Author Topic: Arcing coils / Running issue / no top end  (Read 19014 times)
Offline Turin
« on: December 02, 2025, 10:52:08 PM »
Anyone else experience this issue? I unplugged a wire from the plug and saw a bright arc from the coil to the frame when I cranked it over.  These are the 3ohm (new old stock) and they are arcing from the coil body. no cracks in the coil body.
Backstory - I'm chasing down a running issue on a modded lemans 1000 engine. the power curve hits a wall at 6500 rpm. Down low it's great. I've tried different main jets, checked the timing and advance, valve lash, changed out the dyna ignition. Hoping that a coil swap will do the trick.
Not a mechanic... more of a glorified parts swapper.
« Last Edit: January 20, 2026, 07:01:46 AM by Turin »
1985 Sidlow Guzzi
Re: Arcing Dyna Coils
« Reply #1 on: December 03, 2025, 01:01:26 AM »
With the plug wire off, the energy will find the next path to ground is my first thought.
Online nc43bsa
« Reply #2 on: December 03, 2025, 01:49:36 AM »
Indeed.
GM HEI coils have been known to do similar things.  The coil has high enough voltage to spark, even if there is no spark plug connected.
1990 MilleGT
Online SIR REAL ED
  • uh.... it's personal....
« Reply #3 on: December 03, 2025, 06:11:11 AM »
Correct.
I have long heard that you should always ground the plug wire when turning the engine over.
It might be a old wife's tale, but I have heard that some ignition systems will damage themselves if you don't give the energy a path to dissipate.
2019 Beta EVO 250
Online n3303j
  • Ron Cichowski
« Reply #4 on: December 03, 2025, 07:32:19 AM »
Yup, when you pull a plug wire on a running engine the energy has to go somewhere. When it arcs across the insulating material it turns a bit of it into carbon. This makes the path easier to follow each subsequent time. Eventually you end up burning an alternate path into the insulating material.
Safe way to isolate cylinders for diagnosis is putting a bare metal extender on the plug top and connecting the plug wire to the top of the extender. When you want to disable a cylinder you touch the head with an INSULATED handle screwdriver and bring the shaft to rest on the plug extender. Spark shorts to case ground and energy sagely dissipated. I always made plug extenders with the plug screw on top terminal with a long metric screw (head removed) threaded halfway through it. That screws easily on top of plug and plug wire fits the metric screw.
Early sparking systems (R60/2, Ural) had two grounded and pointed tabs that were gapped near the coil outputd so that if a plug wire dropped off the spark would jump from the metal terminal to the point on the grounding tab. Insulation was not so good in the '50s.
Two ground points aimed at HV terminals visible in this photo.
« Last Edit: December 03, 2025, 07:37:59 AM by n3303j »
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online michaell32
« Reply #5 on: December 03, 2025, 08:56:39 AM »
I always used one of these if I needed a plug out while cranking. You can use an alligator clip to hold it to the engine or frame.  https://www.autozone.com/test-scan-and-specialty-tools/ignition-tester/p/duralast-in-line-ignition-tester/1267200_0_0?searchText=Spark+plug+tester
2003 California EV
2018 Suzuki DR650
78 Honda GL1000
Online Moparnut72
« Reply #6 on: December 03, 2025, 09:11:52 AM »
Always ground an unused plug lead while cranking or running an engine. A very likely way to destroy a coil. The energy will do whatever it has to do to find its way to ground quite often destroying anything in its way.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline chuck peterson
« Reply #7 on: December 03, 2025, 10:08:54 AM »
Using a timing light to check your full advance while running? Sounds like your running issue
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline wirespokes
« Reply #8 on: December 03, 2025, 11:11:11 AM »
So now the question is - does the coil arc to ground with the plug wire replaced?
When everything looks good, yet there's still a problem, that's the time to look deeper. Looking deeper requires knowing more about the systems being checked.
Your high speed running issues can be electrical or fuel. A little more data might narrow the search. Give us more data what happens. Does the engine gradually run out of steam? Give it more throttle and it bogs? Backfire? Bucking?
What bike is this? Points? Electronic ignition?
Offline Turin
« Reply #9 on: December 03, 2025, 07:26:36 PM »
no plug when the coil arced, gave me a scare. won't do that again.
Engine pulls like a freight train until 6500 RPM, then acts like it's hitting a rev limiter. Fluttering. I've tried every main jet from a 155 to a 225. needles have been raised, lowered etc.
Good battery, Charging system is working. Timing and advance checked. Valve gap checked.
Dyna III ignition (I've tried two, no change)
Dyna 3 ohm coils ( I'll try swapping these for another set)
NGK bP6ES plugs
NGK 8 mm copper core wires
It must be something stupid.
1985 Sidlow Guzzi
Online n3303j
  • Ron Cichowski
« Reply #10 on: December 03, 2025, 11:56:18 PM »
What is the chance that something is floating at 6,500? Maybe a valve spring is broken and the valve doesn't fully close at the higher RPM?
Or your advance is not fully advancing?
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online michaell32
« Reply #11 on: December 04, 2025, 01:13:20 AM »
About the only things left are cam timing or valve float. I can think of a couple others but the symptoms would be slightly different.
2003 California EV
2018 Suzuki DR650
78 Honda GL1000
Offline Tony F
« Reply #12 on: December 04, 2025, 02:36:01 AM »
Is it getting enough fuel? Are the filters on the fuel taps clear of rust etc?
Tony
'79 SP1000
KTM Duke 890R
MV Agusta F4 (x2)
Online SIR REAL ED
« Reply #13 on: December 04, 2025, 06:14:02 AM »
Thanks for the picture.  I like that design.  The good ole days.
My father had a different method for grounding out/isolating a single spark plug.
He would make one of his sons hang on to the spark plug in question.
If you flinched, he knew that spark plug was getting juice.  Then he feign ignorance and ask "What the Hell is wrong with you?"
Some may think that cruel, personally, I think having your brother or mother-in-law hold the plug sounds more humane.
« Last Edit: December 04, 2025, 06:23:08 AM by SIR REAL ED »
2019 Beta EVO 250
Offline Turin
« Reply #14 on: December 04, 2025, 10:55:00 AM »
Clear fuel line and plenty of fuel flow. Valve springs are not broken.
1985 Sidlow Guzzi
Offline dblue
« Reply #15 on: December 04, 2025, 12:13:16 PM »
ran into that problem with my  modded LM 3, air filter was the restriction.
David Blue
dfblue46@outlook.com
937-210-8721
Offline wirespokes
« Reply #16 on: December 04, 2025, 04:13:48 PM »
How do you know it's getting enough fuel?
Yes, DO check for obstructions in the air flow.
It's hard for me to believe there's anything mechanically wrong with the engine because it runs great up to 6500.
I've heard bad things about the NGKs, so I'd try Denso plugs.
When you 'hit the rev limiter' what happens giving it more throttle? Does it try to go faster or stall out. Then if you back off the throttle, does the engine speed up? What exactly happens at 6500?
Fuel, air and spark are needed to run.
Once it's determined they're all there, is there enough fuel, air and spark?
After that, you're getting into fine points of timing and oddities.
Does the engine rev to redline while stationary?
« Reply #17 on: December 04, 2025, 10:22:05 PM »
This was a head scratcher until I found it. Bike ran great except at wide open. Turns out that the closed end of the filter needs to be at a minimum two times the diameter of the throat . Theoretically it should be 2.5. It usually isn’t a problem until we do some tweaking . It’s measured from the carb opening to the end of the filter.
« Last Edit: December 04, 2025, 10:25:49 PM by John A »
Offline wirespokes
« Reply #18 on: December 05, 2025, 01:46:12 PM »
Let's see if I read you correctly, John: For a 40mm Dellorto, the distance from the entrance into the carburetor to the closed end of the filter should be 100mm or more? Minimum 80mm?
Intake, including filter dimensions, and exhaust sizes have an effect on an engine's performance.
I worked at an auto repair shop for a while back in the late 80s and there was a VW bug that had us pulling out our hair. It wouldn't run past mid range. We'd gone through everything. Finally the boss decided to replace the fairly new exhaust. Didn't make sense, but we'd gone through everything else. As it turned out, the owner had driven through a deep puddle which had shocked the hot muffler and dislodged a baffle. Ran fine after that!
Offline Turin
« Reply #19 on: December 05, 2025, 08:03:14 PM »
2 sets of plugs tried. I'll pull the K&N filters and install the velocity stack/bell mouths. cant hurt.
1985 Sidlow Guzzi
Online Offcamber1
« Reply #20 on: December 05, 2025, 09:31:35 PM »
Turin, what type of spark plug wire ends are you using?
Kip
« Reply #21 on: December 05, 2025, 11:52:32 PM »
Yep, that’s right. I got the information from this book https://www.ebay.com/itm/177555593782
They did a lot of testing on a 500cc one cylinder so it is relevant to a Guzzi. Another thing I remember from it is that the exhaust box, or muffler should be ten times the volume of the cylinders, mostly only possible on a stationary engine.
Offline Turin
« Reply #22 on: December 06, 2025, 09:56:56 AM »
1985 Sidlow Guzzi
Online SIR REAL ED
« Reply #23 on: December 06, 2025, 10:23:13 AM »
2019 Beta EVO 250
Offline turboguzzi
Re: Arcing Dyna Coils Added pics
« Reply #24 on: December 07, 2025, 03:03:54 AM »
yep, you never fire a coil without it being attached to a plug that grounded or a grounding wire
May i ask what ignition system are you running?
I see the points housing and dyna (?) coils but no idea what drives them
Whats the history of the problem? meaning, same setup has run good before and then didnt or you are sorting it out now?
what color do the plugs have?
Offline Turin
« Reply #25 on: December 07, 2025, 10:00:29 AM »
Dyna III. I swapped the existing Dyna III for a brand new one. No difference. It's been an issue since the bike was re-started. plugs had a nice tan color before I started changing main jets. (155,165,175,185, 195, 205,215, and 225) the 225 caused a secondary flat spot and the bike did not like that.
1985 Sidlow Guzzi
« Reply #26 on: December 08, 2025, 11:30:33 AM »
This probably isn’t the problem, I’m just throwing it out there. I put a relay on to power the coils . It’s one of those square ones about an inch , usually used on after market lights so it’s rated for continuous duty. The original power to the coils goes to the switch terminal on the relay and a direct line from the battery through an automatic reset mini circuit breaker powers the coils. I did it just because I wanted to be sure the voltage to the coils was not going through the wiring harness. If you watch it in the dark you might be able to see if spark is leaking to ground somewhere. A tricky thing looking for that while running down the road at night!  A dyno would be handy. Another thing I’ve found is that the spring loaded needle valves in the carb can hang up causing erratic fuel levels in the bowels. One winter I drilled out the internal passages in the petcocks and banjos , mostly just cleaned out the passages. I don’t guess it made any difference but winter gets long.
Offline turboguzzi
« Reply #27 on: December 11, 2025, 02:19:34 AM »
I cant even tell you how much i dislike Dyna ignitions......
Try to aim a timing gun at the flywheel at very high revs, you might discover something, tell us what you saw.
Shouldnt be difficult to go back to points just to verify.
That said, if you are so all over the place with main jets, go to a dyno and find the right one based on best WOT power, you are just confusing yourself like that,
anothe ridea, have you tested that you have enough fuel flow to carbs?
did i already asked for  :gotpics: ?
Offline theoneandonlymin
« Reply #28 on: December 11, 2025, 11:19:00 AM »
When I first bought my Stelvio, it really didn't like running if there was a bit of  dampness in the air.
The spark had preferred to go sideways from the coil...
« Last Edit: December 11, 2025, 01:37:08 PM by theoneandonlymin »
Online Offcamber1
« Reply #29 on: December 24, 2025, 07:18:16 PM »
Turin, any update?  I was just pondering, when you changed the Dyna III ignition, did you change the pickup as well, or use the previous one?  Also, wondering about the gap to the pickup being within spec?  (I am not personally familiar with the Dyna III, but with other electronic ignition systems.)
I think Sherlock Holmes called this one a "two pipe problem."
Hope you figured it out, and Merry Christmas!
Kip
