Profanity…?
You're gonna get struck down by a thunderbolt, Huzo! I know, it's strange what upsets 'muricans yet other phrases/words are acceptable. It sucks.
Sure is…I’ve gone over every word of my post and if someone can highlight where the profanity is, I’ll own it.
Goddammit, Huzo! Don't ya geddit?
C'mon moto, we need an update on how you got on with the silencer fitting.
Do some creative engineering with about twenty aluminum beer can walls ...
Here is my final update, after putting things aside for a while. I sanded the pipe, inside and out, cut off a 25mm spacer, cut a slot in it, and put (high-temperature) RTV rubber in the resulting gap. Thanks to all with suggestions, even of using aluminum foil. I've done that too.
Here is my final update, after putting things aside for a while. I sanded the pipe, inside and out, cut off a 25mm spacer, cut a slot in it, and put (high-temperature) RTV rubber in the resulting gap. The 1/8" flat brackets needed washers:The mufflers came out pretty even:They look good:The mounting is as solid as OEM, and the sound is surprisingly strong. If I ever run into a nice set of original V50 mufflers I can install them easily since I didn't modify the bike at all. Thanks to all with suggestions, even of using aluminum foil. I've done that too.
