All of my early Guzzis have run fine with VHB c30 and c29 carbs, including my current 2 850Ts and 1 G5. I experimented with a PHBH 30 and was not happy with the overall performance or fuel efficiency (but I didn't chase the issue with jets and needles, etc). Also, they didn't fit well under the side covers due to a different intake manifold. I'm wondering if anyone has experience, information or opinion on VHB-A carbs. They're different from the VHB-C carbs in having no accelerator pump and other details, and I hear they're a higher-performance carb, possibly more difficult to tune. Thoughts?
Thanks for the input on the VHB A-type carbs. Interesting that they can't be jetted to work adequately well on Guzzis. I see some practically being given away, and thought they might be a "plug and play" for the VHBC type, but I guess not. And I like the recommendation of the PWK copies. The price is right and they're simple, as long as you have the manifolds for Amals. Maybe next time I build a bike, I'll chase down a pair of these. For now, I'm still trying to get this set of VHBCs together, and scrounging parts from Charlie Mullendore. I wish I'd had the foresight over the past few decades to save critical parts like carbs.
Do they make the PWKs in left and right hand versions?
Charlie M - When I searched for the main jet holder for the VHB at Harpers, using Dell'orto p/n 7828, nothing showed up. The only "main jet holder" that showed was for the PH-type carbs. I couldn't find elsewhere the specific Guzzi p/n, as all the carb diagrams I could find only showed the Dell'orto part numbers. Interesting. Same story at Bevel Heaven. MG Cycle doesn't even carry the main jet holder. Anyway, thanks for the part number reference.
Probably so. There's a bump on the side of the carb where one could drill and tap for the idle speed screw, but I don't see the same for the air screw.
