Author Topic: Cranky Norge  (Read 11495 times)
Offline Huzo
Re: Cranky Norge
« Reply #30 on: March 03, 2026, 08:51:38 AM »
Since this problem got worse over a couple of years, I wouldn't suspect the sacred screw.  That should not move over time.
Maybe dirty TBs?  Or all the fuel related ideas already mentioned.
One other related thought is to spray gas into the TB before first crank.
That is a pretty good diagnostic method.
Offline BMCMOTO
Re: Cranky Norge
« Reply #31 on: March 03, 2026, 12:41:19 PM »
The most likely culprit in this scenario are the injectors. When injectors leak the fuel from their supply lines, your circumstances are assured. A leaking fuel pump check valve is also quite possible, but that would still leave unpressurized fuel in the line, so only pressure would need to be built in the line from the pump. Leaking injectors mean not only pressure has to be built but also fuel moved. Air takes longer to compress than it takes to move fuel. The air has to leave by way of the injector opening and closing. There are many way to check for injector leakage, but probably the easiest is to simply have them checked cleaned and flow checked at an injector shop. This has been mentioned before. Please try this. You may be pleasantly surprised!
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline Bulldog9
Re: Cranky Norge
« Reply #32 on: March 03, 2026, 02:14:07 PM »
Brian
Generally, the check valve is between the pump and injectors or fuel rail to keep fuel pressure up, not between the tank and pump. That's just suction. I'm pretty sure Huzo has already said his injectors are not leaking down.
MGNOC#23231
Offline Huzo
Re: Cranky Norge
« Reply #33 on: March 03, 2026, 02:51:39 PM »
I’m a bit hazy on this, it’s not something I have ever been involved with.
I haven’t claimed that my injector/s are not leaking down, I wouldn’t know.
When you say between tank and the pump, I don’t follow you, because the pump is submerged in the fuel.
Why don’t I just remove the injectors from their position and watch them as I crank the starter to see if they deliver fuel immediately as I press the starter ?
Wouldn’t that highlight the issue if there was one ?
Offline Bulldog9
Re: Cranky Norge
« Reply #34 on: March 03, 2026, 03:02:14 PM »
Ah, my bad, I thought you said you had pulled them and let them sit outside the head and nothing was leaking or ripping. Must've been another thread.
I know the pump is immersed in the tank, I was referring to the gas/liquid being pumped. The Fuel System goes as follows as I understand it.
(INSIDE TANK) - STRAINER>>> PUMP W/INTERNAL CHECK VALVE>>> FILTER>>> (OUTSIDE TANK) >>> CONNECTOR>>> FUEL LINES TO INJECTORS.
I would just pull them when the bike is off, leave them out and see if they drip down or are wet over a couple days.
You MAY see some spray immediately, but is it the correct pressure and amount?
Have you tried just cycling the key 2-3 times after sitting to see if it cures the issue?
MGNOC#23231
Offline Huzo
Re: Cranky Norge
« Reply #35 on: March 03, 2026, 03:21:19 PM »
No worries Bulldog.
When I turn the key, I can hear the pump spin up, so I don’t suspect that issue and I have done the key cycle thing as well and it seems to make no difference.
As mentioned and as is evident in video, I can start and run it for two seconds after a week storage where it cranks for 8 or so seconds where it the hesitatingly fires, turn it off, hit the starter and it fires immediately.
Offline Huzo
Re: Cranky Norge
« Reply #36 on: March 11, 2026, 03:05:31 AM »
Today I installed the fuel pump back in with the new filter. I took the injectors out still connected and hit the starter, no fuel came  from the right one.
I subsequently found that the electrical connector was loose to the point of coming away.
This is the offending item.
I will source two new ones as a precaution.
Does anyone know what the way forward to getting new ones ?
e bay, generic automotive replacements ?
I don’t think the decrepid state of the electrical connector is the culprit, because the bike would always run well and start readily once the first start was out of the way, but the new injectors will not go astray.
I notice the prices on e bay vary wildly.
There is a number on my injectors 0267
Is that significant ?
« Last Edit: March 11, 2026, 04:16:03 AM by Huzo »
Offline Pescatore
Re: Cranky Norge
« Reply #37 on: March 11, 2026, 07:55:08 AM »
Good for you to find the problem.
Does the injector fire on second attempt?
If not a connector problem, do you suspect a clogged nozzle?
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Offline Pescatore
Re: Cranky Norge
« Reply #38 on: March 11, 2026, 08:00:19 AM »
In US generic/compatible ones also around $30.
Originals $300.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Offline Huzo
Re: Cranky Norge
« Reply #39 on: March 11, 2026, 10:07:22 AM »
Don’t know Pescatore, but I do know that there is plenty of fuel supply to the injector from the get go, because it spat one out once when the pump was priming and fuel gushed from the supply line.
I may have caused the damage when removing the injector and maybe not, but it’s getting new ones regardless.
When I get the new ones I’ll check the spray while cranking.
Still learning.
Online PJPR01
Re: Cranky Norge
« Reply #40 on: March 11, 2026, 02:52:58 PM »
Peter...there are 2 types of fuel injectors, so you'll need to the ones that are compatible.  Some have 4 holes, some have 8.  When you look on Ebay, make sure it says it's compatible with your model, as the fuel injectors used for 2V are different than 4V.
I have a brand new set of the 4 hole ones (non OEM) that I can send you if you like for postage plus $30 bucks in case you cannot find them on Ebay (which is where I sourced a pair of non OEM ones, and they work perfectly also).  You can get 10 non OEM pairs for the price of 1 OEM...
Glad you found the problem!
« Last Edit: March 11, 2026, 11:32:58 PM by PJPR01 »
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Online nc43bsa
Re: Cranky Norge
« Reply #41 on: March 11, 2026, 03:15:11 PM »
In case your harness needs repair:
https://injectorrepair.com/connector-types/
And, I think the state of the electrical connector had everything to do with your problem.  I've seen that and worse on automotive FI systems, although usually it was rodent damage.
« Last Edit: March 11, 2026, 03:18:17 PM by nc43bsa »
1990 MilleGT
Offline Huzo
Re: Cranky Norge
« Reply #42 on: March 11, 2026, 04:21:23 PM »
Peter...there are 2 types of fuel injectors, so you'll need to the ones that are compatible.  Some have 6 holes, some have 12.  When you look on Ebay, make sure it says it's compatible with your model, as the fuel injectors used for 2V are different than 4V.
I have a brand new set of the 6 hole ones (non OEM) that I can send you if you like for postage plus $30 bucks in case you cannot find them on Ebay (which is where I sourced a pair of non OEM ones, and they work perfectly also).  You can get 10 non OEM pairs for the price of 1 OEM...
Thank you Paul, I will check out some good petrol injection places around here to see what’s up and if I hit a dead end, I’ll take you up on the offer.
Very much appreciated.
Thank you.
Offline Huzo
Re: Cranky Norge
« Reply #43 on: March 11, 2026, 04:22:59 PM »
Possibly yes nc43bsa.
Also much appreciate your interest.
Offline Huzo
Re: Cranky Norge
« Reply #44 on: March 11, 2026, 04:32:35 PM »
If you care to share your cell # Paul, I’ll ring and make some arrangements.
Mine is +61437070946
Thanks again.
Peter.
Re: Cranky Norge
« Reply #45 on: March 11, 2026, 07:31:02 PM »
Thanks for that link :thumb:
Offline Huzo
Re: Cranky Norge
« Reply #46 on: March 11, 2026, 10:26:42 PM »
Mine has 4 holes..
If yours will do the job Paul, I think I’ll take your offer.
Online PJPR01
Re: Cranky Norge
« Reply #47 on: March 11, 2026, 11:31:11 PM »
Hi Peter...indeed, the new set I have has 4 holes...I was mistaken above mentioning 6.
Shoot me your mailing address via PM and I'll get a package out to you this weekend!
They have a IW162 number on them, same ones I've put in my Norge years ago, all working just fine.
You may be able to find them on Ebay as well...here's a reference for the future.
https://www.ebay.com/itm/366107755764?_skw=IW162+fuel+injectors+moto+guzzi&itmmeta=01KKG4Y4JBWYKH12PJG2ZG74WX&hash=item553db904f4:g:LJIAAOSwIgZn2Q55&itmprp=enc%3AAQALAAAA4GfYFPkwiKCW4ZNSs2u11xDHpSE2ov86mrFhRZvWBPUX1%2FNZ00F1589yVW3BCOxJvYMZnuFlEbYHaHkwSj2M5TlMHyCrlu5971VX9Z4HE6dRTIjPE7yA9ZOOW2HTLKQboURi1VQHjERKhSGx5UgSClLNc5Iml3IMobNbOcmrUM5pltbcgmtu1FxhlwCDO4MtZd5eBtk%2F200I05g7hVgAEKvB6JdPykxOw0uLnslYkss3oiag0oKxStF5a05QHybEZ7fFZKl9dvQX--if%2FPSnrNEcR1MnOU4aDt%2BuUegITqrr%7Ctkp%3ABk9SR6LJ-IScZw
Cheers,
Paul
Paul R
2008 Silver Norge
2002 V11 Scura
