Author Topic: aux lights for a Norge  (Read 5147 times)
Offline Oca Grassa
« on: December 21, 2025, 05:09:22 PM »
Like the title states….looking for suggestions from those who’ve mounted them. A) mounting solution and B) wiring ideas. My wireless charging hub is connected to the connector for the factory GPS. Looking for a similar solution. TIA…
My garage:
Offline PJPR01
Re: aux lights for a Norge
« Reply #1 on: December 21, 2025, 05:53:41 PM »
I've had Moto Lights on my Norge for a long time, they mount to the front brake calipers...you can order them with LED or standard halogen lights.  I put a different switch on them that is illuminated at night and mounted to the left hand side.
But to be fair, there are tons of lights driving lights on Ebay that come already with the switch built into the wiring as well, make sure you get a fused (inline) setup.
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Offline Oca Grassa
« Reply #2 on: December 21, 2025, 11:16:33 PM »
Any chance you’d be willing to post a pic of how yours are mounted to the caliper? I’m presuming through the caliper mounting bolt with post style mount system/clamp on the light unit?
And yeah…tons of options for lights…for my intentions, more for being seen than a need to see more than with the OEM head lights. Been exceedingly foggy here so far this year.
My garage:
Offline PJPR01
« Reply #3 on: December 21, 2025, 11:28:22 PM »
Sure...will get some close up pics in the morning.  They are quite a bit pricier than the standard driving lights you can find these days (they were nowhere near this expensive a decade or so ago), but they have been impeccable for many many years.  A few years ago I switched out the halogen inserts to LED's...quite a bit brighter!
Paul R
2008 Silver Norge
2002 V11 Scura
Offline flower_king001
« Reply #4 on: December 22, 2025, 08:09:41 AM »
Denali lights mounted to the crash bars on my Breva 1100. I also removed the stock headlight and used a generic shell and led light. Replacing the stock headlight made a huge difference!
From a previous post several years back:
Step by step of the conversion can be found here using the same components as the original poster:
https://www.guzzitech.com/forums/threads/headlight-conversion-for-the-1100-breva.18970/
Headlight bucket I ($55) used came from here:
https://shop.revivalcycles.com/7-vintage-lucas-headlight-bucket/
And here is the headlight ($39)
https://www.ebay.com/itm/Motorcycle-7-CREE-LED-High-Low-Light-Projector-Headlight-for-Harley/112110579411?fits=Year%3A2007%7CMake%3AHarley-Davidson&hash=item1a1a4faed3:g:B6YAAOSwgZ1XwUcN:rk:1:pf:0
« Last Edit: December 22, 2025, 08:14:01 AM by flower_king001 »
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Offline moto
  • Fear the deer!
« Reply #5 on: December 22, 2025, 09:55:28 AM »
My 2023 Alfa Romeo has standard-equipment fog lamps. Imagine my surprise when I found they were two, small bright white lamps pointing backwards at the rear of the car. If you are routinely riding a motorcycle in a foggy area you stand a good chance of being hit from the rear. You may consider putting some lamps on the back. Good conversation piece, too!
« Last Edit: December 22, 2025, 10:05:41 AM by moto »
850 T-3
Griso 1100 corretto
Offline PJPR01
« Reply #6 on: December 22, 2025, 10:23:43 AM »
Paul R
2008 Silver Norge
2002 V11 Scura
Offline Oca Grassa
« Reply #7 on: December 22, 2025, 11:19:29 PM »
Less of a chance than you might think. A car on either side of me would have to get hit first as I’m not normally stopped all by myself….and because I am allowed to split to the front at a stop, I do.
My entire upper torso is covered by a reflective vest. Not like one you see on construction workers…but a Night Eye one from Richa (I think). The entire thing is 3M reflective.
@PJPR01 thanks for the pics…that’s exactly what I’m looking for.
My garage:
Online Bulldog9
« Reply #8 on: December 26, 2025, 09:51:27 AM »
I have the same fork mounted lights on my Norge as well. They came on the bike, and are a nice farkle. As stated earlier, I have them wired so the switched GPS power lead triggers the Relay. I like them always on with the key. WHen bulbs die out I will try to replace with LED.
I have these small LEDs on the Stornello and 1200 Sport. They are tiny LED's with miniscule amp draw. They are just wired directly into the GPS power lead. No switches, no relays, no mess. Hard to believe it is 8 years on the Stornello and 5 years on the 1200 Sport....... I have a box full of parts, and instead of sourcing the proper plug to plug into the GPS power plug, I usually snip and replace.
On the 1200 Sport, I mounted them with a Nylon spacer and proper threaded bolt to replace one of the fender mounts. Used loctite to keep the bolt snug. Total cost was less than $30 and my time. They get the Job Done. A piece of debris grabbed one of the wires and tore it out of the light so I replaced them with smaller units that look much better.
When it comes to rear lighting I always add extra brake and tail lights as well. This small round LED light has excellent visibility and has Brake/Park/Turn built in. I usually just use the Park and Brake. On the Norge, I installed an extra LED light bar to the edge of the rear case rack. I've likely had it for years and came across in my electrical parts box. Is an AUX brake light.
« Last Edit: December 26, 2025, 10:02:57 AM by Bulldog9 »
MGNOC#23231
Offline Oca Grassa
« Reply #9 on: January 10, 2026, 09:26:11 PM »
Being the cheap Bastid that I am, I found some post type mounts on Amazon for under $20 and then some what appear to be copies of Denali Vision X projector beam LED fog lights for around $80.
I spent today wiring everything up and figuring out how to mount them. After test fitting, it was clear there was just one way the lights could be mounted. The posts mounts were just long enough to mount through the lower chin fairing mounting holes. Bolt diameter and thread pitch matched. No where else seemed logical nor stable enough.
The lights specs closely match the Denali specs. I don’t yet know how well they’ll work for me in the long term. Wiring was straight forward as each cable to the lights & controller are indexed and water tight. The relay/controller wires direct to the battery with the included harness. So easy…a caveman could do it 😂
Still to do….have to re-aim one light so that they’re even, and rotate the lenses so the beams are “right side up” as I had to mount the lights hanging from the posts as opposed to perched atop.
 Mounted the switch pod using the included mount & hardware. The mount I used is held in place by the mirror stem. Some minor massage of the mount to allow it to be placed there was required. Literally took me a few minutes.
Am slightly concerned that I may drag a light pod in harder cornering….as I normally drag the center-stand mount. Not sure where the outermost point of the light pod will be when cranked over hard in a corner with the forks compressed. I “think” it will close, but fine.
My garage:
Offline Oca Grassa
« Reply #10 on: January 13, 2026, 06:27:39 PM »
All done for now. Adjusted the lights so they were even…went to ride to work and found them aimed too high. Like right in a drivers face at around 100 feet.
Readjusted when I got home from work…and they’re just about perfect now. In fog light mode an amber beam pattern is distinct and aimed at the road nominally 100 feet ahead. At least that’s where the brightest point is.
Might take some time this weekend to clean up the wiring a bit. It is certainly fine for right now though. I’d just like to clean up the “wire spaghetti” look under the seat.
Turned out the lights grounding in a corner is a non-issue. Happy enough with that now as well.
My garage:
