$85 top case
Topic: $85 top case (Read 94 times)
Perazzimx14
$85 top case
December 06, 2025, 11:53:39 AM »
I wanted a different top case for my latest acquisition (I won't mention the brand because some have been offend because it not a MG) and have had exceptional luck with offerings from Amazon. So a quick check and a 45L top case, mount, liner, back pads and reflective stickers was $85 shipped (previous similar cases I'd purchased over the last couple years were $124 and $139) for what was branded as Vevor in this instance. Case arrived in two day and was exactly what i expected, great quality case for a fraction of the cost of name brand. I will say this case had plastic mounting spools so again back to Amazon for a set of aluminum spools. There have been a few reports of the plastic spools breaking when abused like lots off-road ridding so for >$9 I figured I just eliminate any threat.
The new spools arrived today and they are an exact replica of the plastic units but the case had a slight amount of play and rattled. This is no way related to quality but rather how straight the rack is the quick detach mount fastened too. So to take up the slack I added two more bolts that could push/pull the front corners of the mount to adjust the spool in the slots of the case to a point where there was no slop and fitment was snug then lock everything down. No more rattle and all in less than $95 I have a top case that works treat.
upload images for forums
2017 Road Glide Special
2020 Kawasaki KLX300SM
izzuG
Hatchling
Re: $85 top case
Reply #1 on:
December 06, 2025, 02:46:57 PM »
do you have a link for the spools?
Perazzimx14
Re: $85 top case
Reply #2 on:
December 06, 2025, 03:06:29 PM »
Quote from: izzuG on December 06, 2025, 02:46:57 PM
https://www.amazon.com/dp/B0CX41WH1Q?ref=ppx_yo2ov_dt_b_fed_asin_title
$85 top case
