Author Topic: V7III Brake Fluid Change  (Read 5544 times)
« on: October 21, 2025, 11:05:07 PM »
My V7III has done over 35,000 km, I thought it might be time to change the brake fluid
I assume on an ABS bike the best way would be to just pump fluid from the master cylinders thru to the caliper until the fluid turns clear as I would on a car.
Am I right or is there a special procedure when dealing with ABS?
« Last Edit: October 21, 2025, 11:06:26 PM by Kiwi_Roy »
Re: V7III Brake Fluid Change
« Reply #1 on: October 22, 2025, 12:30:54 AM »
As you described will work. The latest version of Guzzidiag should be able to cycle the ABS. Look at the bottom of the list for your ABS system.
