gauge fused link (15A) to the relay and a set of red and black 14 gauge wires from the Neg battery post and from the relay to the horns. It should look 'factory' and far outperform the oem meep meep horns.
Pro Tip: Use color coded marine grade heat shrink with adhesive on all wire to connector connections. It looks better than factory connections and will help over time keeping water out of the connection as well as stabilize the vibration at the connections.
Here’s a picture of where I’m mounting the horn relay. That plastic ‘rail’ under the right side cover with the black box is the factory USB port kit. I ran an updated (marine grade) USB cable to the handlebar.
The horn relay is too tall to mount on the top of the USB rail.
« Last Edit: October 12, 2026, 01:17:06 PM by TN Mark »
Online TN Mark
« Reply #197 on: October 18, 2026, 08:16:34 PM »
I finally got the new horns installed. Then I went for a ride to fill the tank and get a few stainless hardware items from Ace Hardware.
The Eldo won’t run past 4000 rpm. A telltale sign I pinched a plug wire when reinstalling the outer valve covers.
Crap. I have a full set of new plug wires so I’ll investigate which one I pinched and go from there.
But not yet, my left knee just can’t take it at this point.
I’ll post which plug wires I messed up when I find it.
Online blu guzz
  • Loves to ride
« Reply #198 on: October 19, 2026, 06:39:40 AM »
When mine would not rung past 4000 rpms, it was in what was considered "limp mode".  If that info helps any.
Blue Guzz
Online TN Mark
« Reply #199 on: October 19, 2026, 07:25:49 AM »
I’ll connect the GTM tuning tool to see if there are any fault codes.
Online Bill W
« Reply #200 on: October 19, 2026, 12:14:47 PM »
Mark
If it turns out to be wire caps than here is some good info for aftermarket replacement ( if factory ones are not available ).
https://www.guzzitech.com/forums/threads/ngk-sb05e-plug-cap-replacement.26712/#post-222865
Online TN Mark
« Reply #201 on: October 19, 2026, 01:59:02 PM »
Thank you Bill.
I have a new full set of OEM plug wires. Just about everything I’ve read about the OEM plug wires is they typically break when being removed from the plug itself.
The aftermarket options don’t seal out water or debris from filling the plug tunnel in the head. The crazy thing is the OEM plug wires are $64 a piece, x4 for a set.
I’ll be sure to use a liberal amount of dielectric grease on the new wires. I’m hoping by removing and reinstalling the outer valve cover will rectify the situation.
I never did remove a plug wire from a spark plug.
« Last Edit: October 19, 2026, 02:14:07 PM by TN Mark »
Online TN Mark
« Reply #202 on: October 26, 2026, 09:15:26 PM »
The 3800 rpm limp mode ended up being a spark plug wire and operator error. When I last put the tank on, I pushed the right center plug wire off the coil. I noticed it right away when I lifted the tank to check things out. I reinstalled the plug wire and the bike has run perfectly ever since.
Early in October I posted I found the all leather tank bag mount. I was quite happy to have found one. Today, I had the top of the tank wrapped with an 8 mil high gloss PPF. I removed the gas cap surround as well as the neck covers to make it easier on the wrap crew. The result is simply stellar. I couldn’t be happier with the job they did. It also comes with a 10 year, yes, a 10 year guarantee. Well done Phantom Films in Chattanooga, TN. Well done indeed. I’ll reinstall the trim pieces as well as the tank mount in a few days.
« Last Edit: October 27, 2026, 09:17:29 AM by TN Mark »
Online blu guzz
  • Loves to ride
« Reply #203 on: October 27, 2026, 06:53:51 AM »
You're making me miss my old black beauty. I got it at 18,000 miles and it crashed at 33,500 and was mechanically faultless the entire time.
You seem to have solved the problem of their being very few upgrades for the bike. I wanted the Touring Screen and lowers but they were unavailable and no longer produced when I was looking.
I miss it some days, but not the heft of it. Enjoy it for as long as you can, they really are unique.
Blue Guzz
Online TN Mark
« Reply #204 on: October 27, 2026, 07:13:47 AM »
Thank you blu guzz. The upgrades the bike had when I bought it were quite significant. More than I could do, or afford, today for sure.
I’ve mostly been doing modifications. I’m very glad to have the new Demand Sensor installed and working so well.
If you get to Chattanooga, TN you’re welcome to take Bella for a ride.
« Last Edit: October 27, 2026, 09:18:46 AM by TN Mark »
Online TN Mark
« Reply #205 on: October 28, 2026, 07:35:28 AM »
In the Eldo Won't Start thread, Bill W brought to our attention the possible poor o-ring in the head oil vent. If Piaggio didn't use a Vitron o-ring, that could account for the owners who had these leak. Here's a picture Bill W posted of the head oil vent cap:
For the do-it-yourself 1400 owners. These o-rings can be bought on places like McMaster Carr in Vitron, which should last much longer and work better in that high heat cycle environment. They are under McMaster Carr item number: 8683N322. Size is 47mm ID x 2.5mm Wide. A pack of 5 is $9.30. The Moto Guzzi item number for this o-ring is: 880965.
While you're at it, the McMaster Carr Vitron o-ring for the spark plug tube is under their item number: 9263K711. Size is 26mm  ID x 2.5mm Wide. A pack of 10 is $6.17. The Moto Guzzi item number for this o-ring is: 873626.
Yes, I ordered a pack of each from McMaster Carr last night. Both of these Vitron options may outlast the oem Guzzi item.
« Last Edit: October 29, 2026, 01:20:48 PM by TN Mark »
Online TN Mark
« Reply #206 on: October 29, 2026, 11:37:44 AM »
I updated the McMaster Carr Vitron o-ring part numbers. Mine came in today and they're correct.
Offline groundhog105
« Reply #207 on: October 29, 2026, 01:59:21 PM »
blu guzz, no, the tires are new as of last year, whew. Nice Avon white walls.
The seller has added just about every Guzzi accessory an Eldorado rider would want: comfort gel seats, rider and passenger, 21” windshield, windshield ‘winglets’, driving lights, heavy duty Eldorado luggage rack, full GTM exhaust system, full GTM fueling system, Matris rear shocks, Matris fork internals  plus a several other items he wanted.
If I can find the accessory heated grips I’ll add them as well.
Wow,  you got a very nicely set up 1400.  You’re going to love the handling and fueling.  I had a 1400 custom that I put 35,00 miles on including the 4 corners of the US tour that was set up like that.
Online TN Mark
« Reply #208 on: November 07, 2026, 10:34:29 PM »
Update to my new Demand Sensor:
Since having the Demand Sensor replaced the bike has performed perfectly. No fault codes and no URGENT SERVICE messages.
The bike has been a delight ride and I'm starting to trust it again. The more I ride it the more I love riding it.
As mentioned previously, I made an error in replacing the tank after wiring in new horns with a horn relay. I knocked off the right side center spark plug wire from the coil and the bike placed itself into Limp Mode. I found my error, plugged in the spark plug wire and 'perfecto' running was restored. This was an operator error, no fault of the bike.
Online TN Mark
« Reply #209 on: November 07, 2026, 10:43:37 PM »
So, what's next for the world's most enhanced 2016 Moto Guzzi Eldorado:
I need to install the leather tank bag mount, the leather tank bag and the leather trunk. Take some pictures of Bella in her full leather ensemble and post them.
I'll leave the leather tank bag mount installed. But not the tank bag or the trunk. I actually prefer using an Ortlieb waterproof duffle bag (thanks Aerostitch) to a trunk on trips anyway. ROK Straps have been my item of choice when needed for many years.
