Author Topic: U-joint inspection - Norge  (Read 4239 times)
Online PJPR01
« on: November 29, 2025, 12:58:56 PM »
Figured as I'm just about to turn 60K miles on the Norge I should do an inspection of the rear drive shaft and Ujoint - trying to determine if this has to be lubed with a zerk fitting or is a no maintenance item.
Anyone here remove, inspect or replace their U-joint on the Norge yet?
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Re: U-joint inspection - Norge
« Reply #1 on: November 30, 2025, 08:34:22 AM »
On a CARC bike, #1 is inspect and grease the swingarm bearings and the bearings in the shock linkage.
Not much to do with the u-joint and shaft.
Online PJPR01
« Reply #2 on: November 30, 2025, 10:56:24 AM »
Yes...that part has been done, and all in good shape there.  Specifically inquiring about the Ujoint however here.  Thanks.
Paul R
2008 Silver Norge
2002 V11 Scura
Offline Bulldog9
« Reply #3 on: November 30, 2025, 03:19:31 PM »
Non serviceable. If you did the swing arm bearings and put fresh grease on the splines, not much else to do. Did you do a visual and inspect when you had the swingarm off for the bearings?
MGNOC#23231
« Reply #4 on: November 30, 2025, 04:30:06 PM »
I first had mine off at 90,000 km and the splines were dry.
I did it again at around 200,000 km and the grease was still surprisingly good and I could see no real wear in the joint, but it cannot last forever.
« Last Edit: November 30, 2025, 11:10:20 PM by Huzo »
Online PJPR01
« Reply #5 on: November 30, 2025, 04:34:23 PM »
I did it again at around 200,000 km and the grease was still surprisingly good and I could see no discernabwear in the joint, but it cannot last forever.
Did you see any wear on your U-joints at the time of both inspections?  Those look standard, even if not with zerk fittings.  The shaft is sold with both u-joints, but I see no reason why those cannot be replaced if they have any play on them.
When I had the bearings greased, there was no play in the U-joints, but it's been several years, so I figure 60K is a good milestone to inspect again.
« Last Edit: November 30, 2025, 05:26:58 PM by PJPR01 »
Paul R
2008 Silver Norge
2002 V11 Scura
