There is literally no load on the engine at 1200 RPM in 4th gear holding speed on level ground. Low RPM/higher gear does not constitute "lugging;" the load on the engine determines if the RPM/gear/throttle position will cause the engine to struggle ("lug.")
The only way there is no load is if you are coasting.
Hose going to manifold goes to valve---------
This morning I temporarily bypassed the EVAP per instructions here and went out for a ride on my '21 V7 850 Special. I couldn't tell any difference in the way the bike acted with the EVAP bypassed. Maybe the effect is different for different model years?
