Author Topic: Pre-E5 V7 Rear Spoked Wheel on V9  (Read 8066 times)
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« on: November 28, 2025, 12:44:12 PM »
Pics below for illustration purposes.
I REALLY wanted to make this work. How lovely would it be to have a spoked 17” or 18” rear wheel on the V9, or even just normal, non-balloon’y wheels with only a few simple modifications that someone with even a slight interest in mechanical fondling can taken on themselves? After all, the pre-Euro 5 final drive of the V7 and V9 have the same style hub plate with 6 dogs fitting into the hub. Clearly we’re just mere steps from making this work, right?
Two issues stand out— (1) different size axles, and (2) discerning possible clearances/gaps that might occur. The first part could be a simple solution—find the proper bearings and see about using the V9’s internal wheel spacer inside the V7 hub. The second bit would require some Dremel work, but felt otherwise quite promising.
The final drive’s dogs indeed fit into the V7’s spoked hub like the V7’s own. The V9’s final drive, however, has an outer lip that projects across to the hub to close up the gap. This lip actually matches up pretty well to the V7 hub, but would need to be trimmed back with a Dremel without compromising structural rigidity of the pumpkin. I was pretty excited to think this was the answer, until I studied the V9 final drive further.
I realized all the thought and effort—including purchasing a V9 swing arm and final drive for the modification—were for naught because of this $@*%#€&~^ final drive vent poking INTO the hub. The inside of the V7’s hub lip clears the vent cap, LEADING ME TO BELIEVE THAT A V7 CAST WHEEL COULD STILL FIT A V9 FINAL DRIVE WITH THE AFOREMENTIONED MODIFICATIONS, but the V7 spoked hub’s inside spoke bosses (correct me if I’m using incorrect terminology) don’t clear this vent cap. This keeps my V9 Monza wheel mod potential alive should I choose to try a V7 cast wheel, but any hopes of using the V9 swingarm with the beefier double u-joint on my custom V7 enduro is tossed out. C’est la vie.
« Last Edit: December 02, 2025, 06:15:15 PM by Dirk_S »
Offline Huzo
Re: Pre-E5 V7 Rear Spoked Wheel on V9
« Reply #1 on: November 28, 2025, 01:00:42 PM »
Can you remove the vent, blank it off and re position one somewhere else ?
It’s only a vent to equalise pressure.
Offline Dirk_S
« Reply #2 on: November 29, 2025, 09:48:00 AM »
Appreciate the suggestion. I do believe a hex head, low-profile socket cap, maybe even a normal socket cap bolt should clear the spoke bosses. I hadn’t considered retapping a new vent, probably near where the previous small block vent always sat. I’d be curious about the structural integrity of a vent bolt threading into the aluminum with no casting built around it. I assume there wouldn’t be many threads to work with.
Offline Vagrant
« Reply #3 on: November 29, 2025, 10:15:04 AM »
I bet they never changed the casting.
Offline Dirk_S
« Reply #4 on: November 29, 2025, 10:56:56 AM »
That’s an understandable assumption given the small block’s slow evolutionary history, but Guzzi changed the swing arm, drive shaft, and final drive beginning with the early V9. There’s probably more new than there is shared. The splines are different, the mating end of the swingarm-to-final drive is beefier, the vent is shifted inward (free dog drive lubrication!). I believe the V9 final drive casting is the same as the E5 V7 and V9, but all fairly different from the final drives found on the V7 III and earlier small blocks. The V9 and V85 even look to have the same casting outside of the extra support for the V85TT’s mono shock. Pics for reference, all from the internet, including one poor soul whose final drive had a case of the runs.
« Reply #5 on: November 29, 2025, 03:27:53 PM »
Maybe vent it at the fill/level plug? Banjo bolt and fitting with a vent hose running up along the rear shock.
Offline Dirk_S
« Reply #6 on: November 30, 2025, 11:03:02 AM »
I like it.
Online faffi
« Reply #7 on: December 01, 2025, 01:55:59 AM »
No chance that some other small block final drive uniy will bolt directly up to the V9 svingarm and shaft, allowing you to use that together with - hopefully - the wheel you want?
Current bikes:
2002 BT1100
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Offline Dirk_S
« Reply #8 on: December 01, 2025, 06:16:52 AM »
Nada. On older small blocks, probably, but the final drive-swingarm mounting bolts on the V9 and E5 small blocks are spread farther apart. As in, the four corners takes up a larger area. The whole system has been beefed up in size.
« Last Edit: December 01, 2025, 08:35:02 AM by Dirk_S »
Offline Dirk_S
« Reply #9 on: December 02, 2025, 06:42:23 PM »
Tonight I chopped off the superfluous lip on the V9 final drive to fit it onto my spare V7 wheel. Removed the vent bolt, expecting a nice fitment.
It almost worked, but I found the plate’s bolt heads hit slightly against the spoke bosses as well. They’re the same size bolts (M8x25) as the older final drives, but Guzzi changed from external hex heads to socket caps (actually Torx heads, ughhhh), thus the bolt heads stick out more proud.
As well, the bolts on this newer style plate sit closer to the edge, and a hex head would absolutely come in contact with the hub’s edge, so I’m going to order some low-profile socket caps, which hopefully will resolve this bit.
Online faffi
« Reply #10 on: December 03, 2025, 02:28:12 AM »
Admire your tenacity :thumb:  Looking forward to follow the next steps.
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline Huzo
« Reply #11 on: December 03, 2025, 03:46:52 AM »
Make sure you know the offset of the rim so you can spoke the new one up the same.
Also, how does the rear disc line up ?  :popcorn:
Offline SIR REAL ED
  • uh.... it's personal....
« Reply #12 on: December 03, 2025, 06:33:52 AM »
Button Head Cap Screws (BHCS) might also solve your clearance problem.
Or you might be able to countersink the holes and use Flat Head Cap Screws (FHCS).
I would try grinding down some Hex Head Cap Screws (HHCS).  Of course measure some dimensions before starting.
Shallow Socket Head Cap Screws make me nervous, but of course, that is what a Button Head Cap Screw or a Flat Head Cap Screw is....
Does not seem like an insurmountable problem.  Good luck.
2002 MZ Skorpion
1994 DR Skorpion
Offline Dirk_S
« Reply #13 on: December 03, 2025, 08:04:17 AM »
Thanks. Who else is going to resolve this curiosity of mine? Sometimes it’s worth cutting up a $250 used final drive just to know what’s possible.
Yeah, I’m no fan of low-profile heads for higher torque applications. I actually just purchased some umbrella cap titanium bolts. Expensive, sure. But hey, shaves weight!
…In time.
See above. And stop jumping chapters!
But seriously, my next step might be looking at the bearings and spacer setup.
« Last Edit: December 03, 2025, 08:33:02 AM by Dirk_S »
Offline Huzo
« Reply #14 on: December 03, 2025, 11:00:40 AM »
Ok, but the issue will surface…
I’ll watch with interest… :popcorn:
« Reply #15 on: December 03, 2025, 01:08:35 PM »
this is a real puzzle you are working here
let me toss in one vote for "it looks cool and awesome with the stock bobber wheel/tire combo, and you can always reduce the tire size at your next tire change while keeping the V9 wheels"
Offline Crashcraddock
« Reply #16 on: December 26, 2025, 05:57:19 PM »
I can't recall if I've shared this Craig Rodsmith video before, so here it is.  Go to 4.40 mark.  Craig (not his real name) says he got the v7 wheel to fit by machining out the hub to accept V9 bearings, using 2 bearing on the the drive side, and then lacing up the wheel offset and it seemed to fit up.
https://www.youtube.com/watch?v=vWzq3lHcBYc&t=595s
Your thoughts?
Regards
Daniel
Daniel
2016 V9 Racer
1980 GSX1100 (never ending project)
1984 Gpz550
