That would be quite the relief if it were simply the sensor.I wonder—for those who understand the pumps a little better than I—I forget where the pump sends oil. If it sends it up to the cylinder heads, you could pop off the valve covers and check that the rocker assembly is lubricated and there’s residual oil sitting. But something’s telling me—and I don’t have the manual in front of me to check right now—that the heads are lubricated by a blow-by system, and the pump is primarily for the cam. I could be correct or completely off.Can someone verify, please?
Rode 100 miles home sure suggests a sensor issue as opposed to mechanical.
My riding is generally a mix of 12 miles each way Monday - Friday, with longer rides (by Welsh/British Standards) on Weekends.
Years ago I had a Harley 883 Sportster. It was notorious for making milkshakes in the winter. It was all from condensation, I live in an area that outside of town is heavy with ice in the winter so I am never able to ride longer distances. I did my best to get it up to operating temperatures for a reasonable amount of time and changed the oil often. Air cooled Sportsters unlike the rest of the Harley lineup run pretty cool a lot of it is probably due to the remote oil reservoir.kk
kev is spot on. Pull the heads.
