Author Topic: Are there sync rings in the gearbox?  (Read 9761 times)
Offline JesperN
« on: October 04, 2025, 06:49:07 AM »
Hi. I have a heavily modified Lemans 4 that has approx. 140 000 km by now. The gearbox is awful. I shimmed the selector drum last winter. Didn't help much. Nothing inside looks bad or worn down. But the synchronization between the higher gear is bad. I have changed all the bearings. But are there anything in the gearbox that functions as sync rings? Never thought about this before.
Another thought is that the selector drum and possibly the forks are worn. Is this a common issue on high mileage Guzzis?
Sincerely Jesper
« Last Edit: October 04, 2025, 06:50:36 AM by JesperN »
Online n3303j
  • Ron Cichowski
Re: Are there sync rings in the gearbox?
« Reply #1 on: October 04, 2025, 09:09:56 AM »
All gears are in constant mesh. Synch rings are for engaging mating gears. These gears are always engaged. Shifting only determines which gear is locked to the output shaft. Crude but effective drive dogs there CLUNK and you are rolling. With practice it can become click if you are not in a rush.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline wirespokes
« Reply #2 on: October 04, 2025, 08:46:17 PM »
  Here's a good YouTube on the old five speeds:
https://www.youtube.com/watch?v=c1WIjtceX-A&t=1134s
It might even be able to contact him with your questions if you can figure it out from the turtorial.
Offline JesperN
« Reply #3 on: October 05, 2025, 08:12:06 AM »
Thanks. Have seen it. Was very useful when i opened the gearbox last winter.
Regards Jesper
« Reply #4 on: October 05, 2025, 08:45:24 AM »
There are shifting dogs that get rounded off and at higher rpm's won't mesh to allow gear engagement.
« Last Edit: October 05, 2025, 03:15:29 PM by guzzisteve »
