Author Topic: Round head fueling.FIXED!  (Read 16444 times)
Offline GuzziNZ
« on: October 07, 2025, 03:46:26 AM »
What would cause a surge/stutter under load and full throttle from 4 to 5000rpm in a 850T?
From 5k on its clean all the way up to redline.
Starts with one tap on button and smooth idle and town running.
Bike had been running great, removed carbs when I had crank balanced and problem started after fitting.
Excellent compression and have changed complete ignition system.
VHB30. Standard Jets, needle at second notch, 10g floats set a 24mm. New red tip float needles.
Choke plungers have depressions marks in rubbers but no signs of over fueling
« Last Edit: November 02, 2025, 01:45:34 AM by GuzziNZ »
Online moto
  • Fear the deer!
Re: Round head fueling
« Reply #1 on: October 07, 2025, 07:21:21 AM »
Surge and stutter seem like two different things to me. Can you describe the symptom in more detail?
850 T-3
Griso 1100 corretto
Offline wirespokes
« Reply #2 on: October 07, 2025, 10:46:20 AM »
The question I have is what was done before the symptoms arrived? It was running great, then the engine was torn down to the crank, rebuilt, and at the same time the carbs were overhauled. That's quite a lot to think with. Even though nothing but the crank balance was changed, in a way, everything was. So forget about finding what was changed by looking back and fixing it, since everything was.
It's highly unlikely the problem is electrical, most likely carburetion. Something in mid-range jetting I'd guess.
Offline GuzziNZ
« Reply #3 on: October 07, 2025, 12:21:51 PM »
Is more like a stutter or goes fluffy if you want to be technical!
Borrowed a dyna system to rule out ignition and dialed up the cam timing again.
Had a closer look at the choke plunger,s and they are not that good. Have turned seals over and will give it another go.
Offline GuzziNZ
« Reply #4 on: October 08, 2025, 01:51:38 AM »
Still no good. Only thing I am noticing apart from not wanting to rev is to get the best idle the RH mixture screw is only one turn out. Book says 2-2 1/2. LH is 2 out as per the book.
Also the exhaust gas out of the RH muffler is warmer!
« Reply #5 on: October 08, 2025, 07:21:47 AM »
To find out what your carbs are doing check throttle settings not RPM. 1/8, 1/4, 1/2, 3/4, and pegged wide open. You also must hold it at those settings w/o moving the grip for 2-3 miles then cut ignition w/o changing the grip  position. Start with new plugs.
When you change pilot jet to a bigger size your idle mixture screw will be less turns out. This is all depending on what intake & exhaust flow you have.
Mark your throttle w/masking tape and lines on tape so you know where you are at not RPM
While riding and issue happens look and see where you throttle is, now you can fix the effected area.
A 50 pilot will be in the range in book for mix screws, a 60 will be 1 1/2 turns out down to 1.
« Last Edit: October 08, 2025, 12:56:29 PM by guzzisteve »
Offline TOMB
« Reply #6 on: October 08, 2025, 12:40:10 PM »
Don't overlook the fact that you could have put the idle jet and the main jet in the wrong location They both will screw into the locations.They could
You wouldn't be the first one that put him in the wrong location
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Online moto
  • Fear the deer!
« Reply #7 on: October 08, 2025, 01:03:31 PM »
If your problem is really at wide open throttle, no carburetor jets are involved except the main jet and the tip of the jet needle as it sits inside it. Idle jets, etc., mean nothing at full throttle.
You probably didn't completely change your ignition when you reverted back to the Dyna. Maybe you have a bad spark plug gap, or a bad spark plug, or two of each. Maybe you have bad coil wires or coils. Your problem is occurring at the highest load situation for your motor, that is, where it makes the most torque. This is where sparks have the most trouble being propagated and spreading through your mixture.
850 T-3
Griso 1100 corretto
Online moto
  • Fear the deer!
« Reply #8 on: October 08, 2025, 02:01:11 PM »
I need to emend this. It is only the main jet that is governing the mixture at full throttle. The jet needle tip is sitting inside the needle jet, but its tapered end is small enough so that the annular area between it and the needle jet exceeds the area of the main jet. This means the main jet is what governs the amount of fuel that goes into the mixture. That was my main point.
850 T-3
Griso 1100 corretto
« Reply #9 on: October 08, 2025, 04:35:38 PM »
There is one thing it may be, maybe accell pump. It is in between the main and the tip of the needle. Maybe it needs that enrichment to work w/o issue
It continues to squirt till the needle clears the plate w/holes. Could be spring is broke then check ball does nill.
Trying to think outside the box , which this is way out.
« Last Edit: October 08, 2025, 04:37:01 PM by guzzisteve »
Online Dukedesmo
« Reply #10 on: October 09, 2025, 02:51:09 AM »
I had a stutter/splutter on my LM2 that would occur only at or near to full throttle, it just appeared from nowhere after previously running fine.
Turns out there was a small amount of grit/rust in the float bowls, presumably came from the tank? It seemed that it mainly sat harmlessly in the bottom of the float bowl until, there was enough 'suction' (at full throttle) to lift it up and partially block the jet.
May not be the issue here as it sounds like the OP's carbs have been off and cleaned but don't discount it as mine had recently been overhauled and I think some loose crud had just been dislodged from the tank, maybe because of removal and shaking it about?
This was a few years back and I've been meaning to fit a proper in-line fuel filter (the small screens in the taps obviously aren't very effective) but I'll admit that I've not got around to it yet as the problem's not re-occurred so; out of sight, out of mind.
Le Mans II
Ducati 916
Ducati M900
Offline jacksonracingcomau
« Reply #11 on: October 09, 2025, 08:38:01 AM »
No need for wild imaginative theories IMHO
All clues are in this first post.
The only thing to ascertain is what exactly was changed during this process
Undo that and logic says bike will be running “great” as it was before
Only the OP knows exactly what was changed, complete ignition system only ?
Revert to the one that worked
Online moto
  • Fear the deer!
« Reply #12 on: October 09, 2025, 05:05:44 PM »
Did you re-gap your new spark plugs? The new plugs will have a gap of about .035 inch, while the spec is about .023 inches. If the ignition is trying to fire across a gap that is too large a problem will first appear at high load in the cylinders, as I said before. Sorry I didn't think to suggest the gap before. Probably you reset it.
850 T-3
Griso 1100 corretto
Offline GuzziNZ
« Reply #13 on: October 09, 2025, 10:17:56 PM »
Thanks for all the suggestions.
So just to clarify, plugs were replaced and gapped correctly.
Points were swapped out to Dyna and both coils changed although all coils ohm tested to spec.
Even tried it with mufflers removed and this had a slight effect of lowering the stutter in the rev range.
After testing again it really doesn't ever clear properly from 4 to redline under full throttle
On thinking back I may have felt this issue slightly as I was running in the motor but never really gave it full throttle under high load
I will try some bigger mains and see if I get a change and found access to a rolling road if all else fails.
« Reply #14 on: October 10, 2025, 12:12:09 AM »
Try it without air filters. I had one that ran great except at those same conditions. It turned out that it was the air filters being too short.  The length from the end of the carb to the end of the air filter should be 2.5 times the diameter of the carb inlet. I got by with 2 times the diameter because there wasn’t enough room to go longer. It probably wouldn’t affect a standard engine but this one was tweaked.
Offline GuzziNZ
« Reply #15 on: October 10, 2025, 02:23:34 AM »
Will try that also John A but it is running the big K&N oval with duel connection.
« Reply #16 on: October 10, 2025, 01:00:30 PM »
An interesting thing I found was when I was testing without filters on I reached down to feel the air flow expecting flow. At wide open the intake air was puffing in and out and it was slightly warm. I had expected some suction.
Online moto
  • Fear the deer!
« Reply #17 on: October 10, 2025, 02:36:58 PM »
I suppose you were running a hot cam with a lot of overlap? If so, some of the exhaust has a chance to flow back through the intake port during the overlap. It becomes unimportant at high RPM, of course. Interesting observation.
850 T-3
Griso 1100 corretto
Online Moparnut72
« Reply #18 on: October 11, 2025, 08:38:12 AM »
If you are getting that much back flow, can't think of the correct term, at the carbs and the engine has been disassembled I would check the cam timing.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #19 on: October 11, 2025, 09:00:41 AM »
The jetting I had in my 850T and Dunstals, K&N ovals, was 60 pilot, 150 main. Can't remember if I raised needle a notch, was 1977.
« Reply #20 on: October 11, 2025, 09:54:28 PM »
Yeah, that one was tweaked as well. It was a Cal2 , sometime last century. It would bury the tach easily on a third gear pass if I didn’t watch it. It surprised me the first time it happened so did it a few times before I checked it. Steel pushrods, timing gears and all that stuff, didn’t hurt a thing . I don’t remember what cam and don’t remember what I timed it at but I generally go with two degrees intake advance
Edit: I’m starting to remember, I was running velocity stacks on PHF 36’s and put a thin foam over the ends of them and it ran terrible at WOT but great everywhere else.
« Last Edit: October 11, 2025, 09:59:37 PM by John A »
Offline turboguzzi
« Reply #21 on: October 12, 2025, 01:32:26 AM »
many good tips, will just add one since im a total newbie here (but lurker with 45 years experience :) )
Often ignition issues seem carb issues. My first suspect in your case would be the swap to dyna.
Maybe go back to points just to eliminate one new variable you introduced?
Offline GuzziNZ
« Reply #22 on: October 12, 2025, 06:30:55 AM »
Hi turboguzzi,
I had points but changed to a borrowed Dyna but had no improvement.
Offline GuzziNZ
« Reply #23 on: October 12, 2025, 06:35:14 AM »
Now that's interesting. Seems like a big jump from 50 pilot and 142 main but I am starting to think its leaning out.
Hope to get it on a rolling road soon.
Offline turboguzzi
« Reply #24 on: October 12, 2025, 10:46:14 AM »
Hi turboguzzi,
both the points and dyna use the same advance mech under the plate.... have you checked it?
Have you checked with a strobe light that you do get full advance? (with any of the ignitions)
strobe gun costs all of 20$, important tool
Offline GuzziNZ
« Reply #25 on: October 12, 2025, 01:06:51 PM »
Yep, using a good Hella Optilux timing light and both sides are advancing to 34 degs
Offline GuzziNZ
Re: Round head fueling.FIXED!
« Reply #26 on: November 02, 2025, 01:52:29 AM »
So the jetting for this American market bike doesn't work in NZ. Tried going up to a 150 main from stock 142 and that really mucked it up. So a big drop the other way to 130 and Zoom Zoom.
Maybe could even go smaller but will try this out for awhile.
« Reply #27 on: November 02, 2025, 06:31:52 AM »
Glad you figured it out
Offline Gliderjohn
« Reply #28 on: November 02, 2025, 07:42:41 AM »
My T-3 has the big bore kit, 36mm round slides, V-7 Sport cam, low restrictive air filters and exhausts, and port and polishing of heads. I use 130 mains and 54 idle. The rod is on the second notch but don't remember which rod. Runs great with this combination.
Back in central KS
Online moto
  • Fear the deer!
« Reply #29 on: November 02, 2025, 10:30:44 AM »
The T is like a T3 without an air filter. Same compression ratio (9.5), same lawn mower cam (inlet 20/52, exhaust 52/20), same carburetors (VHB 30).The full advance ignition timing spec is 34 instead of the T3's 33. Since you have added an air filter, the 120 main jet spec for the T3 is a good place to start.
My own T3 is stock except for the oval shaped dual K&N filter. After not being able to see any improvement with 125 mains I went back to the stock 120s.
To calculate ratios of fuel flow between two jets you  square the ratio of the Dellorto sizes. Ratios compared to 120s for various jets are: 125 = (125/120)^2 = 1.0851; 130 = (130/120)^2 = 1.174; 142 = 1.400; 150 = 1.563. So respectively 9, 17, 40 and 56 percent more flow than the stock 120 jet of the T3.
(The simple formula just applied is correct; pesky pi cancels out.)
Congratulations on your success!
« Last Edit: November 02, 2025, 12:20:40 PM by moto »
850 T-3
Griso 1100 corretto
