Author Topic: Right turn signals  (Read 2692 times)
Offline guzzi ride
Right turn signals
« on: March 22, 2026, 12:41:01 PM »
I could really use some help. I have a question for you... my right side turn signals don't work, but 4-way flashers work fine on all 4 signals. I saw posts that it might be the dash as it controls the signals. So like you yesterday I removed all the body panels-PITA and checked the plug on the back of the dash and everything looks great. Before all of this I had also checked the switch on left handlebar and cleaned everything up although everything looked good. so now what might it be ???
Online DoubleGuzzi
Re: Right turn signals
« Reply #1 on: March 22, 2026, 01:50:45 PM »
Bike model? LED or incandescent bulbs? Tested voltages at the indicator connectors?
Nearly natural progression..
Offline guzzi ride
« Reply #2 on: March 22, 2026, 02:23:49 PM »
Well that might help, Duh. 08 Norge.
Online DoubleGuzzi
« Reply #3 on: March 22, 2026, 04:59:00 PM »
So, as OEM they are traditional bulbs, albeit coloured; we can rule out a possible faulty load resistor, as that could account for the symptoms.
Tried disconnecting the battery overnight, to reset the ECU/clocks?
Possibly a bad earth/chassis ground for the RHS indicators. Using the hazard lights the grounding may come from the LHS and a look at the wiring diagram will confirm if this is a possibility.
« Last Edit: March 22, 2026, 05:04:36 PM by DoubleGuzzi »
Offline guzzi ride
« Reply #4 on: March 23, 2026, 08:11:07 AM »
Yes I had disconnected the battery and checked the dash plug because the signals are controlled by the dash. All wiring looks good as far as I can see.
Online DoubleGuzzi
« Reply #5 on: March 23, 2026, 09:26:52 AM »
I've had a look at a wiring diagram and can see only the positive feeds come from the dash, the grounds being shared by other components. If the connectors are interchangeable, I'd try switching left & rights signals - the rear is possibly easier to access. This may narrow down any wiring breaks etc.
If not already get yourself a really cheap automotive multimeter (I have a decent one kept in the house and a cheapo AliXpress one in the garage) - it doesn't need to be super accurate. Try to squeeze the probes into the connector blocks whilst still connected, to check for output voltage: perhaps small straightened paperclips will help.
Oxidised connection on the handlebar switchgear? It's possible.
For sh*ts & giggles, I've just done this:
https://www.google.com/search?client=firefox-b-lm&q=guzzi+norge+one+side+indicators+not+working
Check out the AI response.  :wink:
« Last Edit: March 23, 2026, 09:38:20 AM by DoubleGuzzi »
« Reply #6 on: March 23, 2026, 10:04:12 AM »
Check your grounds, all common grounds on motor case.
« Reply #7 on: March 23, 2026, 10:52:49 AM »
Yep,and check the ground inside the lights. They are plastic sockets and deform easily around the contact support area.
Online DoubleGuzzi
« Reply #8 on: March 23, 2026, 11:23:37 AM »
So that'll be three of us that have mentioned grounds.  :undecided:
Offline guzzi ride
« Reply #9 on: March 24, 2026, 10:10:02 AM »
Thank you all for the tips. I'll do some more checking with the grounds etc.
Offline Dukedesmo
« Reply #10 on: March 25, 2026, 04:39:23 AM »
Quote from: DoubleGuzzi on March 23, 2026, 05:23:37 PM
___________________ __________
Indeed, my '79 LM2 had a ground problem to the rear indicators and they would occasionally fail to work.
Never liked relying on the frame to carry the ground so I ran a wire direct from battery negative and no issues since.
I appreciate this is different era of tech we are talking about but "ye cannae change the laws of physyics"
Le Mans II
Ducati 916
Ducati M900
Offline Pescatore
« Reply #11 on: March 25, 2026, 08:20:54 AM »
The bulbs have a single filament for blinker and emergency flasher.
If the flashers work, the wiring and ground to the bulb is fine.
Sounds like a handlebar switch, wiring to the switch or a dash problem.
« Last Edit: March 25, 2026, 08:21:28 AM by Pescatore »
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Online DoubleGuzzi
« Reply #12 on: March 25, 2026, 09:29:37 AM »
On reflection, you may well be right; I did mention switchgear.  :wink:
