Author Topic: Anyone ever moved forks up?  (Read 6832 times)
Offline SemperVee
  • USMC Retired
« on: February 02, 2026, 03:02:14 PM »
  Old trick I did on both my Vstrom1000's was to raise forks a bit approx 1 inch above triple tree to lower the front end a bit and thereby the saddle height. Doing this would  Lower the windshield on the EV along with less stress on the front brake line since I have spacers acting as 1 inch risers under the stock triple tree handle bar riser -  I am thinking of doing it to my 03 EV.    Anyone ever do this themselves for any reason and review outcome?  thanks.
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
Offline faffi
Re: Anyone ever moved forks up?
« Reply #1 on: February 02, 2026, 03:29:52 PM »
It will alter the steering geometry and CoG, something you can find to be better or worse than stock - after you make a test ride. If you lower the rear that same amount, you will retain the geometry, but you will lower the CoG further. Whether you want to lower just the front, or include the rear, one inch should not be enough to render the bike dangerous. So why not try it and see what YOU feel?
Current bikes:
2002 BT1100
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Offline Bulldog9
« Reply #2 on: February 02, 2026, 03:37:10 PM »
1" is a lot, and may be too much, I'd start with 1/2 that. Most report quicker steering and turn in, but you can go too far. I'd make sure you have Sag set properly front and rear and that you are currently at the factory rake, then make adjustments from there.
MGNOC#23231
Offline SemperVee
  • USMC Retired
« Reply #3 on: February 02, 2026, 04:55:20 PM »
 I have sag and forks set quite nicely and plan on doing it starting with 1/2 inch.  Just wondered if others had done so previously to this model since it has been out so long already with so many Cali riders here.  Thanks for input.
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
Offline turboguzzi
« Reply #4 on: February 02, 2026, 05:30:15 PM »
Doesnt really matter which bike you do it to, the physical principles are the same :)
done it on my race bike all the time because it quickens steering, which can be good, but like most bike settings, there's no free lunch.
downsides are: less trail (less front end "feedback"), less ground clearance, less available suspension stroke.
like noted by others, 1" is a lot. Consider that your Cali has a bit less than 5" suspension travel, 1" is like taking out 20% of its stroke....
Offline Vagrant
« Reply #5 on: February 02, 2026, 06:02:41 PM »
It works on the v7 and v85.
It does NOT work on an EV 98 or 01. I tried on both. It will turn it into a tank!
« Reply #6 on: February 02, 2026, 06:21:47 PM »
I move my 98EV up 20mm, it feels exactly like all the older Tonti's before the Cal2 that got longer forks & felt weird. It has shorter Earl's forks on it for sidecar use, they are like ones for a G5. I like how it feels & cranks in the curves, feels more planted. I would not go up any higher than 22mm.
Offline drdwb
    • backfeelsgreat.com
« Reply #7 on: February 02, 2026, 06:38:28 PM »
Did this to my wife’s 04 Stone, I don’t recall who on the forum suggested it , we put on 1” lower shocks on rear, and raised the forks by 3/4” as suggested. We also put 1” bar spacers to bring the bars back.  Compared to my 03 EV these changes made it a much more nimble bike, I have to remind myself of it every time I get on. Much more sporty feel. It was a great change.
Online SIR REAL ED
  • uh.... it's personal....
« Reply #8 on: February 02, 2026, 06:43:22 PM »
IIRC, the salad fork is correctly positioned at 9:00 relative to the plate......
2002 MZ Skorpion
1994 DR Skorpion
Offline cappisj1
« Reply #9 on: February 02, 2026, 06:53:07 PM »
You are changing the rake and trail when moving the forks up or down in the mounts if you are not changing the hight on the rear of the bike to match. Pushing the forks up will quicken the steering or make it “tip” in with less effort. Moving the forks up too far (shortening the rake too much) will cause a head shake. Moving the forks is a great tool to get your bike to handle for you but, don’t go past its limits.
73 Eldorado
75 T Cafe
08 Norge
23 V85 Travel
Offline rudyr
« Reply #10 on: February 02, 2026, 07:26:28 PM »
Don Guzzi dealer in ok city drop my V85 about 3” new shock and slip tubes about that. Guz put mark on the tube for about 2”. Rides good enough for me. I quit having fun at a 100 mph. I have went about 10,000 miles since you’ll do what feels good. Rudy
Offline pehayes
« Reply #11 on: February 02, 2026, 08:28:20 PM »
I did 20mm on Regina's 98EV HDM but also used rear shocks 1" shorter.  Intention was a shorter bike for a woman rider.  Performs very well.  Only drawback I find is nearly impossible to load onto the centerstand and the bike sits a little more vertical on the sidestand.  You really have to push very hard to ground out any stand component in the curves.  BTW, the 98EV has a mostly useless brake pressure proportioning valve which is managed through swingarm arc.  Shortening the shocks changes this system.  I went to the extent of fabricating a simple change to the threaded brake valve adjuster so the system performed as original (still mostly worthless).
Offline Turin
« Reply #12 on: February 02, 2026, 11:29:02 PM »
I've done it to almost all of my bikes. it quickens steering. Longer rear shocks/shock has the same effect. I usually start with 10mm increase by 5mm increments.. I had to go pretty far with this one due to a rear wheel change that dereased the wheel diameter by 2 inches.
1985 Sidlow Guzzi
Offline faffi
« Reply #13 on: February 03, 2026, 06:55:30 AM »
Unless the wheel slams into the lower triple clamp, you do not lose any wheel travel by raising the fork tubes up above the triple clamp, as wheel travel is determined by the damper rod.
On average, one inch change in ride height = 1 degree change in rake. You will easily alter the rear height of many bikes just through spring preload, or by adding a passenger, and few think about that when they ride. So unless your bike is bordeline stable, most will not feel much difference by a one inch change in attitude. On a sportbike with radical geometry, sure, an inch is substantial, but not on a basic motorcycle. Even Spies, world superbike champion, claimed that he needed at least 5 mm (1/5 in) to notice a change on a superbike riding as hard as possible, but that a motoGP bike was way more sensitive. Streetbikes like the majority of Guzxis far removed from either.
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
kballowe
« Reply #14 on: February 03, 2026, 07:29:31 AM »
I've lowered many adventure style bikes but always lowered the front and rear.
And then had to shorten the side stands.
You'd just have to try it on your bike and see how you like it.
« Last Edit: February 03, 2026, 07:30:24 AM by kballowe »
Online Moparnut72
« Reply #15 on: February 03, 2026, 09:41:27 AM »
I raised the forks on my Mandello as I was having issues with holding it up coming to a stop especially when loaded with camping gear. I didn't see much of a change in handling except it seemed to hold the line better in turns. The preload at the rear was at the lowest setting. As for the side stand it leaned over too far to start with. I thought about getting a lower shock for the rear but I didn't think it would make much of a difference. I didn't want to spend big bucks for an experiment. I got a V7 instead.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline chuck peterson
« Reply #16 on: February 04, 2026, 04:47:12 AM »
On a Convert, I changed the front forks to the later longer G5 internals that lengthens the forks, resulting in the rear tire grounding out while on the centerstand. Raising the forks in the triples (lowering the triples on the forks?) was the answer to that problem, and quicken the steering nicely despite the stock 110/90 front tire
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
