Author Topic: Audace stumbles on WOT  (Read 20723 times)
Offline toomanybikes
« on: November 25, 2025, 05:51:54 AM »
I've recently experienced some strange and intermittent fueling behavior.
When the tank is relatively low, like three bars or less, the engine will momentarily bog down under sudden heavy throttle, almost like it was running out of gas, but the tank was not empty.  Gradually rolling on the throttle is fine. Filling the tank resolves the problem, but it's not yet clear if it's a fuel level thing or just relieving built up pressure due to clogged vents. The vent tubes all seem to be in place, but I have not yet removed the tank to see what lies beneath.
The bike was a rescue after sitting for unknown years. The tank does not have any sludge in it, but the filter and pump are probably the original.
I'll plan to empty the tank and replace the filter, but should I look for anything else? The pump seems to work fine, except the weird fueling at low levels.
The bike has the stock airbox. I replaced an airbox hackjob by some previous owner. there are no indications of flashes or mods.
It *probably* still has the fuel vapor recovery system in place since I can see the pressure valve attached to the vent tube coming from the fuel opening. It's possible someone messed with that system, given other mods that were done and indications that someone took the tank off previously.
The fuel cap flange spacer is in place with a tiny opening near the vent barb. See pic.
Any suggestions beyond "open the cap perdiocially"? That's one likely easy fix, but I'd rather understand and fix the underlying issue.
« Last Edit: November 25, 2025, 06:10:56 AM by toomanybikes »
Offline Moparnut72
Re: Audace stumbles on WOT
« Reply #1 on: November 25, 2025, 08:41:58 AM »
Having owned an Audace I would check the filter first thing. The evaporative system is pretty benign so I doubt any mod to it will help one way or another. I did mine as recommended by a well known shop owner. It didn't make the slightest improvement in the low gear low rpm surging. During the time I had the bike Beetle wasn't releasing his map for it due to an issue. He has one now.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #2 on: November 25, 2025, 10:06:33 AM »
kk
Thanks. Here's a pic of the pump/filter assembly. Any input on if the hoses can be re-used? I know the oetiker clamps are one and done.
The evap system seems to be in place, tucked in behind the starter motor, with at least the primary hose still connected. A few of the other lines were left unattached, although one is probably for the fuel tank vent line not the evap system.
« Last Edit: November 25, 2025, 10:07:56 AM by toomanybikes »
Offline Moparnut72
« Reply #3 on: November 25, 2025, 11:55:44 AM »
I bought mine kind of used, 500 miles, from a dealer repo'd due to a fraudulent credit ap.  It had originally spent 3 years on the dealer's floor. When it was being checked for me it dropped a valve at least that is what I guess from what I was told happened on a test ride. I had the tank off for another mod and found that the tank vent hose wasn't connected to anything. I think the mechanic who replaced the engine left it this way. I really liked mine but selling it was the start of my downsizing due to age, it was a handful to ride at walking speeds. It was a major mile muncher.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online TN Mark
« Reply #4 on: November 25, 2025, 11:59:35 AM »
Does your tank make the moaning whale sound? If so, you likely found part of your issue. Also, on the riders right hand side of the intake plenum is a vent that goes from the charcoal canister to the intake. That connection can sometimes be less than hand tight. It’s best to remove that and put a bolt in the plenum instead.
If you do an internet search on moaning whale Moto Guzzi 1400 and tip over valve remedy, you will very likely find the solutions to your issues. The Tip Over valve is often a particular source of frustration on the 1400s. I gutted mine recently following the instructions to the T.
Also, if you have the 2016 and earlier firmware in the ECU, that was also quite poor. If going to a dealer is an option to get the latest 2017 firmware downloaded into the ECU that may also work. The ECU on the 1400’s was specifically designed not to receive aftermarket downloads. The last thing you’d want is to brick the ECU.
Also, your fuel filter is the good type. Some of the earlier ones were half metal and half plastic that was sure to deform. If you haven’t yet, pouring a can of Seafoam in the tank and running it through is also a very good idea.
But confirming the mechanical issues are solid is your first coarse of action.
« Last Edit: November 27, 2025, 05:50:22 AM by TN Mark »
« Reply #5 on: November 25, 2025, 12:38:11 PM »
Also, your fuel filter is the hood type. Some of the earlier ones were half metal and half plastic that was sure to deform. If you haven’t yet, pouring a can of Seafoam in the tank and running it through is also a very good idea.
I haven't heard any moaning whales, so I won't go down that thread. The nearest guzzi dealer is 2 hours away via the slab, so I'll leave the ECU alone for now.
I've replaced the filter (see pic, oddly I had the correct one on hand), so will try that and investigate the plenum item you mention.
Online BMCMOTO
« Reply #6 on: November 25, 2025, 01:31:38 PM »
I don't believe that spring clamps are up to the task of a high pressure pump, about 40psi if memory serves. I am willing to be corrected. I always use little rolled edge eared clamps rated for fuel injection.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
« Reply #7 on: November 25, 2025, 03:58:03 PM »
Brian
I've heard varying info on that area and didn't have any oetiker (ear) clamps on hand. Oddly, the local auto parts stores didn't have any on hand and Amazon's were all next day ... except the size I needed (8.8-10.5mm). They guys at the local hose fitting store didn't have any ear clamps that small and thought the green ones would be fine for 40psi. I'll do a test start with a gallon or so of gas.
Online BMCMOTO
« Last Edit: November 25, 2025, 08:18:31 PM by bmc5733946 »
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
« Reply #9 on: November 26, 2025, 06:30:56 AM »
Or here.
https://www.amazon.com/Fuel-Injection-CLAMP-Clamps-30PCS/dp/B07T29HV4L
Brian
I ordered the amazon option to have on hand. I'll keep an eye on the spring clamps. Now that I have experience removing the tank and pump, it will be pretty easy to do a second time if (hopefully not) needed.
Online BMCMOTO
« Reply #10 on: November 26, 2025, 06:37:43 AM »
It's not the pump/filter removal process that irritates me. It's the fuel removal, tank removal, and external line removal that irritate me the most, after all that it's a piece of cake.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
« Reply #11 on: November 26, 2025, 07:21:37 AM »
Brian
Have you ever tried getting the tank out of an '80's Honda GL1100 (Goldwing)? The Audace is a walk in the park.
Online TN Mark
« Reply #12 on: November 26, 2025, 08:06:26 AM »
I thought removing the tank on my Eldorado 1400 was a breeze.
Instead of disconnecting the fuel line at the base of the pump, there’s another disconnect (black connector with square green releases) along the RH frame rail that makes that an easy, low risk endeavor.
Also, removing the top decorative valve covers eases tank removal and minimizes the risk of scratching anything.
I don’t know if I’m allowed to mention the ‘other’ Guzzi forum here or not. They’re a ‘Technical Guzzi’ forum, not a social type forum for shooting the breeze or submitting ride reports etc. That being said, any running, suspension and How To question you may have on a Moto Guzzi is very well covered. Mostly with step by step posts with pictures. I’ve learned a great deal about the 1400s over the years by being a member their.
I highly recommend that site for the Do It Yourself type that wants to learn not only what causes there issue(s), but how and why to properly solve it.
I’m TN Mark over their as well.
« Last Edit: November 26, 2025, 08:35:05 AM by TN Mark »
« Reply #13 on: November 26, 2025, 08:38:43 AM »
Agreed on removing the tank, especially the fuel connector, but I didn't bother with the valve covers.
I'm on the "other site" as well, but am sometimes confused by what types of questions are allowed. Some of my posts, that I thought were reasonable technical questions, have been removed as violating forum rules.
Offline Frulk
« Reply #14 on: November 26, 2025, 09:21:11 AM »
MoparNut….
Remember this bike?
My opinion only. Best looking bike at Broken Arrow that year.
« Last Edit: November 26, 2025, 09:27:38 AM by Frulk »
Offline Moparnut72
« Reply #15 on: November 26, 2025, 10:19:50 AM »
Sure do. I miss that bike a lot. It would eat miles like crazy. It just got too awkward for me. Being 700 lbs with 6.1" of trail and 32* headstock angle did not contribute to confident parking lot handling, u turns were almost terrifying. A younger bigger kind of guy would be the perfect rider. The MGX which is an Audace with fairing, stereo with all the extra weight would be beyond a regular rider's ability. I once started to lift one off the side stand in the dealership, I didn't finish.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online TN Mark
« Reply #16 on: November 26, 2025, 11:08:21 AM »
Of course I admit to being biased but: the Eldorado is the ‘best’ of the 1400 line.
Then the Audace and the standard California. To me, the California Touring bags are way too wide and the front wheel geometry on the MGX-21 didn’t work for me in the showroom.
I’m still bummed the 1400 line was killed in 2020. Though YouTube has no shortage of AI generated videos of the 2025 and 2026 1400 bikes.
Offline Moparnut72
« Reply #17 on: November 26, 2025, 12:45:10 PM »
I test rode an Eldorado and in hind sight I wish I had gotten one of those instead. With the smaller front wheel diameter it probably would have allowed me to ride it longer than the Audace.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline Bill W
« Reply #18 on: November 26, 2025, 04:08:12 PM »
The Eldorado is a beautiful bike but I'll keep my Cali Touring being us old guys have to carry around a lot of everyday survival supplies.
Online TN Mark
« Reply #19 on: November 27, 2025, 05:45:43 AM »
The California Touring is, IMHO, very likely the best value of any 1400. Of course I love the Eldorado but adding things like heated grips, a windshield, the windshield winglets, driving lights, saddlebags and saddlebag brackets is/was very expensive.
I was thrilled that my  Eldorado had so much already done to it.
Full disclosure: the second owner of my Eldorado paid $9,500 for it in late 2021, early 2022. I have his receipts totaling $12,500 for everything he had added to it. I paid him $8,000 for the bike. Plus I also got the OEM items he had replaced like the riders seat for the comfort seat, the OEM fork internals, the OEM shocks, the OEM passenger seat chrome rail and the entire OEM exhaust system with an extra set of OEM mufflers.
IMHO, $8,000 is at the top end of the 1400 pricing level. But, it only had 1,342 original miles on it as well. So, I’m quite pleased with the bike and how things worked out.
One thing I wish is that the GTM doubters and naysayers could ride my Eldorado to see for themselves the complete transformation the GTM fueling system, the GTM exhaust system and the Matris front & rear suspension make to the 1400.
« Last Edit: November 27, 2025, 07:40:06 AM by TN Mark »
Offline Bill W
« Reply #20 on: November 27, 2025, 09:09:04 AM »
You stole the bike for that price along with all the accessories.
I also have Temperamental Todd's fueling kit and I like it a lot.
Online TN Mark
« Reply #21 on: November 27, 2025, 04:27:34 PM »
Are you still running the ‘base’ map or have you gone back to get an adjusted fuel map?
He mentioned a few times recently how few people have called him back for an adjusted fuel map for their specific bike.
Mine is still on the ‘base’ map. It only has a few hundred miles on the GTM fueling system.
I don’t have a Windows based computer and I’m not certain there’s an Apple workaround.
Offline Bill W
« Reply #22 on: November 27, 2025, 06:56:57 PM »
I went through about 6 maps in about 300 miles before I was happy with the bike as it kept backfiring on deceleration. That was three years ago and I have been happy with it until recently when I hooked up the GTM reader and it asked me if I wanted to finish the install ??? I emailed Todd about that and got the usual "Thats covered in the install directions" which it isn't but thats normal reply when dealing with him and his products. To answer your question, I have read of other GTM kit users that have sent their map readings to him for updates, I am leaving mine alone as it seems to be working fine even though it does have a couple of minor ticks that may or may not be related to the re mapping.
Online TN Mark
« Reply #23 on: November 27, 2025, 07:14:54 PM »
Thank you Bill W.
Mine is running the ‘base’ map and it’s fantastic as far as I can tell.
The previous owner who had it installed put under 100 miles on the fueling system, the exhaust and the suspension enhancements. I’ve only put a few hundred miles on it myself.
I have all the cables and the GTM handheld but I’ve not looked into connecting it.
So far, I see no reason to. Plus, I don’t own a Windows based computer.
« Last Edit: November 27, 2025, 07:25:51 PM by TN Mark »
Offline Bill W
« Reply #24 on: November 28, 2025, 05:11:59 AM »
The GTM reader is very simple to hook up and use being its very self explaining. Others have complained about the pad keys not working to which on mine I have to use my finger nail in the very bottom of the screen board to get the "Next" or "Continue" key to work ( I haven't used it since I reset my TPS ) being the screen icons don't seem to be aligned with the buttons under the pad.
« Last Edit: November 28, 2025, 05:18:03 AM by Bill W »
« Reply #25 on: November 28, 2025, 01:09:05 PM »
After all the responses, have you figured out why the low fuel level exacerbates the issue ?
Online TN Mark
« Reply #26 on: November 28, 2025, 03:54:57 PM »
This is what Grok replied with:
Yes, this is a very common symptom and almost always points to one of two issues (or sometimes both at the same time):
1.  Fuel pump is starting to fail / overheating when the tank is low
The electric fuel pump is mounted inside the fuel tank and is cooled and lubricated by the gasoline that surrounds it. When the tank gets down to ¼ or less (your “three bars or less”), there’s not enough fuel left to keep the pump fully submerged and cool.
Under sudden heavy throttle the engine suddenly demands a lot more fuel. A weak or hot pump can’t keep up with the surge, pressure drops for a split second, and the engine bogs or stumbles exactly as you describe. Smooth throttle is fine because the demand rises gradually and the pump can (just barely) keep up.
Filling the tank puts cool fuel back around the pump → problem disappears until the level drops again.
This is the #1 reason people experience exactly what you’re feeling on modern cars (roughly 1996 and newer with in-tank pumps).
2.  Clogged fuel filter or “fuel sock” (pickup screen) in the tank
Less common now because many cars have lifetime filters or the filter is part of the pump assembly, but when the sock gets partially plugged with debris it acts like a straw with a kink: low demand = OK, sudden high demand = it cavitates and starves the pump. Again, more fuel in the tank raises the level above the debris that’s settled on the bottom and temporarily fixes it.
What it almost never is
•  Vapor lock (basically gone on fuel-injected cars)
•  Bad gas (you’d have problems all the time, not just when low)
•  Clogged main injectors (same – constant problem)
What to do
•  Next time it happens, immediately fill the tank halfway and see if the problem instantly goes away. If it does → 99% chance it’s the pump starting to die.
« Reply #27 on: November 30, 2025, 06:36:06 AM »
What to do
Thanks for the useful information. I'd say my faith in AI generated info is restored, but that's a different thread.
After changing the fuel filter, I was able to do a short test yesterday with a tank that was just barely 3bars full (i.e. 2 bars on the side stand, 3 when the bike was vertical). There was no bogging down, but I'd still call the test inconclusive because it was 35degF out and the ride was only 2.5 miles down to the closest gas station for a fill up. The tank is now full and the weather cold, so it will be a while before I can ride it long enough to test the fuel pump. If a warm day comes up, i'll siphon out some gas and re-test.
and as long as we're showing bike pics, here's the Audace in question. Picked it up over the summer as a non-runner project with a bald rear tire. It was easy to get it running again, but there were several things that needed attention after some (likely hack) mechanic had their way with it. Sheared bolts, altered airbox, missing license plate holder, etc.
« Last Edit: November 30, 2025, 06:41:34 AM by toomanybikes »
Online TN Mark
« Reply #28 on: November 30, 2025, 06:47:45 AM »
The Audace is one good looking motorcycle.
You’ve done well to bring it back. It will reward you in kind.
« Reply #29 on: December 16, 2025, 04:21:32 PM »
UPDATE - I've now tested the new filter with the existing pump, at low fuel levels, on a day with reasonable (50F) temps . Unfortunately, the bog at sudden WOT is easily reproduced, so the fuel pump may be the likely culprit.
Which leads to some questions ...
1. Can I replace just the pump unit and not the entire assembly?
2. Do I have to buy a MG pump or is there another manufacturer (MAHLE, Bosch, etc.) that supplies a functional equivalent at a decent price? I'm looking for an automotive supplier, not just the cheapest thing on ebay.
Anything else I should be aware of?
« Last Edit: December 16, 2025, 04:48:43 PM by toomanybikes »
