Author Topic: 850 T3 head bolts  (Read 868 times)
Offline bobra5037
850 T3 head bolts
« on: December 10, 2025, 05:46:56 PM »
Any engineers out there?
The 850 engine (Eldorado and T2/T3) has a short engine stud bolt with a hex socket nut.  The nut sits under a screw in cap.  So, my questions:
1.  Why is this not a regular hex nut like all of the other studs?
2.  How do you get the nut off?
It is frozen tight and I'm not sure if it's fused to the head or fused to the stud.  I suspect the former because it will not budge under extreme torque and I would have thought the stud would unscrew if it was just the nut seized to the stud.
I've tried force, lubricant, heat (albeit rather gentle), a toque wrench and percussion but neither of them will budge.  No problems with the other head nuts.
Cheers
Rob
Re: 850 T3 head bolts
« Reply #1 on: December 10, 2025, 06:30:32 PM »
Cheers
Rob
1. Because there's no room for a regular hex nut?
2. It'll probably need more heat and a good penetrating fluid. I like to heat the offending nut up, then spray it with CRC Freeze-Off. The thermal shock helps loosen things pretty well.
Put the other head nuts back on and torque them down to alleviate any stress on that nut.
Online Moparnut72
« Reply #2 on: December 10, 2025, 07:45:55 PM »
If you have a rattle gun set it on low and let the vibration work on it. Soak it with something like Liquid Wrench for a few days prior.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online TOMB
« Reply #3 on: December 11, 2025, 08:51:52 AM »
I would agree with the other comments here.However, just a thought the head has probably been off sometime in the past.And somebody forgot to put the washer underneath that hex bolt or excuse me, hex.Nut, so do these suggestions from the people above when you get it off.There should be a washer underneath it.It's not your regular diameter, washer.The hole is the same as the other bolts.However, the outside diameter is smaller and it may or may not be a wave washer.Take your time work at it.It will come loose with a big snap, and your arm will probably hurt.When it happens
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Online n3303j
  • Ron Cichowski
« Reply #4 on: December 11, 2025, 09:29:25 AM »
Can't emphasize enough that you have the stiffest wrench combination possible so that no shock input is lost into winding up the wrench arm or hex key.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline wirespokes
« Reply #5 on: December 12, 2025, 10:12:42 AM »
Shock it both ways - clockwise as well. And shock it end-wise also. Use a punch or rod and tap on it, not pound. The idea is to create shock waves, not pound it loose. The bolt will vibrate at a different frequency than the aluminum helping to separate the two. The heating/cooling/vibration/torqueing will help the penetrating fluid penetrate.
The trick is knowing this will eventually work, even though it seems it never will. So don't drag in the heavy artillery and make a mess of things. It will eventually break free.
One other thing - I don't know what's so special about Power Steering Fluid but it's an excellent penetrating fluid. Mix it 50/50 with acetone and it makes short work of problems like this.
« Last Edit: December 12, 2025, 10:15:00 AM by wirespokes »
« Reply #6 on: December 12, 2025, 10:49:37 AM »
TOMB
That washer is sometimes stuck on the head and it’s hard to see if it’s there. A small magnet on a stick helps identify if it’s in place when you put it back together.
