Author Topic: Breva transmission and CARC oil change questions  (Read 7012 times)
Offline nikwax
« on: March 14, 2026, 01:34:14 PM »
I’m looking at doing my first fluid changes on my 2007 Breva 1100.
Transmission: it looks like the transmission drain plug will drain onto the exhaust pipe, cat, and center stand. Am I seeing that right? And if so, what to do?
CARC: there is a bracket holding the rear brake line in place that is almost touching the CARC drain plug. It’s close enough to prevent a socket fitting on the drain plug, and my drain plug is torqued too tight to remove with an open ended spanner. Again, am I seeing that right? Does that bracket come off?
I hope the brake bleeding and oil change are a lot more straightforward 😵‍💫
2007 Breva 1100
Offline Mackers
  • Five miles or 1000ft...how hard can it be?
    • Motoguzzimackers Moto Guzzi Diaries
Re: Breva transmission and CARC oil change questions
« Reply #1 on: March 14, 2026, 06:28:32 PM »
Pinch a sheet of alfoil from the missus and fold that under the drain plug to direct the oil flow. I never had an issue draining the CARC.
Raymond Massey:  "No doctor, I think this calls for something special.
                  I think, perhaps, the Melbourne Method!".
Peter Lorre:  "Not the Melbourne Method!!  Please!!"
            - Arsenic and Old Lace, 1944.
('06 Breva 1100 and '02 Cali EV - '01 Metal Stone deceased).
Offline Pescatore
« Reply #2 on: March 15, 2026, 08:10:15 AM »
Make a chute to direct the oil into a catch pan.
Make sure it's sturdy and stable.  The oil will gush out with some force.
I don't know about the CARC plug. Maybe you can gently move the line to fit a proper wrench.
Are you doing 'lefty loosey'?  :cheesy:
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Offline Huzo
« Reply #3 on: March 15, 2026, 02:17:03 PM »
The line will easily flex out of the way on the CARC.
If you leave the centrestand up, the oil will just drop straight out.
Offline nikwax
« Reply #4 on: March 15, 2026, 04:58:25 PM »
The brake line on my CARC is held in place with a clip, and the clip is very nearly touching the drain bolt. Is there a way to remove the clip?
2007 Breva 1100
« Reply #5 on: March 15, 2026, 05:20:34 PM »
Put the corner of a pan on wheel the other side on a 6x6, it'll go strait down.
Offline Pescatore
« Reply #6 on: March 15, 2026, 07:07:32 PM »
:gotpics:
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Offline nikwax
2007 Breva 1100
« Reply #8 on: March 15, 2026, 07:55:55 PM »
Pull line out & pop it up with a screwdriver, spray silicone spray on knob in hole.
Offline Bulldog9
« Reply #9 on: March 16, 2026, 12:01:37 PM »
I use a box wrench on both, not a socket. As others have said, a small shield to direct the transmission works wonders.
MGNOC#23231
