Author Topic: Glue  (Read 8268 times)
Online slowmover
Glue
« on: April 14, 2026, 08:04:46 AM »
Broke the rear turn signal off on a 2013 V7. What’s the best glue for the black plastic by the nut? Super glue?
Online DoubleGuzzi
Re: Glue
« Reply #1 on: April 14, 2026, 08:35:47 AM »
Best to use a glue that's specifically for plastics/ABS egs.Qbond and "Loctite Super Glue All Plastics".
« Last Edit: April 14, 2026, 08:38:27 AM by DoubleGuzzi »
Nearly natural progression..
Online PeteS
Re: Glue
« Reply #2 on: April 14, 2026, 08:43:01 AM »
Depends what its made of. Likely either ABS or Delrin. If its the latter than nothing works except melting it back together. For ABS a solvent glue is best but good ones are hard to find now that you can’t get methylene chloride anymore. There are some CAs now made for plastics. They may be your only choice now.
Re: Glue
« Reply #3 on: April 14, 2026, 09:14:04 AM »
Loctite 495
Online Wayne Orwig
Re: Glue
« Reply #4 on: April 14, 2026, 03:23:05 PM »
We need a picture or something to judge it better. Maybe JB Weld would be good.
Online slowmover
Re: Glue
« Reply #5 on: April 14, 2026, 06:03:25 PM »
Ok
Online DoubleGuzzi
Re: Glue
« Reply #6 on: April 14, 2026, 07:00:50 PM »
You can but try. Don't hold your breath though.
That indicator mounting is commonly used on Italian and some BMW bikes; have had quite a few broken ones before and ended up just replacing them, where required.
[I struggled to glue a Breva mirror with any lasting effect.]
« Last Edit: April 20, 2026, 05:25:11 AM by DoubleGuzzi »
Online bigbikerrick
Re: Glue
« Reply #7 on: April 15, 2026, 01:24:04 PM »
Thats probably ABS plastic. Its best repaired by plastic welding the piece back on. If you dont have a proper plastic welder, you can get by with a soldering iron. They sell plastic welding "rod" for different plastics. There is a product called fiberflex that can be used when you are not 100% sure what type of plastic it is. It works with almost all plastics.
Rick.
Online SIR REAL ED
  • uh.... it's personal....
Re: Glue
« Reply #8 on: April 15, 2026, 02:44:44 PM »
Check it out:
THISTOTHAT.COM
2019 Beta EVO 250
Online averb
Re: Glue
« Reply #9 on: April 20, 2026, 01:14:38 AM »
I am pretty sure that the plastic is Polypropylene or HD Polyethylene, neither of which glue at all well, they are Low Surface Energy plastic and chemically inert. I would suggest trying to splint the joint, if you can insert a thin wall tube of Aluminium, Copper or similar and then using JB Weld where you can to plug the two halves together. The Loctite glue shown above may do as well
Steve
OK, I just went out to the shed and checked - the housing is Polypropylene. There is a lot of information on the web about PP glues including the Loctite Plastic Bonding system but note that most if not all of the examples you see have a large, smooth bonding surface, you don't.
« Last Edit: April 20, 2026, 02:16:35 AM by averb »
Offline Dukedesmo
Re: Glue
« Reply #10 on: April 20, 2026, 04:44:02 AM »
Difficult to get a strong repair on that.
You could try drilling through the 2 pieces and inserting some 'pins' to strengthen the bond before gluing? Use thin steel pins, my preference is stainless TIG welding wire.
But I suspect it probably won't last too long before breaking again.
Le Mans II
Ducati 916
Ducati M900
Online DoubleGuzzi
Re: Glue
« Reply #11 on: April 20, 2026, 05:23:44 AM »
All things considered, including my previous comments..
The simpler option?:
https://www.ebay.com/itm/363687083953
Other indicators are available, from various outlets.  :wink:
Online slowmover
Re: Glue
« Reply #12 on: April 20, 2026, 08:39:27 AM »
That sure looks like it.Thanks. So far the Locktite is working.
Online Ncdan
Re: Glue
« Reply #13 on: April 20, 2026, 08:50:36 AM »
The glueing process is a temporary fix, I’ve been there and done that.
Replacing the old parts are your best option.
Because the glued one will fall back  off and probably at the worst time, like on a trip with the guys and you’ll get off your bike at a great restaurant and low and behold there will be a dangling turn signal.
Online DoubleGuzzi
Re: Glue
« Reply #14 on: April 20, 2026, 09:35:56 AM »
These are probably a closer match for the V7 and if replaced as a pair should look OK..
https://www.ebay.com/itm/293089900684
Perhaps a used pair of Guzzi ones:
https://www.ebay.com/itm/366311234891
Back on topic..
A tube of Loolifl 496 has arrived today - guess what that's a copy of? I'm gonna try it out on a section of split rear mudguard (V7 Classic) and one of the cars mudflaps. It was cheap and nothing ventured..
[I likely have a broken indicator from a F650GS/Laverda/Triumph that I can try it out on, purely in the interest of curiosity.]
« Last Edit: April 20, 2026, 09:45:03 AM by DoubleGuzzi »
Offline Motormike
Re: Glue
« Reply #15 on: April 20, 2026, 01:31:54 PM »
I quite agree.  The vibration and sun aging that turn signals are subjected to means they never last more than a few years (except the ones used on Harleys...they are metal!) I've had to replace them on Kawasaki's, Buell's, Moto Guzzi's, it doesn't matter the brand.  Glue is very temporary at best.
Offline malik
Re: Glue
« Reply #16 on: April 21, 2026, 05:21:10 PM »
When my all hard plastic stems broke I took the opportunity to swap out the originals for those from the 1TB V7, with flexible stems. Not perfect, still breakable, but better.
I've an idea too that blinkers might be country/market specific, so adjustments might have to be made.
You might need the block in the picture. Note that the bulbs are amber, not the glass.
