Author Topic: NorgeGT clutch replacement.  (Read 52194 times)
Offline theoneandonlymin
Re: NorgeGT clutch replacement.
« Reply #30 on: January 09, 2026, 08:05:14 AM »
 The springs are nothing to do with the lever in or out. But was quieter with the lever in.
The 1200 8v engines have a single plate.
« Last Edit: January 09, 2026, 09:13:03 AM by theoneandonlymin »
« Reply #31 on: January 09, 2026, 10:33:18 AM »
When I pull the clutch lever on my Norge I hear rattling.
It's quiet when I let go the lever.
Is that what you mean by in/out?  In means you let go of the lever?
I read somewhere that the rattling is normal when the lever is pulled.
The plates are free and vibrate against each other.
This is true for a 2V Norge w/2 clutch plates, a 4V has a different set up as shown.
Offline red stripeguz
« Reply #32 on: January 09, 2026, 12:58:49 PM »
My 2 valve 07 Norge most definitely rattles with clutch pulled in when cold. Don't notice it when warm. Glad to hear that's somewhat normal
2023 V7 Special
2007 Norge
« Reply #33 on: January 09, 2026, 01:35:41 PM »
It's still a bit Baltic ( under 4C)  out in my unheated workshop as I reckon it would cause condensation.
I'm not going to heat it just wear plenty of layers. Which means I don't stay too long.
Recieved my Mikalor exhaust clamps today so dry fitted the exhaust. The collector box on these are pretty big and the centre stand sits tight when deployed. Couple of hoses / wires to line up next. Before the rear end goes in. Which I was going to do last week but was even colder and need to be out there for longer.
Had a ride out around N. London on V1000G5 as the overnight rain had washed most of the road salt away and our street wasn't icy.
« Reply #34 on: January 12, 2026, 05:30:08 PM »
A wee bit further on this morning.
Everything greased up nicely.
Offline Bulldog9
« Reply #35 on: January 12, 2026, 05:53:06 PM »
You haven't lived until you hear the ring ring ring of the dual plate clutch on the 4V 1100 Griso......
MGNOC#23231
« Reply #36 on: January 14, 2026, 02:49:56 PM »
Heading in the right direction, getting back into semi familiar territory.
« Reply #37 on: January 18, 2026, 03:46:19 AM »
Popped the front wheel in so now it's off the engine stand and on the main stand. No longer attached to the scaffolding frame and down a notch on the bench height. Think today I'll get the throttle bodies on and start tying in the loose wiring and hoses.
« Reply #38 on: January 18, 2026, 02:41:12 PM »
Good day's work today.
Throttle bodies, starter and associated cables wiring and hoses back to where they were.
« Reply #39 on: January 29, 2026, 12:41:55 PM »
A few more steps further on, just wee jobs and starting to relocate some cabling and some plastic.
Offline Bulldog9
« Reply #40 on: January 30, 2026, 08:49:48 AM »
That's the way my dual plate clutch in the GRiSO 1100 sounds. It's a rattle/ring sound.  My 1200 Sport (70K+ miles 2008 4V) is also dual plate (I believe) but does not make the same noise. My 8V Norge (52K miles 2012) is single plate and is quiet when lever is pulled, and has a chuck chuck noise when released. I've noticed it is worse if the TBs are not well sync'd.
The V7ii Stornello is a whole other story. The pilot bearing squalls occasionally, clucks when lever is released, and chucks when pulled. I generally shift clutchlessly up and down 3-6. The Breva 750 has so much gear whine from the engine and transmission, I can't hear the clutch  :evil: But in fairness, I've only ridden it maybe 500 miles. It is a beautiful soulful little bike, but is too small and underpowered for my likes so it rarely gets ridden.
When I bought my Griso from Dave Richardson, he gave me some sage advice. He said "Guzzi's make weird noises.... and are faintly agricultural...... no two are the same..... If your Guzzi is making weird noises, all is well. You need to start worrying if it is quiet and smooth like a Japanese bike" He said this as I started the GRiSO for the first time, and just after I pulled in the clutch and quickly released when I heard the racket of the dual plate clutch.....
This was SAGE advice.... It has helped me overcome my obsession with eliminating odd noises, keeps me sane, and to embrace each Guzzi as its own, and to accept and incorporate the 'odd' sounds into the personality of each bike. I Do pay attention when the odd noises change, get worse, or better.
MGNOC#23231
« Reply #41 on: March 15, 2026, 12:39:01 PM »
Sorry folks I've been doing other stuff.
Anyway, threw in an extra cable this morning from alternator straight to the battery. Time for the airbox to go in and we're nearly ready to roll.
Well, I'll have to wait for my replacement inlet rubber to arrive from Stein in Germany.
« Reply #42 on: March 22, 2026, 04:10:13 AM »
Rubber arrived, as it has warmed up here in Norf London the rubbers were nice and soft so the airbox floated in nicely.
Tank on, 5 litres of fuel and after a few start attempts the fuel got through and we have action.
Few jobs to finish off and aim to be on the road 1st April. Not going to pay a month's road tax for the last few days of March.
« Last Edit: March 22, 2026, 04:10:50 AM by theoneandonlymin »
« Reply #43 on: March 22, 2026, 12:15:05 PM »
So I had to wait until the engine was running to check my lights.
Both dip earths and wires had signs of a previous owner.
Damn, it's a long way back into the fairing to do anything but repair the previous work.
There's not a lot of extra wire to play with.
In the top photo y'all will see the terminal is missing and has been replaced with a terminal/ earth on the bulb retaining clip.
It was quite a fiddly wee job but got there eventually.
« Reply #44 on: April 07, 2026, 09:25:25 AM »
So, we're rocking again.
First ride out  ABS light came on, hmmmm, then speedo stopped, ah, must be the wheel sensor.Then it started running really bad. Luckily I wasn't far from home.
Quick Internet search...loose battery terminals or not charging.
Sure enough it wasn't charging.
Replaced headlight fuse as it was/ wasn't consistent. As if it was broken not fused.
Cleaned up the rest of the fuses and we're back in business.
50 mile test ride this morning and all is well.
Thanks for all your love.
