Author Topic: Convert "deflectors" question  (Read 35430 times)
Offline Cdn850T5NT
  • Cdn850T5NT
Re: Convert "deflectors" question
« Reply #30 on: March 25, 2026, 09:11:44 PM »
Didn’t that model come with crash bars,just curious?
No; did not...
1985 Eurospec 850 T5 NT (Nuovo Tipo - New Type... i.e. Series III)
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #31 on: March 25, 2026, 09:13:03 PM »
They should fit on a T5 but there is spacers that fit in between bar & frame with a longer motor bolt.
Thx
Offline kidsmoke
« Reply #32 on: March 26, 2026, 09:39:32 AM »
No; did not...
do you prefer the squared V1000 style bars to the 'triangulated' style used on the 1000S and Swoop tank Cali's? Might the latter be easier to mount?
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
Offline Groover
    • Scooteropolis
« Reply #33 on: March 26, 2026, 04:46:03 PM »
I love the look of the deflectors, they define the Convert and G5 I think  - word of caution, I lost one once going 88 MPH, same as the DeLorean in Back to the Future... and the bike turned into helicopter and took off vertically!  :grin:
Regarding the engine guard, it should work as mentioned by using the correct bolts on the bottom, and the top mounts to a brace on the frame - not sure if the T5 has that there or not, guessing it does, maybe just not drilled - you can see it in the 2nd photo - my bike doesn't look that clean anymore, not even close - that was 11 years ago right after the restoration... gee time flies, so Back to the Future it is!
« Last Edit: March 26, 2026, 04:50:30 PM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline kidsmoke
« Reply #34 on: March 27, 2026, 09:46:43 AM »
Not long after my arrival here on WG, and the photos of your bike impacted me. Knowing how a G5 could present softened me up and prepped me for taking on Chucks when he was ready to move on. I have a full monty shot of yours somewhere. Care to share here again? I didn't recall that you had all the crash bars mounted.
'79 G5      (Gina)
'93 1000S (Monica)
'09 GRiSO  (Perla)
Offline Groover
    • Scooteropolis
« Reply #35 on: March 30, 2026, 07:46:59 AM »
Hi Kidsmoke, you've always been a fan, I appreciate that! I have to say, I'm "it" now, as I have to add a 1000S to my stable!
Not sure which photo, but I'll gladly add more here!
(Deflectors have been there since auction day when I got it)
« Last Edit: March 30, 2026, 07:50:25 AM by Groover »
1980 Vespa SI Moped
Offline jrt
« Reply #36 on: March 30, 2026, 10:29:51 AM »
That's a nice looking G5, Groover!  Reminds me of the one I bought new, back in '83, I think.  Fantastic motorcycles!
To contribute to the subject- my G5 did not come with deflectors, but it did have the mounting bungs on the crash-bars.  I eventually mounted a Harley style fairing and made my own deflectors out of sheet aluminum.  They deflected some updraft, but I think the SP fairing setup was superior.
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Offline kidsmoke
« Reply #37 on: March 30, 2026, 10:44:52 AM »
That's it! My saved photo was a simple side shot. I like those cast wheels. Nothing I've owned tours quite like the G5. Very confidence inspiring. Perhaps too much so. I've ridden her pretty hard.
Spent all day on my 1000S yesterday. She'll be my steed for this years DGR.
'79 G5      (Gina)
'93 1000S (Monica)
'09 GRiSO  (Perla)
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #38 on: April 04, 2026, 01:35:51 PM »
I prefer the protection of the squarer ones... but I find the "triangular" ones more aesthetic. I currently have the latter ones but would swap-out, at times, the square ones. I plan on fitting rear ones too, for that added protection.
 Per the Harley photos, that's what I want to achieve. Note the "rub pads".
« Last Edit: April 04, 2026, 01:43:52 PM by Cdn850T5NT »
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #39 on: April 04, 2026, 01:41:17 PM »
There are some drillings, as you can see I mounted the "triangle"-shaped bars.... May hafta adapt though... for the "square" bars.
« Last Edit: April 04, 2026, 04:09:29 PM by Cdn850T5NT »
Offline theoneandonlymin
« Reply #40 on: April 25, 2026, 02:39:30 PM »
Do you have these under your wings ?
One on each bolt, for a bit of extra stability once the downforce gets out of hand.
« Last Edit: April 25, 2026, 02:41:33 PM by theoneandonlymin »
« Reply #41 on: April 25, 2026, 06:09:43 PM »
That makes them SUPER wings and cost extra.
« Reply #42 on: April 25, 2026, 07:06:29 PM »
Might even get some lift off!
Offline Groover
    • Scooteropolis
« Reply #43 on: April 28, 2026, 03:04:24 PM »
For those seeking maximum airfoil performance out of the deflectors/spoilers on your Convert or G5 (or others adapting), here is all the information you may need:  :azn:
As theoneandonlymin showed, they look like this when mounted (view from the bottom):
Make note that there is an "upper" and a "lower" support bracket for each Aerodynamic Refinement Spoiler (ARS system)  :wink:  (two of each total)
Harpers sells both and are still available:
18449755 & 18449855
https://harpermoto.com/products/bracket-18449755?_pos=1&_sid=214a665e5&_ss=r
https://harpermoto.com/products/plate-or-bracket-18449855?_pos=3&_sid=214a665e5&_ss=r
Hope that helps!
« Last Edit: April 29, 2026, 01:45:21 PM by Groover »
1980 Vespa SI Moped
Offline TN Mark
« Reply #44 on: April 28, 2026, 07:06:30 PM »
Squared, for sure.
