Author Topic: Horn test results. Should I buy louder ones?  (Read 13589 times)
Offline nwguy
    • Jim Gallant's home page
« on: December 24, 2025, 08:00:02 PM »
Before I buy new/louder horns for my 1999 Bassa I wanted to know if I add a relay with wires direct to the battery terminals to the stock horns, will the better connections make them significantly louder? Loud enough? Do I really need to buy new horns?
So I tested the horns using a free dB metering phone app from 10" and 14' away, first using the stock setup and then using wires direct to the battery terminals. For grins I also tested reversing the polarity to the horn terminals. My Bassa's left horn is the high tone horn. Low is on the right.
Battery
It was on a charger during this test since the horns draw a surprising amount of current. I didn't want test results to vary depending on battery voltage. Voltage readings were above 13 volts. I figure your battery will probably be charging most times you use your horn while riding.
Polarity
Original polarity was hot wires to inside connectors. Reverse polarity readings showed less than one decibel difference in loudness, so caring about this seems a wash unless there's some phase advantage that would require more testing.
Relay
To simulate using a relay without having installed one yet, I just used stout test cables with alligator clip ends to go from the battery terminals to horn terminals. I read this somewhere:
"Maximum allowable voltage drop for any relay or switch contact is 300mV (.300V)."
So the Direct db values may be a bit smaller in real world use.
I didn't have the stuff to make jumper cables to test the direct wiring with both horns on simultaneously. But based on the individual results, looks like combined they'd be significantly louder.
All readings are measured in decibels.
TESTS INSIDE GARAGE
       from 10" away   |  from 14' away
       Stock  | Direct | dB chg | Stock  | Direct | dB chg
Both:  114.8  |        |        | 99.8   |        |
Left:  116.9  | 117.2  | +0.3   | 102.6  | 117.1  | +14.5
Right: 108.4  | 115.1  | +6.7   | 87.0   | 108.4  | +21.4
Initially I did these tests in my garage with the doors closed. It's echo-y in there. I should have done all these test outdoors. So I did more tests to tell how fewer decibels there were outside than in the garage. No difference in 10" away, but 14' away:
OUTDOOR TESTS with stock wiring from 14' away
       In garage | Outdoors | dB change from in garage
Both:  99.8      | 92.7     | -7.1
Left:  102.6     | 92.4     | -10.2
Right: 87.0      | 82.1     | -4.9
End result, my horns make 92.7 dB in real life situations. I haven't found how advertised horn volumes are tested. Seems to me, outdoors from maybe a 30-50 foot distance would make the most sense. I suspect modern, louder horns rated at 120+ dB are much louder than mine.
Next up, same test on my stock headlight with a light meter app.
« Last Edit: December 24, 2025, 08:02:09 PM by nwguy »
Offline bronzestar1
Re: Horn test results. Should I buy louder ones?
« Reply #1 on: December 24, 2025, 09:25:15 PM »
If you're going to go thru the trouble of wiring up a relay to your stock horns, you might as well go with new horns, like Fiamm Freeway Blasters, or even better, a compact air horn like a WoLo Badboy.  Either one of those will definitely be louder than most OEM motorcycle horns.
Offline moto
  • Fear the deer!
« Reply #2 on: December 24, 2025, 09:53:48 PM »
I believe one meter is the usual test distance. I found distances by carefully examining manufacturers' websites.  If you take your readings at one meter you should get markedly different results, maybe up near the claimed values of manufacturers.
Your right horn gives surprisingly low values compared to your left one. Are you testing it at a different angle? Maybe try putting it in exactly the same spot when you make your tests.
I am not surprised that direct wiring doesn't increase the decibel level much. Some people advocate using a relay to reduce the voltage at the OEM switch to keep it from early failure. I don't know how well that works.
I think your tests are a good idea. Make sure you can get very similar values in repeated tests before taking results as definitive. Good luck.
P.S. I find flashing very bright lights more effective than honking very loud horns at longer distances. I have both, in spades.
« Last Edit: December 24, 2025, 09:54:46 PM by moto »
850 T-3
Griso 1100 corretto
Offline Dr. Enzo Toma
« Reply #3 on: December 24, 2025, 11:46:06 PM »
If those are the original horns, the difference in volume left to right may simply be due to how the horns have weathered and aged. They are basically speakers with a diaphragm that is exposed to the elements, with wind being a rough one.
2027 Moto Guzzi V7 Sport
MGNOC Member
Offline normzone
« Reply #4 on: December 25, 2025, 12:12:30 AM »
If memory serves me well, which it may not, the Hella Horns I replaced my stock '99 Bassa horns with tested out at 114 db.
Offline JoeB
« Reply #5 on: December 25, 2025, 06:19:07 AM »
98EV here and have run stock, freeway blasters, and lately a set of Hellas.
The blasters in my opinion were head and shoulders ahead.
Didn't do any testing on them other than observations from practical use.
FWIW wiring on my era of bike already had the horns coming off a relay.
Not sure of others. Also Merry Christmas!
https://dpguzzi.com/cal1100i_x.pdf
« Last Edit: December 25, 2025, 06:29:26 AM by JoeB »
« Reply #6 on: December 25, 2025, 09:14:28 AM »
I can FART louder than most "stock" motorcycle horns... :laugh: :grin: :wink:
I had one of these STEBEL Nautilus Air Cannon horns on my old 2014 Victory Vision Tour.
It was a "blaster" and as loud like a train horn. :thumb: :cool: :wink:  Highly recommended... :thumb: :thumb:
Offline jbhotchkiss
« Reply #7 on: December 25, 2025, 09:59:53 AM »
Lots of good, reasonably-priced LOUD horns out there. Given the prevalence of distracted idiot drivers on the roads these days, I recommend new horns. WOLO, Farbin, Stebel, etc.
Offline StuCorpe
« Reply #8 on: December 25, 2025, 10:24:13 AM »
I went the route of adding an airhorn and throwing the original horns away.  The airhorn is much louder to my ears but have never made any measurements on it.
« Reply #9 on: December 25, 2025, 11:03:09 AM »
Usually, they are all about 139dB+ :thumb: :bow: :cool: :boozing:
I once blasted a distracted driver in a large white Cadillac SUV who cut me off, and it was so loud, he fumbled and dropped his cell phone to the floor!! :laugh: :grin:
Offline nwguy
« Reply #10 on: December 25, 2025, 11:29:31 AM »
The wiring diagram for a 2000 Jackal that seems to apply to my Bassa shows my horn using a relay. I replaced all my relays with new ones from Dan Prunuske during my restoration. Despite this relay, I'm seeing from different installation instructions for compressor-driven horns that I'd need to use the new horn's supplied relay with heavier gauge wires. And then use one of the positive wires to my stock horns as the signal wire for the relay. Correct?
The Stebel Air Cannon's packaging shows dB levels measured from 4 inches and 6 feet away.
The Fiamm Freeway Blasters come in low and high, so I suppose I would buy one of each. Would these be a direct replacement? Or would they require a 30 amp relay and heavier gauge wires?
« Reply #11 on: December 25, 2025, 11:37:40 AM »
Those are real loud and it's fine on way you're doing install.
2 of the Guzzi's I ride don't have a horn, just deleted at sometime in past, stuff stops working & you pitch it. Last was air horns on the sidecar rig.
Offline nwguy
« Reply #12 on: December 25, 2025, 01:43:42 PM »
I've read at least one opinion saying if you need to use your horn, it's too late. I disagree. Too many times I've seen people about to turn left in front of me that I've thwarted by using horn, lights, finger, or whatever it takes. Plus, a horn may be used to prevent an accident but it can also be used to tell a driver that they made a mistake and should be aware of it. Though these days that might result in a road rage thing.
« Reply #13 on: December 25, 2025, 03:02:25 PM »
They have Fiam's at the auto parts store and reasonable. That is what it came with new.
Offline MG_rider
« Reply #14 on: December 25, 2025, 03:20:29 PM »
If you want a louder horn go with the Stebel or Nautalis as recc'd by JJ.
You should use a relay because the inductive kick-back when you let go the button is 10X the running load current.  That can burn out the contacts on the horn button.
'23 Moto Guzzi V100 Mandello S
The bike is just a blank page, the rider is the writer, the road is the ink....
Everyone should have something in their life that requires a helmet.
Offline Motormike
« Reply #15 on: December 25, 2025, 05:50:04 PM »
In 50+ years of riding, I don't think I've ever bothered to use a motorcycle horn in a forlorn attempt to warn or signal a car driver of anything.  Not including the times I've hit the horn button while trying to use the turn signal switch! While much of that may be because stock horns on motorcycles are worthless, I have had a few horns that were surprisingly loud.  If you are ever around the owner of a K1600, ask them to sound the bikes horn...it will make you jump!
« Last Edit: December 25, 2025, 05:51:40 PM by Motormike »
Offline Tkelly
« Reply #16 on: December 25, 2025, 07:39:59 PM »
In situations where I needed to get another drivers attention because he was going to hit me I was too busy avoiding the crash to try to find the horn button.
Offline guzziart
« Reply #17 on: December 26, 2025, 06:34:56 AM »
Or a Goldwing 1800 or a Lemans IV....good horns.
« Reply #18 on: December 26, 2025, 07:19:40 AM »
If you're going to upgrade, listen to JJ.  And add a relay.  I assisted at a shop for quite a while that did hundreds of air horn installs and a many repairs for incorrect installation.  Do it right, do it one time.
As for the additional observations, better to have and not need than the other way around.  In all my years of riding, needed the loud horn one time.  It was a life saver.
It's another tool in the bag.
Offline guzziart
« Reply #19 on: December 26, 2025, 08:00:36 AM »
Yeah, Greg Bender (TOT) can hook you up with a pretty nice fused harness & relay assembly for minimal cost to make the installation of horns,etc. a plug & play easy peazy task.  I've used his relay harnesses on my Lemans, eldo & strom. :thumb:
Offline Vagrant
« Reply #20 on: December 26, 2025, 09:09:06 AM »
I can't tell you how many times a loud horn has saved my ass in a parking lot where some moron decides to back out without looking. I do everything in my power to never go near a lot but sometimes you have to.
I tried to make a run north to south through Shenandoah park a few years ago. The morning greeted me with rain and dense fog. I consulted the weather map and did a 60 mile South detour around the mess on an interstate. I also always avoid them but sometimes it's the only choice. While running 80 on the V85 just to keep up with traffic I was going by a car with a totally lost in space driver. He started drifting into my lane as I was right by his door. The stock horn didn't phase him. He had me to the edge in a second and I was on both brakes as hard as they would go. I was out to the last inches of the outside edge of the pavement when his bumper cleared my front tire. He still never knew what happened. The bike got a freeway blaster as soon as I got home.
Offline Tkelly
« Reply #21 on: December 26, 2025, 09:23:14 AM »
Good point!
Offline nwguy
« Reply #22 on: December 26, 2025, 10:08:27 AM »
I bought a Stebel Nautilus Compact Air Horn. Looking forward to installing it.
Offline moto
  • Fear the deer!
« Reply #23 on: December 26, 2025, 10:13:35 AM »
Good choice. I installed mine in the space where the air box used to be on my T3. It is also wired up to sound with the original stock horns when I press the headlight flash and horn button simultaneously. So sometimes I start out with the regular horns and then add the full Union Pacific treatment as needed. Very effective.
850 T-3
Griso 1100 corretto
« Reply #24 on: December 26, 2025, 10:51:11 AM »
It's a very LOUD one....https://www.youtube.com/shorts/dWDqNHbBIjs...and reportedly, can be heard 8 blocks away!! :bow: :thumb: :cool: :boozing:
« Reply #25 on: December 26, 2025, 12:27:02 PM »
Here it is on my V85.
Offline nwguy
« Reply #26 on: December 26, 2025, 01:48:45 PM »
Interesting. I'll have to find the right spot on my Bassa.
Offline bronzestar1
« Reply #27 on: December 26, 2025, 06:36:08 PM »
Oh yeah, that'll get you noticed for sure!
Offline nwguy
« Reply #28 on: January 24, 2026, 10:37:43 AM »
Epilogue:  I did install the Stebel Air Cannon with a relay. It's amazingly loud! I love demonstrating it to friends.
Offline bronzestar1
« Reply #29 on: January 25, 2026, 04:31:39 PM »
By far the loudest horn(s) I've installed on any of my bikes has been a compact air horn with a relay (WoLo Bad Boy).  Next loudest was a pair of Fiamm Freeway Blasters with a relay.  But the compact air horn, if you have the space, is the best choice IMO.
