Author Topic: Removing and replacing mufflers  (Read 5415 times)
Offline Mackers
  • Five miles or 1000ft...how hard can it be?
    • Motoguzzimackers Moto Guzzi Diaries
« on: February 04, 2026, 12:46:01 AM »
Removing mufflers is one of the worst jobs when working on my Guzzi.  It is a fight against creosote glue that resists pulling, twisting and hammering.
Does anyone have a method to clean up the muffler aperture and header pipe so that they just slip back together?
Raymond Massey:  "No doctor, I think this calls for something special.
                  I think, perhaps, the Melbourne Method!".
Peter Lorre:  "Not the Melbourne Method!!  Please!!"
            - Arsenic and Old Lace, 1944.
('06 Breva 1100 and '02 Cali EV - '01 Metal Stone deceased).
Offline chuck peterson
Re: Removing and replacing mufflers
« Reply #1 on: February 04, 2026, 04:34:43 AM »
When assembling head pipe to crossovers to mufflers while cold, slather 3-4” of each joint with anti-seize, more than necessary. Fire up the motor to heat up the exhaust joints. The anti seize will liquify and excess will drip off. Next time you take it apart it will only take a few blows with a soft face sand filled hammer. Hopefully…
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline Perazzimx14
« Reply #2 on: February 04, 2026, 06:19:32 AM »
I would also encourage that the OP clean the male/female exhaust joints with a compatible material (for instance do not use a carbon steel wire wheel on a stainless exhaust) prior to the slathering. As for the slathering I prefer to go with a thin schmear on the male/female parts with copper based anti-seize. Globbing on excessive amounts of slip'em is just more to clean up. Like tire lube the goal is not to see how much you can apply it is applying the right amount in the right places :thumb:
« Reply #3 on: February 04, 2026, 06:28:12 AM »
And don't forget to put that anti seize on the clamp bolt threads.
Offline davethewelder
« Reply #4 on: February 07, 2026, 10:57:44 AM »
I too found reinstalling the muffler on my V7-850 Stone, damn near impossible.   Its almost like you should buy a new gasket.
Offline Stretch
« Reply #5 on: February 07, 2026, 06:33:26 PM »
I use the copper-based anti-seize, and muffler removal on the big 1400
Cali is still a wrestling match. Not as bad as the first time, though.
If anyone has a better idea, and I think I can speak for the entire forum
here, we'd be appreciative!  :cool:  :bow:
                                                -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
Offline bigbikerrick
« Reply #6 on: February 10, 2026, 12:00:06 PM »
I like to use a smear of whatever silicone rtv sealer I have around. Its heat resistant, makes removal of the mufflers later easy,and seals up any small imperfections between the pipes,as no exhaust leaks out. Someone here taught me that tip years ago,
Rick.
Offline Mackers
« Reply #7 on: February 10, 2026, 03:49:25 PM »
I cleaned them up with a brillo pad and applied a smear of copper annti-seize.  They slipped together easily.  I'll see eventually how they come apart.  Thanks for the advice.
Offline faffi
« Reply #8 on: February 11, 2026, 01:31:16 AM »
The mufflers on my V9 has slid off and on with ease every time. Now, if you all buy V9s, problem solved :grin:
Current bikes:
2002 BT1100
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Online Moparnut72
« Reply #9 on: February 11, 2026, 09:10:44 AM »
In the airplane radial engine shop I used to work in we used Permatex Ultra Copper on anything that needed to be sealed. A very light smear on both sides of a gasket worked well against leaks. In the event something had to be removed it would come of very easily, valve covers were the usual culprits.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
