Author Topic: New twist on fuel line removal  (Read 1813 times)
Offline Kaladin
« on: November 07, 2025, 05:36:02 PM »
Taking the fuel line off the gas tank is easy.  Just push in on the line and pull back on the connector.   Except when the dang thing is 15 years old and stuck.   I have this rarely used tool in my tool box, it was designed to pull wires off of spark plugs back in the day.  It works great when trying to pull the connector sleeve back.
First you look where it should be, then you look where it might be, then you look where it won't be, then you look where it mustn't be.  And when you find it you discover "that's where it should have been."
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
Online Tom H
Re: New twist on fuel line removal
« Reply #1 on: November 07, 2025, 05:43:58 PM »
That tool looks like what I use to pull rubber hose off of fittings. I have a set with 3 sizes. Works better than just some type of pliers. Doesn't crush the hose.
Thanks for the tip!
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #2 on: November 07, 2025, 06:46:57 PM »
Also lovingly referred to as ‘earwig’ pliers. By me.
Offline guzziart
« Reply #3 on: November 08, 2025, 07:56:35 AM »
Are they a Harbor Freight item?  Woulda been a good thing to have when I was disconnecting tank lines on my v11 Lemans.  I wonder if the v85 has the same fitting setup, ain't messed with that yet :violent1:
Art
Online Tom H
« Reply #4 on: November 08, 2025, 11:17:35 AM »
The set I bought was from HF.
« Reply #5 on: November 08, 2025, 02:07:40 PM »
Art
Different and easier on V85
Online SIR REAL ED
  • uh.... it's personal....
« Reply #6 on: November 08, 2025, 05:10:18 PM »
I have one of those.  I don't think I have ever used it!
Thanks for the post.
2019 Beta EVO 250
Offline brider
« Reply #7 on: November 10, 2025, 10:24:47 AM »
THAT'S what those pliers are for?! I've had a pair or 2 cluttering up the garage for years and never knew what they were for. Probably got them in a set of multi-use needle-nose but I never knew what their intended application was. Thanks!
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
« Reply #8 on: November 11, 2025, 03:04:43 PM »
im dure for inner plugs on the B1100
I just did the outers, valves, oil/trans/final fluids and brake pads all around
I've been putting off the inner plugs, air filter, and (not blocked, but 'guilty by association') clutch fluid swap because of this little bugger of a connector!  Off to Harbor Freight, if this works we may need to get you a new mega-flair title for this site! GOSLING?!? I say an immediate bump to MENTOR is is order  :boozing:
« Last Edit: November 11, 2025, 03:06:22 PM by Mayor_of_BBQ »
Offline Kaladin
« Reply #9 on: November 12, 2025, 12:52:38 PM »
I'm glad to see that I'm not the only one with a recalcitrant fuel connector.  BTW, I had this tool out and visible because I was planning to use it to pull the spark plug caps off the inner plugs.   As with the Silver Norge, the right side was welded to the spark plug and had to be destructively dismembered.
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
