Author Topic: VHB 29 (Ambo) Pod Filters, Stacks, Jets  (Read 308 times)
Offline neetones
« on: February 17, 2026, 09:48:11 AM »
The previous owner got rid of the airbox and installed these pod filters.
I believe the jetting remains stock, though.
Recommendations? Do I need velocity filters? Are there better pods I should be using? Are there good jet sets to purchase?
Thanks!
Nitin
1969 Ambassador
2022 V7 850 Centenario (sold)
Re: VHB 29 (Ambo) Pod Filters, Stacks, Jets
« Reply #1 on: February 17, 2026, 10:10:00 AM »
I don't understand why owners ditch the original airbox. I always hear about how hard it is to get the boot to seal, but a little Ultra Black RTV takes care of that issue. It's not rocket surgery.
IMO, those filters are a bit small. I used to recommend an oval K&N, but they're getting hard to find and increasingly expensive. Now, I use Uni Filter foam pods attached to the original "velocity stacks". It looks like someone has cut yours down, better than none I guess.
Jets don't come in "sets", you'll need to purchase them individually. You really shouldn't need to change it much, if any. Usually just raising the needle one notch is all that's necessary in my experience.
Offline neetones
« Reply #2 on: February 17, 2026, 01:24:03 PM »
As always, thanks Charlie.
Think it's worth getting something like this and adding new filters? https://www.mgcycle.com/index.php?main_page=product_info&products_id=3201
1969 Ambassador
« Reply #3 on: February 17, 2026, 03:40:48 PM »
I have those and these K&N filters on my Convert (VHB 30 carbs).
https://www.knfilters.com/ru-2450-universal-clamp-on-air-filter
These are the foam filters I mentioned: https://unifilter.com/online-catalog/clamp-on-air-filters/
Offline JoeW
    • The Guzzi Doctor
« Reply #4 on: February 18, 2026, 09:54:19 AM »
I use the Uni pod UP4152 foam filter with a pair if 850T3 velocity stacks that I turn down to the same OD of the carb body. Then you can slide the filter on with the velocity stack inside.
 :gotpics:
Joe Walano
