Author Topic: Adventures In Tire Mounting  (Read 4007 times)
kballowe
« on: January 11, 2026, 08:10:24 AM »
A friend of mine dropped by with a "take off" Gold Wing wheel that he'd recently purchased.
I mounted a tire on what appeared to be a perfectly serviceable wheel.
A good spin on the static balancer tells another story.  I uploaded the video to YouTube.  I would have never caught this if I had been using balancing beads instead of this static balancer.
Here's the link.
https://www.youtube.com/shorts/nU9-BW_Yfts
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: Adventures In Tire Mounting
« Reply #1 on: January 11, 2026, 08:29:33 AM »
“Bring out your sledge!
Bring out your sledge!”
Offline Oca Grassa
« Reply #2 on: January 11, 2026, 08:51:44 AM »
A sledge ain’t fixing that wobble, sorry. Okay, maybe make it so no one else buys that wheel!!
For the record…I hate balance beads. Particularly when my customer doesn’t warn me that they’re “installed”
Put that wheel in the bead breaker and as soon as the bead breaker snaps open the bead….its like an explosion of balance beads. They go every freaking where. Now I gotta stop & clean up the mess. Same for slime or any other liquid puncture seal.
I use the harbor freight balancer with the Marc Parnes “axle” and cones. Being able spin a wheel with a reference to check for run out and/or damage is worth the extra cost to me.
My garage:
Offline Pescatore
« Reply #3 on: January 11, 2026, 11:09:27 AM »
How does that even happen?!?  I would think it was straight when new.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Offline Oca Grassa
« Reply #4 on: January 11, 2026, 12:11:55 PM »
If I had to guess, a front end collision. With something striking one fork leg or other. It appears the hub is twisted laterally on the spokes. It would take a significant amount of force to do that.
I’ve seen rims damaged with a pneumatic machine, but not like that. You’d have to hold the axle fast, then strike the hoop with significant force to twist it like that.
My garage:
Online nc43bsa
« Reply #5 on: January 11, 2026, 01:01:35 PM »
Especially since there isn't a significant ding to either bead surface.
1990 MilleGT
« Reply #6 on: January 11, 2026, 01:29:57 PM »
I took a bent Lester wheel to a shop in Minneapolis about thirty years ago . It was the straitest wheel I’ve ever seen on a motorcycle afterwards. I didn’t think it was save able but it was their speciality. A competent wheel shop can do wonders.
Offline Trialsman
« Reply #7 on: January 11, 2026, 01:40:18 PM »
Rather than trying to strike it to straighten it, put it on a hydraulic press and block one side to get the twist onto the rim.  You should be able to do it without collateral damage to the sides of the rim.
« Last Edit: January 11, 2026, 04:30:02 PM by Trialsman »
2010 FE570 Husaberg
2019 Alta Redshift EXR
2021 Moto Guzzi V85TT Centenario
2024 Stelvio V100
2026 Bonnell 805 EX
Online Dirk_S
« Reply #8 on: January 11, 2026, 01:53:20 PM »
Fine.
Two sledgehammers.
Online guzziart
« Reply #9 on: January 16, 2026, 04:20:01 PM »
Just something else to check before you buy a used $50 rear wheel off of a triked Wing, unless you're looking for a mangled wheel. :laugh:
« Reply #10 on: January 20, 2026, 12:20:04 AM »
It's a loss but could be an experiment to use a press to straighten it out.  Caveat emptor.
