Author Topic: 17" front on a V85?  (Read 26365 times)
Offline Vagrant
17" front on a V85?
« on: February 01, 2026, 09:09:48 AM »
Seeing as the mother ship isn't interested in making the V85 roadster I want to lower mine more. At 78 the muscles are toast and with a 28" inseam even my lowered 1" v85's are a bit too much when I get off on the side of the road on gravel or a foot slips at a stop. I am not willing to give up all the great things the V85 has like the extra revs, brakes and comfort over a v7-850. My thoughts are a 17" rim laced on a stock wheel. That with my current lower (17MM) shock might make the bike more manageable for me. Would that work with all the nanny systems on the bike or will it go into red light hell on me. Most likely I'd pick up a complete used wheel then send it off to Woodys.  Thoughts, facts?
Online PeteS
Re: 17" front on a V85?
« Reply #1 on: February 01, 2026, 09:33:06 AM »
Ever since my first dual sport I get on and off like a horse. Left foot stays on the peg and swing the right leg over. Side stands and pegs  on my KLR, Triumph Tiger and V85 and plenty strong enough.
Online Perazzimx14
« Reply #2 on: February 01, 2026, 11:43:25 AM »
I ran a set of RT wheels on my Hexhead R1200GS and it was a great combo. The 17" front really livened up the steering w/o sacrificing high speed stability and also the increased my tire choices as the RT wheels used common 120 and 180 series rubber so I could get sport, sport touring or super sport rubber.
Honestly I would like if BMW offered the 17" front as an option to the 19" for those of us who are never going to take the bike off-road.
I say go for it especially if you can get tubeless.
Online bad Chad
« Reply #3 on: February 01, 2026, 11:57:07 AM »
I don't think you specifically said it here, but you do have a lower seat right?   You did say you dropped the bike down an inch, but didn't say how.
1988 YX600 Radian
Offline Bulldog9
« Reply #4 on: February 01, 2026, 12:00:04 PM »
Steve, I think it's doable, but this is hurting my brain a bit. You mean keep the stock V85 hub (brake rotor/ABS/hub, etc) and have a 17" rim laced to it? You would likely have to reset/learn the ABS module so sensors are sync'd but I doubt it would need much more unless the speedo is connected to the front wheel. THis would give you about a 1" drop in the front. Can you lower the fork on the TT as an alternative?
If you do this, why not go all the way and swap out the beak for a Caponard Front Fender and fit a proper round headlight and new screen?
« Last Edit: February 01, 2026, 12:12:46 PM by Bulldog9 »
MGNOC#23231
Offline Huzo
« Reply #5 on: February 01, 2026, 12:03:25 PM »
The 2” reduction in diameter will result in the front lowering by 1”.
You sit half way between the front and rear contact patch of the tyres, so that equates to 1/2” reduction in reach to the ground, only you know if it’s worth it. I slid the forks up in the yokes and fitted a shorter shock.
That involved major surgery on the side and centre stands, but I got the seat height down to 30” if memory serves.
You can see it here.
Offline skippy
« Reply #6 on: February 01, 2026, 12:10:37 PM »
The 2" difference in diameter may be to much for the logic that monitors wheel speed to overcome and your abs and speed indication may not function correctly, even after a recalifration. Food for thought.
23 V100 Mandello
20 V85TT
Online Perazzimx14
« Reply #7 on: February 01, 2026, 01:04:28 PM »
On the BMW's at least  there was no resting or relearning the ABS sensor. The sensors are somewhat relational F/R and as long as they are both sensing movement all is well.
Offline Huzo
« Reply #8 on: February 01, 2026, 01:31:59 PM »
Does the ABS and TC (if applicable), work on the differential in rotational speeds in spin up/lock up situations ?
Offline ridingron
« Reply #9 on: February 01, 2026, 01:59:05 PM »
There has to be some allowance in the system to allow for wearing tires and different diameter of tires. MY Honda ABS kicking in is seamless. You can barely feel it. My old BMW F650 GS was crude in comparison. It was very obvious by sound and feeling.
Ask if anyone has a 17" wheel to loan, that can be fitted. Have to be sure the sensor ring and sensor line up. I wouldn't worry about spacers to get the caliper/rotor aligned, just tuck them out of the way. Just take it easy and just run it around the block. The ABS system will work or it won't.
« Last Edit: February 01, 2026, 02:16:12 PM by ridingron »
« Reply #10 on: February 01, 2026, 02:49:15 PM »
Hamlin would know.
Offline Vagrant
« Reply #11 on: February 01, 2026, 05:13:07 PM »
As stated 17mm shorter shock factory that lowers seat 1" when allowing for the angle of the shock. The stock seat has no rubbers under it so it's as low as the Guzzi low seat. The forks are raised to the fourth line and the side stand has been shortened already. It's all together not enough as far as I'm concerned.
The real question is if the TC, ABS and Lean angle on the 2025 will work without codes. The speedo is useless anyway so I would use a GPS. The one extra inch of shorter height the 17 would give could be a perfect fit.
Yes I would find a full stock wheel somewhere then I'm sure Woodys can get a rim to fit. Using a 120/70/17 would be great for tire choices.
Offline Vagrant
« Reply #12 on: February 01, 2026, 05:15:14 PM »
Hamlin would know.
I bet he does but I hate to have to ask because unless he has a good wheel for sale he wouldn't make any money on the deal. Unless he can lace me one.
« Reply #13 on: February 01, 2026, 05:47:48 PM »
Maybe try asking the folks who sold you the bike.  Appears you've been a good customer.  They may be able to guide or assist.
NOT being a smart guy, mind.  AS the folks you spent $$$$ with.
Cliff in Queen Creek is a great guy and talented mechanic.  Owns Manic Moto.  He may assist also.
Offline Bulldog9
« Reply #14 on: February 01, 2026, 05:50:26 PM »
With a 2" shorter diameter on the front wheel, the only real change would be the timing of the front wheel on the ABS sensor. I had to recalibrate the ABS/TC on the Stornello when I fit the Shinko 705's. Wasn't a big deal, but the TC and ABS was wonky until the recalibrate. I think it's an interesting idea, and will likely improve handling.
Can you drop the front any more?  You could also get lower profile tires, that's what I did on the Breva 750 when trying to get it lower for SWMBO to ride.
MGNOC#23231
Offline Vagrant
« Reply #15 on: February 02, 2026, 09:30:36 AM »
If I recall 4 lines down on the forks was maxed for clearance somewhere.
Online Perazzimx14
« Reply #16 on: February 02, 2026, 10:03:20 AM »
Yes!
Offline auzziguzzi
  • This ain't no dress rehersal
« Reply #17 on: February 02, 2026, 03:35:37 PM »
FWIW, I went the other way and ran a 19" front rim and single disk on my Norge for use on dirt roads.
ABS threw an error when the speed got to an indicated 80 kmh (50 mph).
I think it may have disabled the ABS once the ABS light came on - not sure.
Other effects :
Threw the speedometer reading out.
Threw the odometer reading out.
Slowed the steering but still completely tolerable.
Handling was fine, whether on the tarmac or the gravel.
'96 Sport 1100c (67,084 km)
'83 V50 III (80,000 km)
'06 Norge (169,000 km)
'90 NTX 650 (66,911 km)        SOLD 21/08/2025
'06 Breva 1100 (84,505 miles) SOLD 03/03/2022
Offline Bulldog9
« Reply #18 on: February 02, 2026, 03:48:11 PM »
Steve,
Hard to know unless someone does it, but I would think that keeping the same hub and tone ring, all you'd need to do is to recalibrate the TC/ABS system.
As you know the system (at least on the V7ii and iii) is pretty sensitive to tire size, and even pressure, so a 2" shorter front wheel will definitely send signals different than expected, mess with the ABS and trigger the TC system.  For me, the V85 and E5 version with TBW is a big unknown.
MGNOC#23231
Offline Vagrant
« Reply #19 on: February 02, 2026, 05:54:21 PM »
Steve,
I've switched through several brands front and rear on all 4 v85s and haven't calibrated one yet. But yes the v7 serries seems a bit touchy.
Offline Vagrant
« Reply #20 on: February 02, 2026, 05:57:05 PM »
I think the forks could go up another inch if I remove the Micky mouse ears I installed on the front of the gas tank for stopping wind
. I'm at the fourth line (see pic).
Has anybody raised them higher than this?
Offline Huzo
« Reply #21 on: February 03, 2026, 02:05:50 AM »
Not me.
Offline YellowDuck
« Reply #22 on: February 03, 2026, 07:59:21 AM »
It's a pretty long travel suspension - are you ever coming close to bottoming out?  Put a zip tie on one of the fork legs to find out.  If not, you can sacrifice some of the positive travel to reduce front ride height just by winding all the preload out.  If that's not enough you could fit shorter springs, or even easier cut down any spacers that are in the forks (not sure if the V85 has any).  None of that will create any problems with how the forks function so long as you still have at least a little bit of installed preload on the springs with the forks fully extended (i.e., you still need to compress the springs at least a little to screw the fork caps back on.
All of that is a lot easier than swapping out the front rim.  Of course you want to match whatever you do to front ride height at the rear end as well, but you know that.
Online PeteS
« Reply #23 on: February 03, 2026, 08:08:40 AM »
These are upsidedown forks. How can they possibly bottom out? There is way more than 5 inches to the fender.
It appears the limit is determined by how far down the top leg is at the same diameter for the triple clamps to engage it.
Offline Vagrant
« Reply #24 on: February 03, 2026, 09:13:08 AM »
In S. Az. I run 1-1 1/2 turns of preload now because our roads are so bad. In N. Ga. I think I am at 4 turns.
Offline YellowDuck
« Reply #25 on: February 03, 2026, 04:41:42 PM »
Well externally the maximum travel would be when the dust seal contacts the casting on the bottom of the fork lower.  But travel in USD forks is internally limited slightly before that happens.  I am not clear on how, exactly - I think sometimes it is an internal bump stop, and in other cases at the end of positive travel the piston blocks an oil port leading to hydraulic lock.
Online PeteS
« Reply #26 on: February 03, 2026, 05:49:13 PM »
None of that is dependent on the location of the legs in the triple tree.
I suspect the marks on the fork legs are in a range Guzzi feels will not negatively affect handling. If it was me I would just move them up gradually and see how it handles before making a new wheel. If its proves acceptable you won’t have to deal with ABS issues.
Offline Huzo
« Reply #27 on: February 03, 2026, 06:18:01 PM »
If you refer to the shot I posted earlier with my lowered V85 next to a stock one, you’ll see the difference in seat height. I think mine is 815 mm which is about 25-30 mm lower than standard.
Also you’ll see how much closer the reflector is to the bottom clamp, versus the stock one.
This is a visual indication of how much I moved them and also see how much straighter the universal joint is to being straight…No losers there.
It isn’t hard…
Offline Vagrant
« Reply #28 on: February 03, 2026, 06:56:34 PM »
I think this is the avenue to go for now. I will do it if we ever have a rainy day. Of course that might not be till next year as it was 78 and sunny here today.
Offline Vagrant
« Reply #29 on: February 03, 2026, 06:59:45 PM »
Huzo, I did go back and look at it. I bet your 1 or at least 3/4" below the fourth line. Could you take a pic and measurement of the top of the fork like I posted?
Thanks in advance.
