Author Topic: Darn things are like potato chips  (Read 1774 times)
Offline Perazzimx14
« on: November 19, 2025, 11:13:43 AM »
Another R1200GS but this time its water cooled  :thumb:
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline flower_king001
Re: Darn things are like potato chips
« Reply #1 on: November 19, 2025, 06:36:15 PM »
Out of the 5 bikes I own/ride my 07 /gsa 1200 get's the most saddle time.
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Offline cliffrod
« Reply #2 on: November 19, 2025, 07:22:59 PM »
Go with what you know.  Have fun!
Offline moto-uno
« Reply #3 on: November 22, 2025, 10:57:35 PM »
  Kinda ironic isn't it ? In the back of a pick up truck  :evil: !
Offline Perazzimx14
« Reply #4 on: November 23, 2025, 06:42:51 AM »
I've never been able to figure out how to drive my truck and ride a bike simultaneously.
« Reply #5 on: November 23, 2025, 07:32:04 AM »
Perfect!  Made coffee come out my nose.
« Reply #6 on: November 28, 2025, 02:49:21 PM »
 :grin: :grin: :grin:  Reminds me of one tee that I got Harper's.  "Moto Guzzi are like potato chips.  Can't just have one!"  (para-phrasing)
Offline Perazzimx14
« Reply #7 on: November 29, 2025, 10:34:01 AM »
Well this potato chip has gotten:
- New oil/filer
- New air filter
- New FD oil
- Valves checked
- CPC metal quick connects for the fuel line to replace the OEM plastics units
- Coolant replaced
- Removed front wheel to clean and check wheel bearings and brake pads.
- Added: Grip Puppies, windscreen support bracket, frame plug kit, Amazon top box (the panniers and top case that came with the bike are going back on, or at least not right now) and cockpit cover
- Lots of cleaning and detailing even in places that have not seen the light of day since it was assembled at the factory
- Connected to GS911 and rest service reminder, read and cleared faults + testing components/systems for functionality.
Still to do:
 - Remove swingarm to clean and re-grease the pivot bearing. Most likely does not need it but I like to kill flies with a sledgehammer
 - ESA preload on the rear shock is in fault. Need to remove and dissect to see if it the motor or just bound up. Shock works great just cannot add preload if going 2-up. Since I don't ride 2-up this has not been a priority.
 - New spark plugs. They just showed up yesterday so they'll likely get replaced today/tomorrow
Some nice surprises I didn't expect.
- Bike came with a LED headlight
- Owner left a like new Zumo XT on the bike
- Tires have 75% thread. Not what I'd normally pick but it nice to not have to spend $400 right out of the gate on new rubber. This can now be delayed for several thousand miles
A few pic along the way:
« Last Edit: November 29, 2025, 03:10:47 PM by Perazzimx14 »
Offline Turin
« Reply #8 on: January 09, 2026, 09:21:07 PM »
Tom, I need one of those potato chip shirts.
1985 Sidlow Guzzi
Offline inditx
« Reply #9 on: January 10, 2026, 10:57:42 AM »
What year?
How would you compare the w/c to the air cooled GS?
Much more involved to check/adjust the valves?
inditx
inditx
This is the day.....
Offline Perazzimx14
« Reply #10 on: January 10, 2026, 05:37:38 PM »
What year?
inditx
The one in the pic is a 2013 R1200 GSW
Each generation is more refined than the last.
Checking the valves on the oil/watercooled GS's is as easy as on a 2 valve Guzzi. Remove the valve cover roll the cylinder to TDC on the compression stroke and slide the feeler gauge between the shim and rocker arm.
« Last Edit: January 10, 2026, 05:40:59 PM by Perazzimx14 »
