Author Topic: 1975 850T Survivor Project  (Read 124221 times)
Offline cmice
Re: 1975 850T Survivor Project
« Reply #60 on: April 07, 2026, 07:54:26 PM »
Past few weeks were busy sourcing and cleaning up a seat pan, and getting a custom seat made at Corbin which is about 1.5hrs away from me.  https://www.corbin.com/ridein/index.shtml
You can tell which is the good seat pan, and which is the lost cause.
Metal Prep, then POR15 clear base coat, and then Duplicolor top-coat.
I won the prize for the oldest-foam of the year.  After we discussed what I was looking for, the basic parameters of the seat, it took less than an hour to block out the basic seat shape which we refined from there.  Tweaked the height, the position of the rear butt-stop, the scoop-out of the seat base and how the base transitioned into the sides.  The foam was then completely taped up with masking tape, and we marked out a design (based on a design I liked).  Colors, textures, stitching, piping, bottom turn, logo stitching.  It was really a comprehensive process.  We broke for lunch, and when I came back, viola - seat...
Offline cmice
« Reply #61 on: May 08, 2026, 08:29:07 PM »
The big update I have is I took him out for his first ride today.  It was fantastic!  I was going to grab some video but couldn't figure out how to mount the gopro so I said to-hell-with-it and I'll try to get something interesting later.  Too many things to be worried about for a first ride anyway.  So here's a photo of where we stand as of now...
Let's start with the good stuff...
First, the chassis and suspension are surprisingly good - even shockingly good.  Nimble but really stable, no wobble, head-shake or frame flex.  I didn't really push it, but it did go down some very not-straight roads and hills with less than ideal road surface in places. Front dampers were replaced with new but original spec dampers.  The one nasty fork tube I replaced with a good used replacement.  The rear shocks are originals and are pretty ok.  I honestly didn't expect it to be so comfortable and capable, but it's just great.
Next, the engine pulls like a train.  It's really surprising how smooth the torque delivery is, and the gearing really suits it well.  I was keeping the revs and throttle opening on the modest side as we're still seating the rings and breaking in the engine.  But I'm really looking forward to being able to open him up more.  Also, turns out, I did know what I was doing when I put the gearbox back together along with the re-shimming process.  No clunks or crashes, just nice and smooth.  Most importantly, no leaks anywhere!  Given this bike has been parked since 1985, I made it a point to replace every seal and o-ring I could get to.
Lastly, the look and the sound.  It sounds great with the Dunstalls - maybe a little boomy, so we'll see over time whether they stay. But wow it's a symphony when you're out there.  On a relatively short ride with a friend to a local pub, got a couple of comments and thumbs up on the "antique" bike and nearly as antique owner.
In terms of the to-do list, which I may or may not keep up here...
I replaced the right start-kill switch when the OEM shorted out to the bars (released the magic smoke).  I picked this switch from a Tomos scooter because I like the look of it, and it should visually match a "Lego" style lemans left hand switch when (not if) my left switch dies.  The Tomos switch is wired backwards from new, so kill is on and run is off.  Irritating but maybe consider it an anti-theft device for now.
It's having a problem holding a steady idle.  Symptoms are lean pops at idle, and high-then-falling idle like an air-leak.  The dellorto rebuild kits I used didn't have the o-rings for the mixture screws and I thought I saw somewhere that they aren't important.  I think they are, so I'll try putting them in and see if that solves it.
The alternator struggles to top the battery up.  It's putting out amps but with all the incandescent lighting plus the sealed-beam front light, that's just a lot of draw.  I'm going to swap the sealed-beam for an H4 style lens and use an LED headlamp bulb - that should drop the 10A draw down to 1.5A.
The clutch bite point seems really narrow for as much lever travel as is afforded.  It seems like of the, say, 3 inches of total lever travel that the initial bite to full engagement is all of 1/2inch.  If I mess with the cable adjuster I can move that 1/2inch forward or backward on the lever, but widening the zone doesn't seem to be an option.  It's not a huge deal and may be just getting used to it, other things to worry about...such as...
The brakes are...well...bad.  The rear brake is surprisingly good, but the front does not feel like it'll be there when you need to do a panic stop.  I replaced the rubber lines with braided ptfe, and used new (old stock) pads.   Solid lever feel and not spongy, but you've got to put a firm handshake on it to get even modest braking out of it.  Two finger braking is not it's deal right now.   I'll try bedding the front a bit more, but I think realistically a dual-disc conversion is in the cards, but I was already planning on that anyway.
That's it for now - was just a great day today, and thanks for listening.
« Last Edit: May 08, 2026, 08:35:44 PM by cmice »
« Reply #62 on: May 08, 2026, 09:43:27 PM »
The VHBs used on Guzzis (and Moto Morinis) didn't have o-rings on the mixture or idle speed screws from the factory, and I've been running all of my VHB equipped bikes without any for the last 42 years.
The LED headlight should help considerably with the charging issue, an LED brake light bulb will help too (in more than one way). I like to run as "big" of a battery as possible (ETX30L) and an adjustable, solid state voltage regulator will help optimize output. A 450 watt alternator kit from EME eliminates the issue once and for all...
The stock PS15 front master cylinder is ill suited for a single F08 caliper. There are several "easy" ways to get better front brakes: 1) Replace the PS15 with a PS12 off of a later Tonti (T3, Convert, etc.) or even a PS11. 2) Replace the F08 caliper (38 mm pistons) with an F09 (48 mm pistons). 3) Add a second disc, F08 caliper, etc. and stick with the PS15 master cylinder.
Offline cmice
« Reply #63 on: May 09, 2026, 09:30:21 AM »
Yeah - is a theory of mine - as I think about it, the thread on the adjuster screw is pretty fine and probably seals pretty well on its own. Will pull the carbs and go back through them, check float heights and all that.  Back to basics, as it's a pretty simple setup.
Ordered the my regulator just now, and will track down some LEDs for front and rear.
Lots of options - the F09 swap may be the simplest and cheapest.  2nd disc gets pricey when you add up the caliper, the hub spacer, disc, extra hose and distribution block change, plus the weight.  Just rebuilt the PS15 and other masters don't look right (to me) and are price-equivalent to swapping the caliper out.  Gotta mull this over but nice to have the options laid out like that - thanks Charlie!
« Reply #64 on: May 10, 2026, 08:36:45 AM »
You're welcome.
I use these LEDs in the taillight and turn signals:
https://www.amazon.com/dp/B074GPX2Q8
https://www.amazon.com/dp/B074RFSFVT
I've installed this LED sealed beam unit in two customer bikes:
https://www.amazon.com/dp/B0BNT4V2VC
There are lots of others that are less expensive, but I like the look of the Peak lens better.
Offline cmice
« Reply #65 on: May 10, 2026, 10:37:34 AM »
Cool link regarding master cylinder to wheel cylinder brake ratios...
https://www.vintagebrake.com/mastercylinder.htm
« Reply #66 on: May 12, 2026, 10:42:22 AM »
Nice job saving the old girl.  Without your influence the future of this bike was a best uncertain.   Late to the party on this one, but per usual Charlie has provided his steady guidance.  Good going, and glad you are enjoying the T!
« Reply #67 on: May 12, 2026, 08:03:41 PM »
That's my "go to" chart as well.
Offline cmice
« Reply #68 on: May 20, 2026, 03:36:08 PM »
Several updates -
Went back to basics since the engine was assembled and heat-cycled a few times.  Retorqued the heads, reset the valve clearances, re-gapped the points, and checked the timing.  Much better now - no popping or spitting and nice steady idle (for a carb'ed, points bike).
Electronic voltage regulator works a treat.  I am running a comically small lithium battery (36wh), but it was new and free and weighs all of 0.5lb (if that).  May swap to a larger one later just so I can enable shorter hops and know I've got enough juice to make it home.
Brakes still on the to-do list, but for now the good weather has arrived and I want to get some time in the saddle! :) :)
Will still do a video at some point.
I put the end-caps back onto the Dunstalls to see if it quieted them down at all, and they don't - plus would have to downsize the mains to deal with the backpressure, so why bother.  I wanted to pull the end-caps off while stopped on a ride, and found I have 2x 10-11 wrenches and 2x 17-19 wrenches, but no 13-14 wrenches in my original toolkit.  Anyone have a 13-14 they want to swap for either a 10-11 or a 17-19?
« Last Edit: May 20, 2026, 03:38:18 PM by cmice »
Offline cmice
« Reply #69 on: May 24, 2026, 09:02:19 AM »
As promised…
https://www.youtube.com/watch?v=vgjFhaOAlWcNo
The ride back is more interesting than the ride there, but you get the idea.
Have a great Memorial Day.
« Last Edit: June 29, 2026, 06:46:18 PM by cmice »
