Author Topic: My 'new' Stornello  (Read 4633 times)
Online egschade
  • Eric S - MGNOC NJ Rep - mgnocnj.forumotion.com
Re: My 'new' Stornello
« Reply #30 on: March 07, 2026, 08:40:55 AM »
I've narrowed it down to either the Anakee Adv 2 or Pirelli MT60. The Michelins are radials and the new 2 series front is supposed to be quieter - they were kinda noisy on my V85. The Pirellis have the closest looking tread pattern to the OEM Golden Tires but would require mixing a radial on front and bias on the rear. Price is nearly identical so that's not the issue. Ruled out the Bridgestone AX41S - newer tire with few reviews and those were mixed.
Again, I'm riding 90/10 with the 10% on groomed gravel and dirt roads.
Found a good deal on the Chaparral ebay store for the MT60s so going with them.
« Last Edit: March 07, 2026, 08:43:26 AM by egschade »
The elder Eric in NJ
2016 V7 Stornello #394
1971 Honda SL350
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
Online egschade
« Reply #31 on: March 09, 2026, 02:45:10 PM »
Took care of draining the gas and replacing the in-tank fuel filter with an all metal one. Despite only having 94 miles of use the plastic part of the OEM filter was quite swollen. Might have lasted a while but I wanted to change it 'while I was in there' cleaning out tank sediment. Despite the 10 years of storage the inside of tank is rust free, just some gunk floating around in the very bottom. Will fill the tank with premium + Seafoam & stabilizer.
Next up is brake fluid flush then engine, trans and gearbox oil changes. With that done I can start puttering around while I wait for the new tires.
1971 Honda SL350
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
« Reply #32 on: March 09, 2026, 04:10:00 PM »
I was cleaning out one on a Norge & filter change, there was a big (+1 quart ) chunk of foam inside from mfg. Had to cut it up.
« Reply #33 on: March 09, 2026, 04:47:40 PM »
That is what the filter looked like on every one I've pressure tested and still didn't fail at 120 psi.
Online egschade
« Reply #34 on: March 12, 2026, 04:42:43 PM »
Can't believe how dark/oxidized the brake fluid (in tube) and motor oil became. Goes to show what 10 years does despite only going 94 miles...
1971 Honda SL350
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
