Author Topic: Breva 1100 rear brake light switch wiring.  (Read 5221 times)
Offline Keith H
« on: March 08, 2026, 11:11:44 AM »
I need to replace the electrical switch for my rear brake pedal light switch but could do with some guidance from anyone who has done this on their bike.
Looks like a fairly easy basic electrical switch with a connector to part of the wiring loom but I would like to know the best way to access the switch and wiring to remove it and replace with new. Had a brief look at my bike and the part appears to be quite well hidden so advice required please on what needs removing to allow access.
Thanks in advance.
Re: Breva 1100 rear brake light switch wiring.
« Reply #1 on: March 08, 2026, 11:43:12 AM »
Haven't worked on one for +10yrs but think you have to take off side frame plate & plastic side cover and it's mounted on frame or back of side plate. Remove master cylinder to change switch. Wiring goes up into the battery box & connects to loom by R/H side frame under side cover.
If I'm not correct, someone here that owns one will correct me.
« Last Edit: March 08, 2026, 11:50:42 AM by guzzisteve »
Offline theoneandonlymin
« Reply #2 on: March 12, 2026, 03:17:24 PM »
This is the only photo I have. It's from my Stelvio. Just to give you some indication as to what is behind the plate.
