I've had this problem more on the 2012 I had than both my 2007's one of which I currently am riding. If it is not a lot then I use 2 round rods, punches, screwdrivers or whatever. Put them on either side of where the bolt goes, slip them into the frame and push the tank forward. On my 2012 it swelled too much for this to work so I took a either a file or dremel, I forget, and ground the hole so it was enlongated and I could put the tank on. There was enough just plastic and not tank to do that in front of the hole.
That is awesome!Do you think a 2 ton bottle jack is up to the job?
I think a 2 ton bottle jack would be adequate if it was red.
