Author Topic: Shinko life expectancy?  (Read 1548 times)
Offline wirespokes
« on: March 19, 2026, 01:30:44 PM »
Here's the story:
Summer of 2024 I got a mostly finished G5 project from a forum member. It sported a somewhat working electronic speedometer that didn't have an odometer reading. At least, not that I could figure out.
I replaced the electronic gauge with a standard set of T3 gauges and set the odometer to 5k - guessing that would have been the maximum miles the PO rode it. He replaced the cylinders with nikasil, went through the transmission and final drive, installed a permanent magnet alternator, M Unit, mistral exhaust... you get the idea. So I want to get an accurate gauge of mileage since this was all done.
However, just last week I replaced the front tire - a Shinko 712 100x90 - date code 3616. It was down to the wear bars, but could have been run longer. So it wasn't totally shot, but time to go. I have put 12K on the clock since resetting.
I'm rethinking the estimated mileage. I don't recall having a front tire last more than 10 or 11K, especially a Shinko. I'm thinking this tire couldn't have had more than a thousand miles when I got the bike.
So my question is - how many miles do you get from these tires?
Offline blu guzz
  • Loves to ride
Re: Shinko life expectancy?
« Reply #1 on: March 19, 2026, 03:10:35 PM »
Is that date code correct? 2016
Throw that thing in the trash.  It doesn't matter if it has the nubs on it.  Is your life worth it?
I'm presently recovering from a motorcycle related broken leg and I can tell you, I envy those that can walk properly. You don't want to risk this on old tires.
It must have been the drugs, I thought you said you put that one on.  I see now, but I apply the above rant to "even saying it had life left in it".
I am grouchy today.
« Last Edit: March 19, 2026, 03:13:01 PM by blu guzz »
Blue Guzz
« Reply #2 on: March 19, 2026, 04:12:28 PM »
The 712s are "budget" tires for lighter bikes, so don't last as well as the 230 Tour Master. On my Morini 350 K2 the rear would last ~ 6k miles, never wore the front out in the time I had the bike.
« Reply #3 on: March 19, 2026, 05:53:10 PM »
The tyre’s life or your own…?
« Last Edit: March 19, 2026, 07:04:21 PM by Huzo »
Offline wirespokes
« Reply #4 on: March 19, 2026, 09:35:09 PM »
I think I've gotten something like 10K out of the front tires in the past. Rears are less usually.
I've been riding Shinkos ever since Bridgestones doubled in price. What's that - 15 or 20 years? I had a GSPD with a Michelin Anakee that ran 20K miles, about the longest I've ever had a tire last, especially a rear.
This particular front tire gripped just fine up to the end. It did make the steering a little heavy, worn as it was, but it didn't cup and wore smooth and evenly.
Age doesn't necessarily deteriorate tires. There are other factors involved. A durometer (tool to test elasticity) often shows old tires to be as supple as new ones. Just because the tire was 7 years old when I got it was no reason for me to toss it. It looked fairly new and wasn't cracked or hard.
Online Ncdan
« Reply #5 on: March 19, 2026, 10:36:46 PM »
I’ve ran the Shinko brand for over 20 years on everything from older goldwings, Harley full dressers, Harley sport bikes and 4 moto Guzzi cruisers.
I average 7k on the rear and 10-12 on the front.
I never run a tire down to the wear bars simply because its not safe in the rain.
Offline wirespokes
« Reply #6 on: March 19, 2026, 11:02:39 PM »
Thanks Ncdan. That's about the same experience I've had as well.
I ride year-round and have had no issues riding in the rain in Portland Oregon, on old worn out tires - down to the wear bars. In a straight line, it hasn't made much difference through puddles, and in the turns, the grooves are deeper to shed water. My tires wear down in the middle first.
Because they're cheap, guys tend to think they're an inferior tire. They're not. They're actually very good quality. I guess the writing on the sidewalls isn't real classy, but they are very good tires.
Online Ncdan
« Reply #7 on: March 20, 2026, 08:51:33 AM »
My experience with worn tires in rainy conditions is I’ve felt my bike slipping at times. Not necessarily to the point of losing control but enough slip that experience and common sense tells me the tread was to shallow for the condition I was riding in.
An extra few hundred miles is simply not worth the risk of broken bones or worse, let alone a busted up bike.
However everyone rides at their own risk and comfort level👍
Offline Moparnut72
« Reply #8 on: March 20, 2026, 08:51:59 AM »
I put a pair of Shinkos on the T3 I am rebuilding (re-constructing). They are good looking tires with lots of tread. I will add which models  after I make it out to the shop. When my tires start to get close to the wear bars they are gone. I have no desire to take a dive.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline acogoff
« Reply #9 on: March 20, 2026, 09:00:49 AM »
    Usually 6 or 7 thousand on the rear and 10 or 11 thousand on the front.
Marshall County Minnesota USA
Online Ncdan
« Reply #10 on: March 20, 2026, 03:35:42 PM »
You are right where the rest of us has been thus far.
I think this is the norm for these tires.
They may be a little softer compound than some of the other brands that get better mileage. However, there is a lot of advantages to a softer compound tire.
Offline SemperVee
  • USMC Retired
« Reply #11 on: March 20, 2026, 04:05:01 PM »
 Agree about 7 K miles is what I got on my Vstrom 1000's.... Tires worked fine as road bike tires. Multiple sets.   That said I would not ride on tires that OLD!  No Way.
« Last Edit: March 20, 2026, 04:05:49 PM by SemperVee »
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
Online Guzzidad
« Reply #12 on: March 20, 2026, 07:26:13 PM »
   Shinko bought their tire molds and technology from Yokohama.
Online DoubleGuzzi
  • '19 V7III CS; '79 V50; (Triumph S400)
« Reply #13 on: March 20, 2026, 09:07:54 PM »
Amazed me to see vehicles in the States with zero tread, sometimes showing canvas: are there no laws on this?
The legal tread depth limit for motorcycles, mopeds and scooters over 50cc in the UK is 1mm across three quarters of the width of the tread pattern, and with visible tread still remaining on the other quarter. At this point though, the ability of your tyre to disperse water will be limited, and it will be performing far from its best in the dry.
I find tyres to be too squared off (rear) or too stepped (front) long before this limit.
Just for reference, UK & EU:
The legal limit for the minimum depth of the tread on your tyres is 1.6 millimetres, across the central ¾ of the tread around the complete circumference of the tyre. For safety reasons, it is recommended that you replace your car tyres before the legal limit is reached.
« Last Edit: March 20, 2026, 09:09:27 PM by DoubleGuzzi »
Nearly natural progression..
Online Tony F
« Reply #14 on: March 20, 2026, 10:50:47 PM »
That was about 40 years ago though.
Tony
'79 SP1000
KTM Duke 890R
MV Agusta F4 (x2)
Online egschade
  • Eric S - MGNOC NJ Rep - mgnocnj.forumotion.com
« Reply #15 on: March 21, 2026, 11:38:18 AM »
I ran a set of 705s on my BMW F650GS. When I sold it with about 3K on the tires the rear looked ok for another 3K but a little squared off. The front looked hardly worn with another 5-7K likely left on it.
The elder Eric in NJ
2016 V7 Stornello #394
1971 Honda SL350
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
Online MikeP996
« Reply #16 on: March 22, 2026, 06:12:29 AM »
"Amazed me to see vehicles in the States with zero tread, sometimes showing canvas: are there no laws on this?"
Yes, there are laws and vehicle inspections in most US states.  Just as there are laws setting speed limits...  :wink:
For those not familiar, the USA's 50 states are really more like 50 countries in many ways.  Each state can establish its own laws re just about anything!  Texas, for example, just recently eliminated the requirement for annual vehicle safety inspections.
Texas used to allow motorcycle filtering; they recently outlawed it.    :angry:
Arizona did the opposite.   :thumb:
« Last Edit: March 22, 2026, 06:14:38 AM by MikeP996 »
2021 Moto Guzzi V7 850 Special (UK)
1976 Honda CB400F (UK)
2017 BMW R1200RS (TX)
'73 Norton Commando (Mexico
2015 BMW R9T (Mexico)
(Wife's bikes:
2015 Ducati Diavel (TX)
2019 Honda Africa Twin  (Mexico)
2021 Honda NC750  (UK)
