Author Topic: Loop wheel on a Tonti?  (Read 387 times)
Online wirespokes
« on: February 13, 2026, 09:52:16 AM »
Is an Eldorado disc front wheel any different than an early Tonti - say an 850T or a T3? I'm thinking of getting an Eldo disc wheel to use on a T3.
Re: Loop wheel on a Tonti?
« Reply #1 on: February 13, 2026, 10:38:36 AM »
Hub is different wheel rims maybe same, Tapered bearings in one, roller bearings in the other, just use the right stuff or get it new from HMB. Call Harpers they might have a trailer full, if He ain't to lazy to go get them.
« Reply #2 on: February 13, 2026, 10:50:43 AM »
Disc Eldo front wheel is virtually identical to T, T3, Convert, G5. The bearing carriers will be different - Eldo will have one that is 39.5 mm thick and the other that is 22 mm thick. You'd need a pair of 29.5 mm thick ones for use on a T3.
https://www.mgcycle.com/index.php?main_page=product_info&cPath=218&products_id=579
« Last Edit: February 13, 2026, 10:52:11 AM by Antietam Classic Cycle »
Online wirespokes
« Reply #3 on: February 13, 2026, 11:13:25 AM »
Thanks, Charlie! I figured you'd know.
So the answer is that Eldos used ball bearings and newer ones have tapered rollers. Right there is enough to warrant changing the carriers, though the wrong thickness would definitely dictate a change.
Did the eldo disc front wheel have stainless spokes?
« Reply #4 on: February 13, 2026, 11:39:19 AM »
You kind of have that backwards. Most drum brake Loops had tapered roller bearings (the exception being the four-leading-shoe front drum which used ball bearings). Tontis all used ball bearings (except the rear of the V7 Sport).
Stainless spokes (with nickel-plated brass nipples) were used on Loop wheels after 1969, so yes, the disc Eldo front wheel will have stainless spokes.
If you buy the disc Eldo wheel and it comes with the 39.5 mm wide spacer/bearing carrier, I would be interested in buying that. A bit hard to find.
« Last Edit: February 13, 2026, 11:46:43 AM by Antietam Classic Cycle »
« Reply #5 on: February 13, 2026, 12:18:39 PM »
Thanks for correcting, I knew you would be along.
Online wirespokes
« Reply #6 on: February 14, 2026, 03:08:49 PM »
Yeah, that's right. I forgot the tontis have ball bearings - I'm so used to the airheads with their tapered rollers.
Offline matt franklin
« Reply #7 on: February 14, 2026, 05:43:53 PM »
It would probably be easier to find another Tonti front wheel than the Eldorado disc wheel.  It was only made for 1 year.  Any convert, G5, T or T3 wheel would work.  SP as well.
« Reply #8 on: February 14, 2026, 06:31:17 PM »
It sounds to me like he's already found the Eldo wheel and just wanted to know if it will work or not. Short answer is it will. it's the same wheel except for the bearing carriers.
The 1000SP had cast alloy wheels, not spoked ones.
« Reply #9 on: February 14, 2026, 09:15:59 PM »
It might look weird, but I assume it would work, since the hub width is the same.
Online wirespokes
« Reply #10 on: February 16, 2026, 08:43:42 PM »
It looks to me like a normal T3 wheel. I'm guessing it was the first of the normal wire wheels used on the 850T and newer.
« Reply #11 on: February 16, 2026, 08:57:31 PM »
The disc Eldo and 850-T were produced concurrently (there were '75 Eldos BTW), so it was the same wheel. Rim, spokes and hub were identical, only different width bearing carriers were used for the 195 mm 850-T fork spacing and the 205 mm Eldo spacing.
Online wirespokes
« Reply #12 on: February 18, 2026, 10:00:19 AM »
Thanks, Charlie. You know, any more I'm hesitant saying any parts are the same if I don't know for absolute sure. They can look the same, and logically, should be - but I've been tripped up a number of times when they weren't. I don't know if that's the case so much with Guzzis, but I'd run into that a lot with airheads. As in this case, it doesn't make sense the wheels would be different, but anymore I'm cautious.
