CALI VINTAGE REAR SUSPENSION
Topic: CALI VINTAGE REAR SUSPENSION (Read 376 times)
VINNY59
MR
New Egg
2025 moto guzzi 1992 1000s, 2009 calvin
January 02, 2026, 10:59:46 PM »
My first post, I recently bought a 2009 california vintage, I only seem to have a standard looking spring preload on the left shock only, the right (shaft side ) has not got the visible staggered adjustment collar .
Is this normal?
I wished to soften the preload slightly as it is on max setting as can be seen on the left side.
guzzisteve
"Just Ride It"
Re: CALI VINTAGE REAR SUSPENSION
Reply #1 on:
January 03, 2026, 05:45:06 AM »
How many have owned it since it was sold new? Usually both are the same but maybe factory ran out of that kind ,then they reach into the other box for parts cause it's got to get out the door.
kingoffleece
SplitWeight(tm) seat covers
Rated 5 STARS Motorcycle Consumer News
Reply #2 on:
January 03, 2026, 07:05:51 AM »
That would be the first clue to do what I'd do anyway on a new to me motorcycle.
Go thru everything. Everything. I'd not be surprised if the fork oil isn't well past it's service date.
Unless you KNOW the history for service it's time for a total going over.
Wayne Orwig
Reply #3 on:
January 03, 2026, 03:25:57 PM »
That bike SHOULD have the rear brake proportioning valve under the swingarm. Look under the swingarm just ahead of the brake caliper. If it does, then there should NOT be a factory spring preload adjustment on the shocks. It messes up the setting for that valve. There should be damping adjustments but should not be spring preload adjustments, from the factory.
That being said, people have changed the shocks and spring and not noticed an issue. Just saying......
VINNY59
MR
New Egg
Reply #4 on:
January 03, 2026, 11:42:26 PM »
I cannot see any rear brake proportioning valve under the swingarm, here is apic of rear shocks left and right, as can be seen the left has the preload blacgk collar , the right does not, also the rebound adjusters are at the bottom, I have seen other pics of cali vintage with them at the top, so are the rear shocks fitted upside down? also why are they different. this bike has 27000km form new and is in showroom condition.
guzzisteve
"Just Ride It"
Reply #5 on:
January 04, 2026, 02:36:08 PM »
CalVin's have a valve for brakes on the LH side under side cover like old days and a bleeder on top, nothing on bottom of swingarm.
